Reset encoder count to zero
As I learn programming i usually take smaller sketches and link them together to build larger ones.
My current project uses PWM to control a motor and and encoder to count its position.
I cannot figure out how to zero the encoder count when i use the pushbutton.
thanks john
```cpp
#include <Encoder.h>
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
Encoder myEnc(2, 3);
int potpin = A0;  // analog pin used to connect the potentiometer
int val;          // variable to read the value from the analog pin
const int buttonPin = 8;  // the number of the pushbutton pin
const int ledPin = 13;    // the number of the LED pin
int buttonState = 0;  // variable for reading the pushbutton status
  myservo.attach(9);          // attaches the servo on pin 9 to the servo object
  pinMode(ledPin, OUTPUT);    // initialize the LED pin as an output:
  pinMode(buttonPin, INPUT);  // initialize the pushbutton pin as an input:
long oldPosition = -999;
  encoder();
  joystick();
  zerohome();
void encoder() {
  long newPosition = myEnc.read();
  if (newPosition != oldPosition) {
    oldPosition = newPosition;
    Serial.println(newPosition);
void joystick() {
  val = analogRead(potpin);            // reads the value of the potentiometer (value between 0 and 1023)
  val = map(val, 0, 1023, 0, 180);     // scale it for use with the servo (value between 0 and 180)
  myservo.write(val);                  // sets the servo position according to the scaled value
  //delay(15);                           // waits for the servo to get there
void zerohome() {
  // read the state of the pushbutton value:
  buttonState = digitalRead(buttonPin);
  // check if the pushbutton is pressed. If it is, the buttonState is HIGH:
  if (buttonState == HIGH) {
    // turn LED on:
    digitalWrite(ledPin, HIGH);
    // turn LED off:
    digitalWrite(ledPin, LOW);
myEnc.write( 0 ); ?
