I am tring to develop a simple project to measure short-range distances wirelessly. I have a Sharp IR distance meter and an Arduino Diecimila.
Im writing to request help in getting started. I am a true electronics & programming amateur but am motivated to learn. I've downloaded the programming interface and gone through some tutorials.
I'm currently stuck on how to connect the sensor with the board so I can practice programming. Where can I purchase a cable to connect the sensor with the board? Picture of the point of connection on the sensor is here:
Thanks for your consideration!
I have used the sharp GP2D-12 sensor in other projects and it was pretty simple. Pin 1 on the sensor goes to an analog in pin on the Arduino. Pin 2 on the sensor goes to ground on the Arduino. Pin 3 on the sensor goes to +5 v on the Arduino. Here is the data sheet http://www.robotstorehk.com/GP2D12.PDF
here is the data sheet for your sensor. http://www.totalrobots.com/media/pdf/R302-GP2Y0A700K0F.pdf
on page 5 it shows that you will use pin 1 to ground, pin 2 to voltage, and pin 4 to analog pin.
Have fun and let us know how the project turns out.
I just started using the same sensor some days ago. I can hook it up fine by using a Capacitor between + and -. I have a computer Power supply outputting 5V and a 10 Ohm 10W resistor to keep the 5V stable. I get stable reading from the sensor, but the readings are not making much sens.
I also have the Sharp GP2D120 and I found calculations I could use for that one on Acroname.
So what I get is.
Distance = (2914 / (V + 5)) - 1
However I am having hard time figuring out how to fill in the equation for the 700 Sensor.
The equation looks like this
Distance = (m' / (V + b')) - k
Look at the info here.
Would be really great full if there is anyone out there that could give me a hand.
Thanks for the help everyone! I am still confused on how to connect my Arduino to the Sharp sensor. Since I dont have a 5-pin connector that fits the housing on the sensor, should I just attach the individual wires to the individual pins and then solder the other ends to the Arduino? Or, do I need to look around for a 5pin connector that will fit with the housing on the sensor?
