Regarding The Faulty JKong nema 23 180kgcm torque motor and HSD57 hybrid servo motor drive
I am using the HSD57 Hybrid Servo drive to run my RMCS 2039 Hybrid servo motor Nema 23
this issue comes up where the red led in the drive is blinking 3 times after the pause just after starting the drive on no load
There is also issue with the planetary gear motor and another driver which is when i gave command for it to move by some angle its getting stuck and not moving i really dont know whats the issue i have almost tried everything
The message in the 3 Blink is found in the datasheet or technical manual.
Please create and post schematics.
We can not see your desk or computer screen. That means we can not helkp and a word salad is not very helpful.
Please read this sticky post at the top of the category and follow the advices in there. This will help us to help you.
Sorry i cannt attach anything else as i am a new user
But you can search for "2HSS57-N-XXHybrid Stepper ServoDriveManual" on google to find the document
I have checked the pcb of the driver and i have not found any problem with the board
And regarding motor getting stuck using another driver
i also cannt find the issue in that driver
I am using Arduino uno as a controller to send signal
#define STEP_PIN 8
#define DIR_PIN  9
#define EN_PIN   10
// Set according to driver microstep settings
#define STEPS_PER_REV 800
  pinMode(STEP_PIN, OUTPUT);
  pinMode(DIR_PIN, OUTPUT);
  pinMode(EN_PIN, OUTPUT);
  digitalWrite(EN_PIN, LOW);   // Enable driver
  // Clockwise
  digitalWrite(DIR_PIN, HIGH);
  for(int i = 0; i < STEPS_PER_REV; i++) {
    digitalWrite(STEP_PIN, HIGH);
    delayMicroseconds(500);
    digitalWrite(STEP_PIN, LOW);
  // Counter-clockwise
  digitalWrite(DIR_PIN, LOW);
Hi @whitescholar.
The restriction on attaching non-image files is lifted once you earn the "basic" trust level with the forum software. You are now at the "basic" trust level. So please try the attachment again now.
1.zip (9.4 MB)
3.zip (7.3 MB)
doc.pdf (1.5 MB)
This doc document contains device manual
and these zip files contains 3 videos
4.zip (5.9 MB)
