Searching for a small Server for NodeMCU without using ESP8266WebServer.h
Hey folks,
I'm using a NodeMCU v3 with some stuff connected to it.
Long story short: I have to define my SD-reader-pins freely.
The only library I've found to be able to is mySD. (GitHub - nhatuan84/esp32-micro-sdcard)
But: It is outdated and also will it redefine File, so I have to use #define FS_NO_GLOBALS first.
But this makes the ESP8266 Webserver unusable.
What I need is a simple server to download one single file from this NodeMCU's SD.
It's name is speed.txt and at the end of the day there are only two things needed:
Get this file from the SD via Wifi (What I use for NTP anyways) and, which is a second thing I'd like to do, empty the same file. (with whatever command).
However, the downloading is my #1 priority.
So can anyone suggest me a webserver / code that is small and easy for transferring this file?
Actually my talents in C are very limited :wink: (Any examples or whatever are highly appreciated!)
Regards,
Maeffjus
Here is my code, for your information:
#include <NTPClient.h>
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27,20,4);  // set the LCD address to 0x27 for a 16 chars and 2 line display
#include <ESP8266WiFi.h>
#include <WiFiUdp.h>
#include <mySD.h>
#include <FS.h>
#include <WiFiClient.h>
#include <time.h>
// VARIABLES
File root;
const byte numChars = 32;
char receivedChars[numChars];   // an array to store the received data
boolean newData = false;
float laenge;
String Geschwindigkeit_lang;
float Geschwindigkeit;
float max_geschwindigkeit;
String Richtung;
boolean ankommend;
unsigned long previousMillis = 0;
unsigned long currentMillis;
unsigned long old_speed_Millis;
const long speed_interval = 30000;
float totalmax;
float speed[200];
WiFiUDP ntpUDP;
NTPClient timeClient(ntpUDP, "europe.pool.ntp.org", 7200, 60000);
  Serial.swap();
  Wire.begin(D2, D1); /* join i2c bus with SDA=D1 and SCL=D2 of NodeMCU */
  WiFi.begin("NETWORK", "PASSWORD");
  lcd.init();
  lcd.backlight();
  lcd.home();
  lcd.clear();
  lcd.setCursor ( 0, 3 );
  lcd.print(WiFi.localIP());
  delay (5000);
  pinMode(D6, OUTPUT); //SDCard CS-Pin
  SD.begin(D6, D4, 3, D5);
    recvWithEndMarker();
    umrechnung();
    maximum();
    showNewData();
void recvWithEndMarker() {
    static byte ndx = 0;
    char endMarker = '\n';
    char rc;
    while (Serial.available() > 0 && newData == false) {
        rc = Serial.read();
        if (rc != endMarker) {
            receivedChars[ndx] = rc;
            ndx++;
            if (ndx >= numChars) {
                ndx = numChars - 1;
        else {
            receivedChars[ndx] = '\0'; // terminate the string
            ndx = 0;
            newData = true;
void showNewData() {
    if (newData == true) {
       //Serial.println(receivedChars);
       lcd.clear();
       lcd.setCursor ( 0, 0 );        // go to the next line
       lcd.print(max_geschwindigkeit);
       lcd.setCursor ( 0, 1 );
       lcd.print(Richtung);
       lcd.setCursor ( 0, 2 );
       lcd.print(ankommend);
       lcd.print("  ");
       lcd.print(totalmax);
       lcd.print("km/h");
       lcd.print(timeClient.getFormattedDate());
       lcd.print(" ");
       //lcd.setCursor ( 11, 3 );
       lcd.print(timeClient.getFormattedTime());
       lcd.print(" ");
       //lcd.setCursor ( 17, 3 );
       newData = false;
void umrechnung() {
    Geschwindigkeit_lang = receivedChars;
    Geschwindigkeit_lang.remove(0, 12);
    Geschwindigkeit_lang.remove(5);
    Geschwindigkeit = Geschwindigkeit_lang.toFloat();
    Richtung = receivedChars;
    Richtung.remove(0, 19);
    Richtung.remove(1);
    if (Richtung == "+"){
      ankommend = false;}
    if (Richtung == "-"){
      ankommend = true;}
void maximum(){
  currentMillis = millis();
 if ((newData == true)&(currentMillis - old_speed_Millis > speed_interval)){
  old_speed_Millis = currentMillis;
  if (max_geschwindigkeit >10){
  sdwrite();
  max_geschwindigkeit = 0;
  return;
 if ((newData == true)&(currentMillis - old_speed_Millis <= speed_interval)){
  if (Geschwindigkeit > max_geschwindigkeit){
      max_geschwindigkeit = Geschwindigkeit;
       if (totalmax < max_geschwindigkeit){
      totalmax = max_geschwindigkeit;
 void sdwrite(){
  root = SD.open("speed.txt", FILE_WRITE);
  root.print(timeClient.getFormattedDate());
  root.print(",");
  root.print(timeClient.getFormattedTime());
  root.print(",");
  root.print(max_geschwindigkeit);
  root.print(",");
  root.println(ankommend);
  root.flush();
  root.close();
parts of this?
could you use FTP?
