I have ABB servo motor and servo driver.
Servo driver get impuls from electronic , but this electronic is damage.
Now i will build pulse generator with arduino.
I have this servo driver and this motor :
SErvo motor : ABB Brushless Servo motor I=15A U=310V Nn=3550min.
Servo driver
If someone has done something similar or if anyone knows how I can run the engine with Arduino
http://speedy.sh/metkn/DKH-E-0601...5001-Operating-Instructions.pdf
Hi, what is your electronics, programming, arduino, hardware experience?
Tom...... ![]()
TomGeorge:
Hi,Hi, what is your electronics, programming, arduino, hardware experience?
Tom......
Experience whit servo motor and driver is low but programing,electronic isn bad .
Have you any idea for me how can I run this motor whit arduino ?
Read the manual, it has 24V logic which is standard industrial level.
Any output from the arduino you will have to isolate, best with opto coupler, unless you need any analog levels.
Have you analysed the old controller to see how it was interfaced with the driver?
What is the application of this motor?
Tom.... ![]()
TomGeorge:
Have you analysed the old controller to see how it was interfaced with the driver?What is the application of this motor?
Tom....
What I can be read from the manual for the servo driver is to have SW1 + and sw1- on which leads to 10V voltage signal, so connected to my machine. However measurementI found that there have no supply. Drivers checked all right as far as the electronic elements, because of that I want to try to make a generator pulses with Arduino, to thereby start the engine.
This engine is used as a clutch to drive the film, and the other for cutting the foil.
The way in which they connect drivers is shown in the following figure
http://pokit.org/get/?4649f84537854e7e3ce1a589f22b6249.jpg
utilized pins on the driver
SW1+,SW1-,E,BTB,BTB
Explane pins
http://pokit.org/get/?ae4252555fbb772f2f8129c000b7fb00.jpg
t0r30rs:
Please don't use dodgy file sharing sites like this, they are a haven for malware.
Also when someone searches in the future and finds this thread, the link will
long since be broken - link to the manufacturer's site if at all possible.
