Hi, everybody
I am dealing with a project that tries to control relays with buttons using Arduino.
there are 4 relays and 4 buttons when I press the start key 1. the relay is triggered 1. when the button is pressed 1. relay stops 2. 2. the relay is triggered when I press the button 2. relay stops 3. the relay is triggered 3. when I press the button 3. the relay stops at 4. the relay is triggered 4. and when I press the button, all the relays stop.3 if I press the repeat button, I want this cycle to repeat and stop 3 times, but 2. when I press the button, the loop exits the cases and does not start the if's inside the case.Do you want to help
pinMode(1, OUTPUT);
pinMode(10, INPUT);
pinMode(2, INPUT);
pinMode(4, INPUT);
pinMode(8, INPUT);
pinMode(3, OUTPUT);
pinMode(6, OUTPUT);
pinMode(9, OUTPUT);
pinMode(11, INPUT);
int count=0;
int count=digitalRead(10);// digitalRead(10) start butonu
if(digitalRead(12)==1) // digitalRead(12) 3 tekrar butonu
count=2;
switch(count){
case 1:
digitalWrite(1,HIGH);
delay(10);
digitalWrite(3,LOW);
delay(10);
digitalWrite(6,LOW);
delay(10);
digitalWrite(9,LOW);
delay(10);
if(digitalRead(2)==1)//1. swich
digitalWrite(1,LOW);
delay(10);
delay(10);
delay(10);
digitalWrite(3,HIGH);
delay(10);
else if(digitalRead(4)==1)// 2. swich
delay(10);
delay(10);
delay(10);
digitalWrite(9,HIGH);
delay(10);
else if(digitalRead(8)==1)// 3.swich
delay(10);
delay(10);
delay(10);
digitalWrite(6,HIGH);
delay(10);
else if(digitalRead(11)==1) //4.swich durdur
delay(10);
delay(10);
delay(10);
delay(10);
case 2:
delay(10);
delay(10);
delay(10);
delay(10);
if(digitalRead(2)==1 )//1. swich
delay(10);
delay(10);
delay(10);
delay(10);
delay(10);
delay(10);
delay(10);
delay(10);
delay(10);
delay(10);
delay(10);
delay(10);
else if(digitalRead(11)==1) //4.swich başa dön
delay(10);
delay(10);
delay(10);
delay(10);
else if(digitalRead(2)==1)//1. swich
delay(10);
delay(10);
delay(10);
delay(10);
delay(10);
delay(10);
delay(10);
delay(10);
delay(10);
delay(10);
delay(10);
delay(10);
delay(10);
delay(10);
delay(10);
delay(10);
delay(10);
delay(10);
delay(10);
delay(10);
delay(10);
delay(10);
delay(10);
delay(10);
delay(10);
delay(10);
delay(10);
delay(10);
delay(10);
delay(10);
delay(10);
delay(10);
