Recommend a PCB Manufacturer
I have a couple of projects that I'm ready to go to production with. Can anyone recommend a PCB manufacturer that can take my existing PCB's (I made the Fritzing software) and reduce that to using Surface Mount components with the components already installed?
If you made the board with through hole components then the PCB manufacturer will use through hole components. If you want SMD then you need to make your board with SMD.
Can Fritzing generate gerber files? If not, then such a projects is not suitable for PCB manufacturing, all manufacturers require gerber files.
PCB manufacturers are not going to design a PCB for you, but there are consultants who will do that. Sounds like you are needing someone to design a PCB in something like KiCad, and provide Gerbers and a BOM so that manufacturer like JLCPCB could make an assembled board. There are also contract assemblers who will do that.
There are some good, low cost and quick manufacturers of PCBs out there, normally they accept Gerber files.
But it sounds like you are really after someone to design a custom PCB from a schematic ?
I do design my own PCBs, have done for years, but I would be intersted to know the commercial cost of having someone else do it for me.
You first must find a consultant to convert the board to SMD before considering a board mfg.
I suggest you go to the Kicad forum and ask there for someone to $$ design your new board.
You will also need a bill of material showing the EXACT distributor part number for each SMD component. Use Digikey as one possible distributor.
Hello,
Happy new year!
You just need PCB or PCB+components+assembly service?
You can contact kingcredie who can offer you one stop PCB service.
Phone Number:
0755-23110700 Mobile phone/WhatsApp: +8613066904731
Hello, we do PCB prototype layout design and manufacturing, consultation is free, so you can always ask on whatsapp +65 9460 6626. We have a team of engineers with many years of experience ready to help.
Do you have a Web site?
This is our website: http://www.mpntechsg.com
We have 14 years of experience now and have built long-term collaborations with more than 300 local Universities/Institutes/Startups/SMEs/MNCs, feel free to contact me if you want to know more.
Didn't found a prices in your website...
Right, the price varys largely because of customization, you can send me your requirements and we will give you a price range shortly
I interested in a simple PCB prototype making based on my gerber, like a JLCPcb or PCBWay. Nothing special - double layer, 100x100mm in size, 5-20 pcs
If nothing special, that would be about 110-180 us dollars, depends on the number from 5-20. Of course, if you order more, we can give you discount
JLCPcb make it for $2-$6 for 5 pieces + shipping cost
Oh that is because we provide more services to ensure the PCB works with high quality, even including layout redesign to make it more reasonable. If your design is perfect then of course you can just order them online.
