Hi!
I am using a 125Khz RFID module RDM6300 - UART to read RFID Cards. With an example. Is there any way to make the readings faster. Sometimes I have to keep the card close like 0.5 seconds. We would like to make it faster.
#include <SoftwareSerial.h>
#include <avr/pgmspace.h>
// Tags are stored in program flash memory
// 32k minus sketch size determines the amount of tags that can be stored
// Tags include the two CRC bytes (14 bytes total)
prog_char tag_0[] PROGMEM = "000000000000"; //add your tags here
prog_char tag_1[] PROGMEM = "000000000000";
prog_char tag_2[] PROGMEM = "000000000000";
prog_char tag_3[] PROGMEM = "000000000000";
prog_char tag_4[] PROGMEM = "000000000000";
prog_char tag_5[] PROGMEM = "000000000000";
prog_char tag_6[] PROGMEM = "000000000000";
PROGMEM const char *tag_table[] =
tag_0,
tag_1,
tag_2,
tag_3,
tag_4,
tag_5,
tag_6 };
SoftwareSerial rfidReader(2,3); // Digital pins 2 and 3 connect to pins 1 and 2 of the RMD6300
String tagString;
char tagNumber[14];
boolean receivedTag;
int lockPIN=7; // pin 7 is controls the door
pinMode(lockPIN,OUTPUT);
rfidReader.begin(9600); // the RDM6300 runs at 9600bps
Serial.println("\n\n\nRFID Reader...ready!");
receivedTag=false;
while (rfidReader.available()){
int BytesRead = rfidReader.readBytesUntil(3, tagNumber, 15);//EOT (3) is the last character in tag
receivedTag=true;
if (receivedTag){
tagString=tagNumber;
Serial.print("Tag Number: ");
Serial.println(tagString);
if (checkTag(tagString)){
Serial.print("Tag Authorized...");
openDoor();
else{
Serial.print("Unauthorized Tag: ");
delay(1500); // a delay of 1500ms and a flush() seems to stop tag repeats
rfidReader.flush();
memset(tagNumber,0,sizeof(tagNumber)); //erase tagNumber
// checkTag function (give it the tag string complete with SOT and EOT)
// compares with tags in tag_table
// and returns true if the tag is in the list
boolean checkTag(String tag){
char testTag[14];
for (int i = 0; i < sizeof(tag_table)/2; i++)
strcpy_P(testTag, (char*)pgm_read_word(&(tag_table[i])));
if(tag.substring(1,13)==testTag){//substring function removes SOT and EOT
return true;
return false;
void openDoor(){
Serial.print("Opening door...");
digitalWrite(lockPIN,HIGH);
Serial.println("Re-locking door");
digitalWrite(lockPIN,LOW);
delay(1500);// a delay of 1500ms and a flush() seems to stop tag repeats
rfidReader.flush();
Thanks in advance.
Regards,
Daniel
