SD card with TFT_eSPI
I'm making a bike speedometer using a ESP32 DEV board, a NEO6M GPS module and a 3.5 ILI9488 TFT display with touch. All of that works fine, now I'm trying to add a SD card so I can log the latitude and longitude as I ride, this is not working fine.
I'm trying to test it using the example "ESP32_SDcard_jpeg" from the TFT_eSPI/Generic example folder. I've tried both the SD card that is on the display and a separate SD module, with both of them I get the error "Card Mount Failed" If I can't get this to work there's no need to add it to my speedometer code. I have seen in a couple of places that the default for the chip select for the SD card is GPIO 5 but I don't see that anywhere in the "user_setup.h" file, so not sure if there is a place to uncomment that, maybe why I can't get it to work.
Here is how I have everything wired, may not be the best way to show it, hopefully it helps
ESP32		TFT		        TFT		GPS		SD
GPIO		Display		    Touch
5								            CS
15		    CS
16						             TX
17						             RX
18		    SCK		        T_Clk			SCK
19		    MISO	     	T_DO			MISO
21				            T_CS
23		    MOSI	     	T_DIN			MOSI
27		    DC/RS
+5V		  Vcc & LED			         Vcc	Vcc
GND	  	    GND				         GND	GND
Here is the example I'm using
// This sketch if for an ESP32, it draws Jpeg images pulled from an SD Card
// onto the TFT.
// As well as the TFT_eSPI library you will need the JPEG Decoder library.
// A copy can be downloaded here, it is based on the library by Makoto Kurauchi.
// https://github.com/Bodmer/JPEGDecoder
// Images on SD Card must be put in the root folder (top level) to be found
// Use the SD library examples to verify your SD Card interface works!
// The example images used to test this sketch can be found in the library
// JPEGDecoder/extras folder
#include <SPI.h>
#include <FS.h>
#include <SD.h>
#include <TFT_eSPI.h>
TFT_eSPI tft = TFT_eSPI();
// JPEG decoder library
#include <JPEGDecoder.h>
// Setup
  // Set all chip selects high to avoid bus contention during initialisation of each peripheral
  digitalWrite(22, HIGH); // Touch controller chip select (if used)
  digitalWrite(15, HIGH); // TFT screen chip select
  digitalWrite( 5, HIGH); // SD card chips select, must use GPIO 5 (ESP32 SS)
  tft.begin();
  if (!SD.begin()) {
    Serial.println("Card Mount Failed");
    return;
  uint8_t cardType = SD.cardType();
  if (cardType == CARD_NONE) {
    Serial.println("No SD card attached");
    return;
  Serial.print("SD Card Type: ");
  if (cardType == CARD_MMC) {
    Serial.println("MMC");
  } else if (cardType == CARD_SD) {
    Serial.println("SDSC");
  } else if (cardType == CARD_SDHC) {
    Serial.println("SDHC");
    Serial.println("UNKNOWN");
  uint64_t cardSize = SD.cardSize() / (1024 * 1024);
  Serial.printf("SD Card Size: %lluMB\n", cardSize);
  Serial.println("initialisation done.");
// Main loop
  tft.setRotation(2);  // portrait
  tft.fillScreen(random(0xFFFF));
  // The image is 300 x 300 pixels so we do some sums to position image in the middle of the screen!
  // Doing this by reading the image width and height from the jpeg info is left as an exercise!
  int x = (tft.width()  - 300) / 2 - 1;
  int y = (tft.height() - 300) / 2 - 1;
  drawSdJpeg("/EagleEye.jpg", x, y);     // This draws a jpeg pulled off the SD Card
  delay(2000);
  drawSdJpeg("/Baboon40.jpg", 0, 0);     // This draws a jpeg pulled off the SD Card
  delay(2000);
  drawSdJpeg("/lena20k.jpg", 0, 0);     // This draws a jpeg pulled off the SD Card
  delay(2000);
  tft.setRotation(1);  // landscape
  drawSdJpeg("/Mouse480.jpg", 0, 0);     // This draws a jpeg pulled off the SD Card
  delay(2000);
  while(1); // Wait here
// Draw a JPEG on the TFT pulled from SD Card
// xpos, ypos is top left corner of plotted image
void drawSdJpeg(const char *filename, int xpos, int ypos) {
  // Open the named file (the Jpeg decoder library will close it)
  File jpegFile = SD.open( filename, FILE_READ);  // or, file handle reference for SD library
  if ( !jpegFile ) {
    Serial.print("ERROR: File \""); Serial.print(filename); Serial.println ("\" not found!");
    return;
  Serial.println("===========================");
  Serial.print("Drawing file: "); Serial.println(filename);
  // Use one of the following methods to initialise the decoder:
  bool decoded = JpegDec.decodeSdFile(jpegFile);  // Pass the SD file handle to the decoder,
  //bool decoded = JpegDec.decodeSdFile(filename);  // or pass the filename (String or character array)
  if (decoded) {
    // print information about the image to the serial port
    jpegInfo();
    // render the image onto the screen at given coordinates
    jpegRender(xpos, ypos);
  else {
    Serial.println("Jpeg file format not supported!");
// Draw a JPEG on the TFT, images will be cropped on the right/bottom sides if they do not fit
// This function assumes xpos,ypos is a valid screen coordinate. For convenience images that do not
// fit totally on the screen are cropped to the nearest MCU size and may leave right/bottom borders.
void jpegRender(int xpos, int ypos) {
  //jpegInfo(); // Print information from the JPEG file (could comment this line out)
  uint16_t *pImg;
  uint16_t mcu_w = JpegDec.MCUWidth;
  uint16_t mcu_h = JpegDec.MCUHeight;
  uint32_t max_x = JpegDec.width;
  uint32_t max_y = JpegDec.height;
  bool swapBytes = tft.getSwapBytes();
  tft.setSwapBytes(true);
  // Jpeg images are draw as a set of image block (tiles) called Minimum Coding Units (MCUs)
  // Typically these MCUs are 16x16 pixel blocks
  // Determine the width and height of the right and bottom edge image blocks
  uint32_t min_w = jpg_min(mcu_w, max_x % mcu_w);
  uint32_t min_h = jpg_min(mcu_h, max_y % mcu_h);
  // save the current image block size
  uint32_t win_w = mcu_w;
  uint32_t win_h = mcu_h;
  // record the current time so we can measure how long it takes to draw an image
  uint32_t drawTime = millis();
  // save the coordinate of the right and bottom edges to assist image cropping
  // to the screen size
  max_x += xpos;
  max_y += ypos;
  // Fetch data from the file, decode and display
  while (JpegDec.read()) {    // While there is more data in the file
    pImg = JpegDec.pImage ;   // Decode a MCU (Minimum Coding Unit, typically a 8x8 or 16x16 pixel block)
    // Calculate coordinates of top left corner of current MCU
    int mcu_x = JpegDec.MCUx * mcu_w + xpos;
    int mcu_y = JpegDec.MCUy * mcu_h + ypos;
    // check if the image block size needs to be changed for the right edge
    if (mcu_x + mcu_w <= max_x) win_w = mcu_w;
    else win_w = min_w;
    // check if the image block size needs to be changed for the bottom edge
    if (mcu_y + mcu_h <= max_y) win_h = mcu_h;
    else win_h = min_h;
    // copy pixels into a contiguous block
    if (win_w != mcu_w)
      uint16_t *cImg;
      int p = 0;
      cImg = pImg + win_w;
      for (int h = 1; h < win_h; h++)
        p += mcu_w;
        for (int w = 0; w < win_w; w++)
          *cImg = *(pImg + w + p);
          cImg++;
    // calculate how many pixels must be drawn
    uint32_t mcu_pixels = win_w * win_h;
    // draw image MCU block only if it will fit on the screen
    if (( mcu_x + win_w ) <= tft.width() && ( mcu_y + win_h ) <= tft.height())
      tft.pushImage(mcu_x, mcu_y, win_w, win_h, pImg);
    else if ( (mcu_y + win_h) >= tft.height())
      JpegDec.abort(); // Image has run off bottom of screen so abort decoding
  tft.setSwapBytes(swapBytes);
  showTime(millis() - drawTime); // These lines are for sketch testing only
// Print image information to the serial port (optional)
// JpegDec.decodeFile(...) or JpegDec.decodeArray(...) must be called before this info is available!
void jpegInfo() {
  // Print information extracted from the JPEG file
  Serial.println("JPEG image info");
  Serial.println("===============");
  Serial.print("Width      :");
  Serial.println(JpegDec.width);
  Serial.print("Height     :");
  Serial.println(JpegDec.height);
  Serial.print("Components :");
  Serial.println(JpegDec.comps);
  Serial.print("MCU / row  :");
  Serial.println(JpegDec.MCUSPerRow);
  Serial.print("MCU / col  :");
  Serial.println(JpegDec.MCUSPerCol);
  Serial.print("Scan type  :");
  Serial.println(JpegDec.scanType);
  Serial.print("MCU width  :");
  Serial.println(JpegDec.MCUWidth);
  Serial.print("MCU height :");
  Serial.println(JpegDec.MCUHeight);
  Serial.println("");
// Show the execution time (optional)
// WARNING: for UNO/AVR legacy reasons printing text to the screen with the Mega might not work for
// sketch sizes greater than ~70KBytes because 16 bit address pointers are used in some libraries.
// The Due will work fine with the HX8357_Due library.
void showTime(uint32_t msTime) {
  //tft.setCursor(0, 0);
  //tft.setTextFont(1);
  //tft.setTextSize(2);
  //tft.setTextColor(TFT_WHITE, TFT_BLACK);
  //tft.print(F(" JPEG drawn in "));
  //tft.print(msTime);
  //tft.println(F(" ms "));
  Serial.print(F(" JPEG drawn in "));
  Serial.print(msTime);
  Serial.println(F(" ms "));
I've attached my user_setup.h file as well.
User_Setup.h (16.4 KB)
Thanks for all comments and suggestions
John
GPIO 5 is not the same as Pin 5, boards may route GPIO numbers to other pin numbers. You would get better help if you linked to the exact hardware (and a wiring schematic).
EDIT: Try to change if (!SD.begin()) ... to if (!SD.begin(5)) ...
@Danois90 thanks for the info but that did not help. I did notice while making that change that in the section above where I set all the chip selects high that I had the wrong number for the touch screen chip select, should be 21, I made that change as well.
Good point about the pin numbers but all the other pins I've used have worked as to what I have on the board. I did try making a schematic using Fritzing but I couldn't find the icon for the display, I did Google for one but also didn't find one which I thought was surprising.
I've attached the pinout picture I've been using.
Thanks again for your suggestion
Did you try SD.begin(CS_pin_number)? How is everything powered?
First I added the define statement, #define cs_pin_number 5, then modified the SD begin as if (!SD.begin(cs_pin_number)), I get the same results.
Right now I am powering everything with the USB cable from my laptop into the ESP32 and a jumper from the 5V pin on the ESP32 to the positive rail on the breadboard, all the other devices connect to the rail.
Thanks again
Dunno the problem, I would try to remove / comment out the following three lines from setup():
Since the chip select is handled by the libraries when required.
I put those statements in as a suggestion from a YouTube video I watched that was doing basically the same project as I was, seemed like a good idea to initialize everything to a base position then let the code handle the chip selects.
I commented those out and still doesn't work. I think I'll move the ESP and the SD module to another breadboard so that's all that's connected just to see if there is some kind of interaction with the display or touch screen. I'll do that later and let you know how it does.
Thanks for sticking with this
When you set all CS pins to high, all SPI devices will think they are spoken to when you address one of them and that could be a problem.
Good luck and make sure the SD-card is FAT32 formatted!
@Danois90, I have made some progress and I have 2 problems. one was the size of the SD card the other is I believe I can not have multiple devices on the SDA pins.
I removed the ESP32 from the breadboard and connected just the SD module to it on another breadboard. If I use a 8Gb SD card it works, if I use a 32Gb, the one I had started with, it does not. I reformatted it to make sure it was FAT32, still didn't work. So it's either a limitation on the SD module, TFT_eSPI library or the ESP32. Not sure.
I then connected the GPS module, that uses serial communications. I was able to open the SD card and read the GPS.
If I reconnect the ESP to the TFT and the GPS but not the SD card, that also works, I had to comment out the !SD.begin statement but that will read and display the GPS.
I went back into the "user_setup.h" file and found this statement next to the driver I have configured for the TFT, "#define ILI9488_DRIVER // WARNING: Do not connect ILI9488 display SDO to MISO if other devices share the SPI bus (TFT SDO does NOT tristate when CS is high)" So I believe that means I can't have both the TFT and the SD module on the same bus. Also wish I had noticed that awhile ago.
I'll have to try a different display
Thanks for your help and a again sorry I didn't see that notice earlier.
John
With ESP32, it is possible to have multiple SPI busses and that could be a solution for you.
Excellent, looks like I have some homework to do.
Thanks
