SD error
I'm trying to write the code to program an SD card on a data logging shield. So I can't figure out how to fix / what this error means.
RTC.ino: In function 'void loop()':
RTC:109: error: 'class DateTime' has no member named 'get'
I'd appreciate any and all advice!
Some simple advice:
"Post the code!!!!!!"
#include <LiquidCrystal.h>
#include "SD.h"
#include <Wire.h>
#include "RTClib.h"
#define LOG_INTERVAL 1000 // mills between entries
#define ECHO_TO_SERIAL 1 // echo data to serial port
#define WAIT_TO_START 0 // Wait for serial input in setup()
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
const int sensorPin = A0;
int sensorValue;
float Res = 10.0;
RTC_DS1307 RTC; // define the Real Time Clock object
// for the data logging shield, we use digital pin 10 for the SD cs line
const int chipSelect = 10;
// the logging file
File logfile;
void error(char *str)
Serial.print("error: ");
Serial.println(str);
while(1);
void setup(){
lcd.begin(16,2);
lcd.clear();
Serial.print("Initializing SD card...");
pinMode(10, OUTPUT);
// see if the card is present and can be initialized:
if (!SD.begin(chipSelect)) {
Serial.println("Card failed, or not present");
return;
Serial.println("card initialized.");
// create a new file
char filename[] = "LOGGER00.CSV";
for (uint8_t i = 0; i < 100; i++) {
filename[6] = i/10 + '0';
filename[7] = i%10 + '0';
if (! SD.exists(filename)) {
// only open a new file if it doesn't exist
logfile = SD.open(filename, FILE_WRITE);
break; // leave the loop!
if (! logfile) {
error("couldnt create file");
Serial.print("Logging to: ");
Serial.println(filename);
Wire.begin();
if (!RTC.begin()) {
logfile.println("RTC failed");
#if ECHO_TO_SERIAL
Serial.println("RTC failed");
#endif //ECHO_TO_SERIAL
logfile.println("millis,time,light");
ECHO_TO_SERIAL;
Serial.println("millis,time,light");
ECHO_TO_SERIAL; // attempt to write out the header to the file
void loop(){
sensorValue = analogRead(sensorPin);
float Vout = sensorValue*0.0048828125;
delay(100);
Serial.print("Voltages");
Serial.print(Vout);
lcd.print("V\t");
lcd.print(sensorValue);
delay(200);{
if(Serial.available()){
delay(100);
lcd.clear();
DateTime now;
// delay for the amount of time we want between readings
delay((LOG_INTERVAL -1) - (millis() % LOG_INTERVAL));
// log milliseconds since starting
uint32_t m = millis();
logfile.print(m); // milliseconds since start
logfile.print(", ");
#if ECHO_TO_SERIAL
Serial.print(m); // milliseconds since start
Serial.print(", ");
#endif
// fetch the time
now = RTC.now();
// log time
logfile.print(now.get()); // seconds since 2000
logfile.print(now.year(), DEC);
logfile.print("/");
logfile.print(now.month(), DEC);
logfile.print("/");
logfile.print(now.day(), DEC);
logfile.print(" ");
logfile.print(now.hour(), DEC);
logfile.print(":");
logfile.print(now.minute(), DEC);
logfile.print(":");
logfile.print(now.second(), DEC);
#if ECHO_TO_SERIAL
Serial.print(now.get()); // seconds since 2000
Serial.print(", ");
Serial.print(now.year(), DEC);
Serial.print("/");
Serial.print(now.month(), DEC);
Serial.print("/");
Serial.print(now.day(), DEC);
Serial.print(" ");
Serial.print(now.hour(), DEC);
Serial.print(":");
Serial.print(now.minute(), DEC);
Serial.print(":");
Serial.print(now.second(), DEC);
int photocellReading = analogRead(photocellPin);
delay(10);
// converting that reading to voltage, for 3.3v arduino use 3.3
float voltage = tempReading * 5.0 / 1024;
logfile.print(photocellReading);
#if ECHO_TO_SERIAL
Serial.print(", ");
Serial.print(photocellReading);
Here's an idea, have a look at the DateTime class, and see if you can find a function called get( ). It is either there, or it isn't.
What to look at, after that, depends on the answer to that question.
Is this the ONLY compilation error that you get ?
So what is the Datetime class?
And no I get a few errors, but the first two are about the 'get'
Its using the Adafruit RTClib.h whose datetime class doesn't have a get() method,
from the comment the method secondstime() is intended. Perhaps an old version
of the library had a different method name?
PS
 code tags for code please
