Relay 5v 8channel arduino uno
I have relay 5v 8 chennel i connect it with arduino and when i upload a code
// تعيين دبوس الريلاي
int relayPin = 7;
pinMode(relayPin, OUTPUT); // تعيين الدبوس كإخراج
digitalWrite(relayPin, HIGH); // تشغيل الريلاي
delay(2000); // انتظار لمدة 2 ثانية
digitalWrite(relayPin, LOW); // إيقاف الريلاي
So it function just one time and stay on the relay
Hello 38aredamohammed38
Post a connection and wiring diagram to see how we can help.
Hi @38aredamohammed38
welcome to the arduino-Forum.
Change your code in this was to make visible what your code is really doing
const byte relayPin      =  7;
const byte onBoardLEDPin = 13;
  Serial.println("setup-Start");
  pinMode(onBoardLEDPin, OUTPUT);
  Serial.println("Top of Loop");
  digitalWrite(relayPin, HIGH); // Turn on the relay
  digitalWrite(onBoardLEDPin, HIGH); // Turn on the relay
  Serial.println("relay and onboard LED HIGH");
  delay(2000); // Wait for 2 seconds
  digitalWrite(relayPin, LOW); // Turn off the relay
  digitalWrite(onBoardLEDPin, LOW); // Turn on the relay
  Serial.println("relay and onboard LED LOW");
With this code you have two things that make visible what your code is coding
The onboard-led of the arduino is witched ON/OFF whenever the relais is switched on off
In the serial monitor you see text
If you do not see the LED blink 2 seconds on two seconds off
it is very likely that you have a power-supply-problem or an EMV.
Any kind of microcontroller is NOT a power-supply.
Same applies to relais-boards
You should supply power to things like seros or relays this way
Here is a WOWKI-Simulation of an arduino Uno and a relay
try setting relayPin to LED_BUILTIN and see if the Arduino LED toggles on/off
I will di thank you stefan
Ok i trying to do this :heart_eyes:
pretty sure that the LED will blink. If the onboard-led does not blink you can conclude the problem is hardware related. Could be the relay not connected correctly or relay-current to high making the microcontroller hang or resetting.
The microcontroller resetting could be easily seen in my code-version.
Be repeated showing
"setup-Start" in the serial monitor
