I have a program that is to send a signal of 10 saved RFID codes to the transmitter.
The appropriate code will open the door.
The program only reads the first code.
How to make him read all the codes cyclically in turn?
No errors in the sketch.
Arduino Nano
#include <Arduino.h>
// Define the Arduino PIN
#define NTAGS 10
#define TAGLEN 10
#define coil_pin 2
char data[NTAGS][TAGLEN] = {
{'0','6','0','0','C','A','F','E','4','2',}, /* ID=1 /
{'0','B','5','7','8','1','4','6','0','1',}, / ID=2 /
{'0','4','0','0','7','1','1','3','3','5',}, / ID=3 /
{'0','0','1','3','5','5','3','9','0','4',}, / ID=4 /
{'5','6','5','A','1','1','4','0','B','E',}, / ID=5 /
{'3','6','5','A','3','9','8','1','4','9',}, / ID=6 /
{'0','6','0','0','C','A','F','E','4','2',}, / ID=7 /
{'0','6','0','0','C','A','F','E','4','2',}, / ID=8 /
{'0','6','0','0','C','A','F','E','4','2',}, / ID=9 /
{'0','6','0','0','C','A','F','E','4','2',}, / ID=10 */
int spoofed_card[64];
void build_content();
void spoofnow();
int HexToDec(char hexa);
void send_manchester(int clock_half, int signal);
pinMode(coil_pin, OUTPUT);
digitalWrite(coil_pin, LOW);
build_content();
Serial.println("Ready for spoofing");
for (int h = 0; h < 50; h++)
spoofnow();
Serial.println("Spoof done");
// Iterator for the ID wanted
int data_iterator = 0;
// Hex value of the ID
int raw_data;
// Initialize the first 9 bits to 1
for (int i = 0; i < 9; i++)
spoofed_card[i] = 1;
// Set the 5th bit as parity (calculated at the end)
// This loop writes each hex digit in bits
for (int a = 0; a < 10; a++)
raw_data = HexToDec(data[data_iterator][a]);
spoofed_card[(a * 5) + 9] = bitRead(raw_data, 3);
spoofed_card[(a * 5) + 10] = bitRead(raw_data, 2);
spoofed_card[(a * 5) + 11] = bitRead(raw_data, 1);
spoofed_card[(a * 5) + 12] = bitRead(raw_data, 0);
// CRC ROW
for (int r = 0; r < 10; r++)
int bit_set = 0;
// Calculate the number of 1s per row
for (int i = 0; i < 4; i++)
if (spoofed_card[(r * 5) + i + 9])
bit_set++;
// If the number of 1s is even, set parity to 1, else 0
spoofed_card[(5 * r) + 4 + 9] = (bit_set % 2 != 0) ? 1 : 0;
// CRC COLUMN
for (int c = 0; c < 4; c++)
int bit_set = 0;
// Calculate the number of 1s per column
for (int i = 0; i < 10; i++)
if (spoofed_card[c + (i * 5) + 9])
bit_set++;
spoofed_card[50 + 9 + c] = (bit_set % 2 != 0) ? 1 : 0;
// Last bit = stop bit = 0
spoofed_card[63] = 0;
// Function that converts Hexadecimal to Decimal
if (hexa >= '0' && hexa <= '9')
return hexa - '0';
if (hexa >= 'A' && hexa <= 'F')
return hexa - 'A' + 10;
if (hexa >= 'a' && hexa <= 'f')
return hexa - 'a' + 10;
// Handle invalid characters here, e.g., return an error code.
// You can also choose to ignore or skip invalid characters.
return -1; // Return an error code for invalid characters
void spoofnow()
for (int i = 0; i < 64; i++)
send_manchester(0, spoofed_card[i]);
delayMicroseconds(256);
send_manchester(1, spoofed_card[i]);
// XOR the clock and the signal
int man_encoded = clock_half ^ signal;
if (man_encoded)
digitalWrite(coil_pin, HIGH);
