Running VS1053 WebRadioDemo, only getting static sounds during streaming
Problem: I am testing the Web Radio example provided with the baldram VS1053 library. Sketch compiles without error and runs fine but puts out only static over the attached earphones (I would attach a 10 sec audio sample but forum won't let me). The datastream seems to be fine, the decoder just does not seem to be decoding the data stream.
I've tried rewiring from scratch several times. I've tried some alternate CS/DCS/DREQ ports from other people's tested sketches. Same results... static during streaming (no discernible voice or music sounds, just scratchy, static-like sounds).
IDE: Arduino 1.8.16
Board: NODE32S
Upload Speed: 115,200
Hardware:
  1. HiLetgo ESP-WROOM-32 ESP32 ESP-32S Development Board 2.4GHz Dual-Mode WiFi + Bluetooth Dual Cores (pinout JPG attached)
  2. DollaTek VS1053 MP3 Module Development Board
Libraries:
  1. GitHub - baldram/ESP_VS1053_Library: A library for VS1053 MP3 Codec Breakout adapted for Espressif ESP8266 and ESP32 boards. (for MP3 decoder) v1.1.4
  2. GitHub - espressif/arduino-esp32: Arduino core for the ESP32 (for ESP32 board) v2.0.0
Pin Connections:
Pin Connections:
VS1053	ESP32(GPIO pin number)
XDCS	32
XCS 	5
DREQ	4
MOSI	23
GND 	GND
5V	    VIN
XRST	EN
SCK     18
MISO	19
ESP Board Pinout:
(upload://undCFwtVfM0jlpTmo2KDdJy7v5r.jpeg)
![HiLetgo ESP32 Pinout|375x500]
Sketch: WebRadioDemo (from Arduino IDW ESP32 VS1053 Examples from Custom Libraries)
  • Only modifications to Example code are to add my WiFi network credentials, and to
    set the streaming URL to a known good value of "radiostreaming.ert.gr:80/ert-kosmos"
Code:
  A simple stream handler to play web radio stations using ESP8266
  Copyright (C) 2018 Vince Gellár (github.com/vincegellar)
  Licensed under GNU GPL v3
  Wiring:
  | VS1053  | ESP8266 |  ESP32   |
  |   SCK   |   D5    |   IO18   |
  |   MISO  |   D6    |   IO19   |
  |   MOSI  |   D7    |   IO23   |
  |   XRST  |   RST   |   EN     |
  |   CS    |   D1    |   IO5    |
  |   DCS   |   D0    |   IO16   |
  |   DREQ  |   D3    |   IO4    |
  |   5V    |   5V    |   5V     |
  |   GND   |   GND   |   GND    |
  Dependencies:
  -VS1053 library by baldram (https://github.com/baldram/ESP_VS1053_Library)
  -ESP8266Wifi/WiFi
  To run this example define the platformio.ini as below.
  [env:nodemcuv2]
  platform = espressif8266
  board = nodemcuv2
  framework = arduino
  build_flags = -D PIO_FRAMEWORK_ARDUINO_LWIP2_HIGHER_BANDWIDTH
  lib_deps =
    ESP_VS1053_Library
  [env:esp32dev]
  platform = espressif32
  board = esp32dev
  framework = arduino
  lib_deps =
    ESP_VS1053_Library
  Instructions:
  -Build the hardware
    (please find an additional description and Fritzing's schematic here:
     https://github.com/vincegellar/Simple-Radio-Node#wiring)
  -Set the station in this file
  -Upload the program
  IDE Settings (Tools):
  -IwIP Variant: v1.4 Higher Bandwidth
  -CPU Frequency: 160Hz
#include <VS1053.h>
#ifdef ARDUINO_ARCH_ESP8266
#include <ESP8266WiFi.h>
#define VS1053_CS     D1
#define VS1053_DCS    D0
#define VS1053_DREQ   D3
#endif
#ifdef ARDUINO_ARCH_ESP32
#include <WiFi.h>
#define VS1053_CS     5
#define VS1053_DCS    16
#define VS1053_DREQ   4
#endif
// Default volume
#define VOLUME  80
VS1053 player(VS1053_CS, VS1053_DCS, VS1053_DREQ);
WiFiClient client;
// WiFi settings example, substitute your own
const char *ssid = "<your ssid goes here>";
const char *password = "<ssid password goes here>";
//  http://comet.shoutca.st:8563/1
const char *host = "radiostreaming.ert.gr";  // "comet.shoutca.st";
const char *path = "/ert-kosmos";            // "/1";
int httpPort = 80;                           // 8563;
// The buffer size 64 seems to be optimal. At 32 and 128 the sound might be brassy.
uint8_t mp3buff[64];
  // Wait for VS1053 and PAM8403 to power up
  // otherwise the system might not start up correctly
  delay(3000);
  // This can be set in the IDE no need for ext library
  // system_update_cpu_freq(160);
  Serial.println("\n\nSimple Radio Node WiFi Radio");
  SPI.begin();
  player.begin();
  if (player.getChipVersion() == 4) { // Only perform an update if we really are using a VS1053, not. eg. VS1003
    player.loadDefaultVs1053Patches();
  player.switchToMp3Mode();
  player.setVolume(VOLUME);
  Serial.print("Connecting to SSID ");
  Serial.println(ssid);
  WiFi.begin(ssid, password);
    Serial.print(".");
  Serial.println("WiFi connected");
  Serial.println("IP address: ");
  Serial.print("connecting to ");
  Serial.println(host);
  if (!client.connect(host, httpPort)) {
    Serial.println("Connection failed");
    return;
  Serial.print("Requesting stream: ");
  Serial.println(path);
  client.print(String("GET ") + path + " HTTP/1.1\r\n" +
               "Host: " + host + "\r\n" +
               "Connection: close\r\n\r\n");
  if (!client.connected()) {
    Serial.println("Reconnecting...");
    if (client.connect(host, httpPort)) {
  if (client.available() > 0) {
    uint8_t bytesread = client.read(mp3buff, 64);
    player.playChunk(mp3buff, bytesread);
Serial Monitor Output:
ets Jun  8 2016 00:22:57
rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:1
load:0x3fff0030,len:1100
ho 0 tail 12 room 4
load:0x40078000,len:12308
load:0x40080400,len:3076
entry 0x400805ec
Connecting to SSID xxxxx-xxx
.....WiFi connected
IP address:
192.168.1.161
connecting to radiostreaming.ert.gr
Requesting stream: /ert-kosmos
I'm going to close this item, since I have discovered the problem.
The breadboard I was using was faulty. When I rewired the circuit pin-to-pin between the MP3 Decoder and the ESP32 microcontroller everything worked.
