Record servo positions using PCA9685 and then replaying movement between those positions
Hi there, I am trying to control a robot arm using the following code.
I would like to be able to record 2 position and then loop the movement between them on pressing a button. It would normally react to my potentiometers, but as I would press a button, it would record one position, i would move the servos with potentiometers again and record second position. When i would press second button, the servos would move from first position to the other in a loop.
I would appreciate any ideas, thanks!
  PCA9685 PWM Servo Driver Example
  pca9685-servomotor-demo.ino
  Demonstrates use of 16 channel I2C PWM driver board with 4 servo motors
  Uses Adafruit PWM library
  Uses 4 potentiometers for input
  DroneBot Workshop 2018
  https://dronebotworkshop.com
// Include Wire Library for I2C Communications
#include <Wire.h>
// Include Adafruit PWM Library
#include <Adafruit_PWMServoDriver.h>
#define MIN_PULSE_WIDTH       650
#define MAX_PULSE_WIDTH       2350
#define FREQUENCY             50
Adafruit_PWMServoDriver pwm = Adafruit_PWMServoDriver();
// Define Potentiometer Inputs
int controlA = A0;
int controlB = A1;
int controlC = A2;
int controlD = A3;
// Define Motor Outputs on PCA9685 board
int motorA = 0;
int motorB = 4;
int motorC = 8;
int motorD = 12;
  pwm.begin();
  pwm.setPWMFreq(FREQUENCY);
void moveMotor(int controlIn, int motorOut)
  int pulse_wide, pulse_width, potVal;
  // Read values from potentiometer
  potVal = analogRead(controlIn);
  // Convert to pulse width
  pulse_wide = map(potVal, 0, 1023, MIN_PULSE_WIDTH, MAX_PULSE_WIDTH);
  pulse_width = int(float(pulse_wide) / 1000000 * FREQUENCY * 4096);
  //Control Motor
  pwm.setPWM(motorOut, 0, pulse_width);
  //Control Motor A
  moveMotor(controlA, motorA);
  //Control Motor B
  moveMotor(controlB, motorB);
  //Control Motor C
  moveMotor(controlC, motorC);
  //Control Motor D
  moveMotor(controlD, motorD);
It sounds like it is a display of some type. If so consider using the EEPROM to store those variables. Pots will work great but many do not tolerate to much rotation.
Thanks! I should have clarified I just needed to save the position for this current session. Anyway I made it work just by saving the pulse width in a variables and replaying those.
Great, have fun with it!
Dronebotworkshop used an SD card module as a datalogger to record and play back servo movement.
