I guess I need to replace some components of my Arduino Bracchio, as some of the screw joints have worn out so much that they do no longer maintain stability of the whole Bracchio, causing the arm links to droop limply.
This concerns especially the screw joints that maintain the stability of the servo motors M3 and M4. For some reason I cannot upload a file in this post, so I cannot show a picture.
Having dismounted the arm piece I can see that the screw joint is directly connected to the servo motor, which is why I guess that the only possible way would be to buy now servo motors.
What would you suggest?
However, we can do without the pictures, they are not that revelatory anyway, I guess. My description should suffice to answer this question. The screw joints are screwed for the servo motors M3 and M4, and they are attached to these servo motors. That is, a slight burden on any of these screw joints causes the arm link to droop. Now I am simply looking for a cheap but satisfactory option to make good the damage.
