Robust connection between BTS7960 and Arduino UNO
I’m driving a motor with the mentioned H bridge and I would like to create a robust/professional connection between the two. On the bridge side I was thinking of 2x4 DuPont connector (even though I will be using just six pins) and solder each cable to the female piece. On the Arduino side, I got a screw expansion shield so will just use the built in connectors from it. But I wonder how robust is this going to be for a DIY motion platform.
What Arduino are you using?
I’m sorry I didn’t clarify it first. I’m using Arduino Uno. I edited the post title.
That is why you restrain cable movement!
