I have a sealed bag of 5 smd atmega mcu's. The warning label on the outside of it states that after opening the bag, I must subject the units to reflow soldering within xx hours.
I would much like to start by reflow soldering just one of them, to check and test my design before committing to solder the rest... Is there some way I can store the rest of'em, maintaining their 'reflow solderability'?
Just thought of something. Would pre-baking the parts (w/o solder -- just heated in the oven) work to remove moisture and... uh.. "freshen them up" for use?
The reason for bakeout is to remove humidity from the epoxy so that the parts do not popcorn during reflow.
SirNickity:
Yes. Baking is common for parts which have been exposed to humidity. J-STD-033 has bakeout times and temperatures for various parts.
I sometimes wonder about that when I see Maplins picking out of plastic drawers.
Only problem I have had is solder ability though.
Out of curiosity were those chips all in the same metal coated pouch ?
SirNickity:
That's what digikey suggests on their moisture-sensitive device packaging. If the device has been exposed to too much humidity, they suggest baking at 120 - 130C for 48 hours.
JoshD:
This is not the case for all components. It depends on a number of factors.
Digikey is a distributor, not a device manufacturer. I'd stick to the info agreed by the people who make the parts, not sell them.
