I have a custom board using a samd21g18A running the bootloader from the adafruit feather M0 express (i ripped that chip off and put it onto my board so i wouldn't have to burn a bootloader).
My design uses two SPI peripherals. For now lets just focus on one. Following the adafruit tutorial i did this:
#include <SPI.h>
#include "wiring_private.h" // pinPeripheral() function
//Internal spi setup. This controls the ADC and onboard storage
#define internalSPImosi 4
#define internalSPImiso 2
#define internalSPIsck 3
#define flashCS PIN_PA13
#define adcCS 12
//spi config
#define speedMaximum 1000000
#define dataOrder MSBFIRST
#define dataMode SPI_MODE0
//serial config
#define Serial SerialUSB
SPIClassSAMD INTERNALSPI (&sercom2, internalSPImiso, internalSPIsck, internalSPImosi, SPI_PAD_0_SCK_3, SERCOM_RX_PAD_1);
//serial speed is set to maximum 2,000,000 baud
Serial.begin(2000000);
// Initilize SPI
INTERNALSPI.begin();
// Assign pins for internal SPI to SERCOM functionality
pinPeripheral(internalSPImosi, PIO_SERCOM);
pinPeripheral(internalSPImiso, PIO_SERCOM);
pinPeripheral(internalSPIsck, PIO_SERCOM);
INTERNALSPI.beginTransaction(SPISettings(speedMaximum, dataOrder, dataMode));
digitalWrite (adcCS, LOW);
INTERNALSPI.transfer(0x86);
digitalWrite (adcCS, HIGH);
INTERNALSPI.endTransaction();
the main code does nothing useful other than just spit out a bunch of data fast. Nothing shows up on the oscilloscope. as a sanity check, i actually probed the USB interface doing a rapid serial print, which probed fine, so its not a probing issue, at least i don't think
the code defines show which pins i'm using for serial, which according to the datasheet should work.
my question is what am i doing wrong, and how might i change my code to correctly enable the serial peripheral interface i want? if i forgot information that's needed, as i'm sure i have, please let me know.
I changed this. Now it outputs something. However its still not right. MOSI and SCK both output the same thing (MOSI data). Miso has nothing, as there is no device. SCK has significantly smaller amplitude than MOSI, but is definitely outputting something, and is definitely the same signal as MOSI. seems I am getting closer to a solution I hope.
pinPeripheral(internalSPImosi, PIO_SERCOM_ALT);
tried following this tutorial SPIOnD21 and came up with the following code:
#include <SPI.h>
#define internalSPImosi 4 //TX sercom
#define internalSPImiso 2 //RX sercom alt
#define internalSPIsck 3 //sercom alt
#define adcCS 12
//spi config
//serial config
SPIClassSAMD INTERNALSPI (&sercom2, internalSPImiso, internalSPIsck, internalSPImosi, SPI_PAD_0_SCK_1, SERCOM_RX_PAD_0);
pinMode(internalSPImosi, OUTPUT);
pinMode(internalSPImiso, INPUT);
pinMode(internalSPIsck, OUTPUT);
pinMode(flashCS, OUTPUT);
pinMode(adcCS, OUTPUT);
// Initilize SPI
pinPeripheral(internalSPImiso, PIO_SERCOM_ALT);
pinPeripheral(internalSPIsck, PIO_SERCOM_ALT);
Still doesnt work, but the behavior of the sck and mosi pins are now switched?! SCK outputs SCK data, MOSI outputs SCK data at significantly smaller amplitude. I am dumbfounded as to what the issue is. Reading other forums people are having very similar issue. Anyone know what my issue may be? Thanks.
