Hello. I am creating a remote control sailboat and I am using two nRF24L01. I am having difficulty with creating the two-way, simultaneous, communication. From one Arduino (Arduino A) two joysticks transmit signals to the other Arduino (Arduino B), one for the sail winch (using a dc motor with a motor shield), and one for the rudder (using an analog servo motor). From Arduino B to Arduino A, there is a compass that transmits the Azimuth value. Arduino A receives the Azimuth value and graphs it on a digital compass that projects onto an OLED monitor connected to Arduino A. Could someone please help with the error in the code, there is no response on either end? Thank you!
Arduino A:
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
#include <Wire.h>
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
#define OLED_RESET -1
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
#define LOGO_HEIGHT 16
#define LOGO_WIDTH 16
int last_dx, last_dy, dx, dy, angle;
const int centreX = 86;
const int centreY = 32;
const int radius = 30;
RF24 radio(9, 10); // CE, CSN ************
const byte addresses[][6] = {"00001", "00002"}; //Byte of array representing the address. This is the address where we will send the data. This should be same on the receiving side.*****
int x_key1 = A1;//check pin
int y_key1 = A0;//check pin
int x_pos1;
int y_pos1;
int x_key2 = A3;//check pin
int y_key2 = A2;//check pin
int x_pos2;
int y_pos2;
int data[2];
int boat[4];
int x_valreceived;
int y_valreceived;
if (!display.begin(SSD1306_SWITCHCAPVCC, 0x3C)) {
Serial.println(F("SSD1306 allocation failed"));
for (;;); // Don't proceed, loop forever
display.display();
delay(2000); // Pause for 2 seconds
pinMode (x_key1, INPUT);
pinMode (x_key2, INPUT);
display.clearDisplay();
display.setTextSize(1);
display.setTextColor(WHITE);
display.display();
last_dx = centreX;
last_dy = centreY;
radio.begin(); //Starting the Wireless communication
radio.openWritingPipe(addresses[0]);
radio.openReadingPipe(1, addresses[1]);
radio.setPALevel(RF24_PA_MIN);
delay(5);
radio.startListening();
if (radio.available()) {
while(radio.available()) {
radio.read(&boat, sizeof(boat));
Serial.print("X: ");
Serial.print(boat[0]);
Serial.print(" Y: ");
Serial.print(boat[1]);
Serial.print(" Z: ");
Serial.print(boat[2]);
Serial.print(" Azimuth: ");
Serial.print(boat[3]);
delay(5);
radio.stopListening();
data[0] = analogRead(x_key1);
data[1] = analogRead(x_key2);
Serial.print("data[0]:"); Serial.print(data[0]); Serial.print(" ");
Serial.print("data[1]:"); Serial.println(data[1]);
radio.write(&data, sizeof(data));
Draw_Compass();
angle = boat[3];
dx = (0.7 * radius * cos((angle - 90) * 3.14 / 180)) + centreX; // calculate X position for the screen coordinates - can be confusing!
dy = (0.7 * radius * sin((angle - 90) * 3.14 / 180)) + centreY; // calculate Y position for the screen coordinates - can be confusing!
draw_arrow(last_dx, last_dy, centreX, centreY, 2, 2, BLACK); // Erase last arrow
draw_arrow(dx, dy, centreX, centreY, 2, 2, WHITE); // Draw arrow in new position
last_dx = dx;
last_dy = dy;
display.setCursor(0, 48);
display.setTextSize(2);
display.print(angle);
display.print(char(247)); // and the degree symbol
display.display();
//delay(2000);
void display_direction(int x, int y, String dir) {
display.setCursor(x, y);
display.print(dir);
void draw_arrow(int x2, int y2, int x1, int y1, int alength, int awidth, int colour) {
float distance;
int dx, dy, x2o, y2o, x3, y3, x4, y4, k;
distance = sqrt(pow((x1 - x2), 2) + pow((y1 - y2), 2));
dx = x2 + (x1 - x2) * alength / distance;
dy = y2 + (y1 - y2) * alength / distance;
k = awidth / alength;
x2o = x2 - dx;
y2o = dy - y2;
x3 = y2o * k + dx;
y3 = x2o * k + dy;
x4 = dx - y2o * k;
y4 = dy - x2o * k;
display.drawLine(x1, y1, x2, y2, colour);
display.drawLine(x1, y1, dx, dy, colour);
display.drawLine(x3, y3, x4, y4, colour);
display.drawLine(x3, y3, x2, y2, colour);
display.drawLine(x2, y2, x4, y4, colour);
void Draw_Compass() {
int dxo, dyo, dxi, dyi;
display.drawCircle(centreX, centreY, radius, WHITE); // Draw compass circle
for (float i = 0; i < 360; i = i + 22.5) {
dxo = radius * cos(i * 3.14 / 180);
dyo = radius * sin(i * 3.14 / 180);
dxi = dxo * 0.95;
dyi = dyo * 0.95;
display.drawLine(dxi + centreX, dyi + centreY, dxo + centreX, dyo + centreY, WHITE);
display_direction((centreX - 2), (centreY - 24), "N");
display_direction((centreX - 2), (centreY + 17), "S");
display_direction((centreX + 19), (centreY - 3), "E");
display_direction((centreX - 23), (centreY - 3), "W");
Arduino B:
#include <Wire.h>
// QMC5883L Compass Library
#include <QMC5883LCompass.h>
QMC5883LCompass compass;
#include <Adafruit_MotorShield.h>
Adafruit_MotorShield AFMS = Adafruit_MotorShield();
Adafruit_DCMotor *myMotor = AFMS.getMotor(1);
//communication 2 way
//firstly download library https://github.com/nRF24/RF24
#include<Servo.h>
Servo Myservo1;
Servo Myservo2;
int x_val;
#include <SPI.h>
#include <RF24.h>
RF24 radio(9, 10); // CE, CSN //*****
const byte addresses[][6] = {"00001", "00002"}; //******
int x_pos1;
int x_pos2;
int position1;
int position2;
int servoVal2;
int servoVal1;
const int servo_pin1 = 3;
int data[2];
//int xval;
int boat[4];
int x, y, z, a, b;
char myArray[3];
Wire.begin();// Initialize I2C.
compass.init(); // Initialize the Compass.
//compass.setCalibration(-32768, 1915, -32768, 456, -591, 1085);
Myservo1.attach(servo_pin1);
// Myservo2.attach(servo_pin2);
Serial.println("test");
// myMotor->run(FORWARD);
// myMotor->setSpeed(150);
// // turn on motor
// myMotor->run(RELEASE);
radio.begin();
radio.openWritingPipe(addresses[1]);
radio.openReadingPipe(1, addresses[0]);
Serial.println("check");
delay(5);
compass.read();
boat[0] = compass.getX();
boat[1] = compass.getY();
boat[2] = compass.getZ();
boat[3] = compass.getAzimuth();
Serial.print("X: "); Serial.print(boat[0]); Serial.print(" ");
Serial.print(" Y: "); Serial.print(boat[1]); Serial.print(" ");
Serial.print(" Z: "); Serial.print(boat[2]); Serial.print(" ");
Serial.print(" Azimuth: "); Serial.println(boat[3]);
radio.write(&boat, sizeof(boat));
delay(5);
while (!radio.available());
radio.read(&data, sizeof(data));
data[0] = map(data[0], 0, 1023, 0, 180);
if (data[0] > 400 && data[0] < 600)
else {
Myservo1.write(data[0]) ;
data[1] = map(data[1], 0, 1023, -100, 100);
if (data[1] > 0) {
myMotor->setSpeed(data[1]);
if (data[1] < 0) {
myMotor->run(BACKWARD);
myMotor->setSpeed(data[1] * -1);
