Trying to get my new SD card going
No luck
I get fail using arduino SD/Cardinfo sketch at command
card.init(SPI_HALF_SPEED, chipSelect)
Browsing the forum only trick I found was this
Not sure if it's valid for my Arduino Uno ...
pinMode(10, OUTPUT);
digitalWrite(10, HIGH);
Also tried using chipSelect = 10 or 4 as CS on SD card
Following instructions from Adafruit
The card is workin fine on my desktop SD box. FAT32 format .... but shouldn't be format problem at all I reckon .... failing at card.init ??
Any idea how I can go forward with trouble shoot ?
Or is it a DOA I got .... ?
Not really so much code before fail ....
SD card test
This example shows how use the utility libraries on which the'
SD library is based in order to get info about your SD card.
Very useful for testing a card when you're not sure whether its working or not.
The circuit:
* SD card attached to SPI bus as follows:
** MOSI - pin 11 on Arduino Uno/Duemilanove/Diecimila
** MISO - pin 12 on Arduino Uno/Duemilanove/Diecimila
** CLK - pin 13 on Arduino Uno/Duemilanove/Diecimila
** CS - depends on your SD card shield or module.
Pin 4 used here for consistency with other Arduino examples
created 28 Mar 2011
by Limor Fried
modified 9 Apr 2012
by Tom Igoe
// include the SD library:
#include <SPI.h>
#include <SD.h>
// set up variables using the SD utility library functions:
Sd2Card card;
SdVolume volume;
SdFile root;
// change this to match your SD shield or module;
// Arduino Ethernet shield: pin 4
// Adafruit SD shields and modules: pin 10
// Sparkfun SD shield: pin 8
const int chipSelect = 10;
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
Serial.print("\nInitializing SD card...");
// we'll use the initialization code from the utility libraries
// since we're just testing if the card is working!
if (!card.init(SPI_HALF_SPEED, chipSelect)) {
Serial.println("initialization failed. Things to check:");
Serial.println("* is a card inserted?");
Serial.println("* is your wiring correct?");
Serial.println("* did you change the chipSelect pin to match your shield or module?");
return;
Serial.println("Wiring is correct and a card is present.");
BR Bosse
