Seed Studio ESP32S3 Slave I2C not working
I am having 2 esp32s3 by seed studio, I am trying to communicate between the two ESPs using I2C, so what I am trying to do is that I send data to Master ESP via BLE using NRF connect app then that data is transferred to the slave ESP but in my case what is happening is that data is getting sent successfully but the slave is not receiving it
// Master (ESP32-S3) - i2c_json_master.ino
// Sends a JSON packet over I2C to a Slave ESP32-S3
#include <Wire.h>
#include <ArduinoJson.h>
// I2C address of the Slave
#define SLAVE_ADDR 0x50
  // Initialize I2C as master (SDA = 21, SCL = 22 on Seed Studio ESP32-S3)
  Wire.setPins(5, 6);
  Wire.setClock(100000);
  Wire.begin();
  delay(100);
  Serial.println("I2C Master Initialized");
  // Create a JSON object
  StaticJsonDocument<200> doc;
  doc["id"] = 123;
  doc["status"] = "OK";
  doc["value"] = 50.5;
  // Serialize to string
  String json;
  serializeJson(doc, json);
  // Send JSON over I2C
  Wire.beginTransmission(SLAVE_ADDR);
  Wire.write((const uint8_t *)json.c_str(), json.length());
  byte status = Wire.endTransmission();
  if(status == 0)
    Serial.println("Data Transmission Successful");
  Serial.print("Sent JSON: ");
  Serial.println(json);
  delay(2000);
Here is my slave code
void onReceive(int bytes) {
  len = 0;
    // Serial.println("Data received");
  while (Wire.available() && len < sizeof(incoming) - 1) {
    incoming[len++] = Wire.read();
  incoming[len] = '\0';
  dataReceived = true;
  // vProcessData();
  // Serial.println(incoming);
  Serial.begin(115200); /* prepare for possible serial debug */
  Serial.println("Reset Reason: " + String(esp_reset_reason()));
  if(Wire.begin(SLAVE_ADDR, I2C_SDA, I2C_SCL, FREQ))
    Serial.println("I2C Initialized");
  Wire.onReceive(onReceive);
  esp_task_wdt_deinit();
  vInit_Preferences();
  if (wifiStatus) {
    wm.autoConnect();
  } else if (!wifiStatus) {
    vStartWifiManager();
  if (WiFi.status() == WL_CONNECTED) {
    Serial.println("Wifi Connected");
    Serial.println("Wifi Not Connected");
  lv_xiao_touch_init();
  // mcp.begin_I2C(I2C_ADDR);
  // mcp.pinMode(WIFI_BTN, INPUT_PULLDOWN);
  // mcp.pinMode(PIR_PIN, INPUT_PULLDOWN);
  // mcp.pinMode(BTN_PIN, INPUT_PULLDOWN);
  lv_init();
  tft.begin();        /* TFT init */
  tft.setRotation(0); /* Landscape orientation, flipped */
  lv_disp_draw_buf_init(&draw_buf, buf, NULL, screenWidth * screenHeight / 10);
  /*Initialize the display*/
  static lv_disp_drv_t disp_drv;
  lv_disp_drv_init(&disp_drv);
  /*Change the following line to your display resolution*/
  disp_drv.hor_res = screenWidth;
  disp_drv.ver_res = screenHeight;
  disp_drv.flush_cb = my_disp_flush;
  disp_drv.draw_buf = &draw_buf;
  lv_disp_drv_register(&disp_drv);
  /*Initialize the (dummy) input device driver*/
  static lv_indev_drv_t indev_drv;
  lv_indev_drv_init(&indev_drv);
  indev_drv.type = LV_INDEV_TYPE_POINTER;
  indev_drv.read_cb = my_touchpad_read;
  lv_indev_drv_register(&indev_drv);
  ui_init();
  // if(Wire.available())
  if(dataReceived)
    Serial.println("Data Received");
    dataReceived = false;
    vProcessData();
    memset(incoming, 0, sizeof(incoming));
  lv_timer_handler(); /* let the GUI do its work */
  delay(5);
Your topic does not seem to indicate a problem with IDE 2.x and therefore has been moved to a more suitable location on the forum.
Kinda hard to help if you don't show us anything. Try adding some debug prints so we can see what is happening.
Your slave code is not complete.
It's also very hard to guess what pins you are actually using on both boards.
i am using GPIO pin 5 and 6 on both the esp32s3
this is getting printed at my slave side
17:17:43.008 -> I2C Initialized
17:17:43.008 -> First boot? YES
17:17:43.008 -> *wm:AutoConnect
17:17:43.008 -> *wm:Connecting to SAVED AP: Particle
17:17:43.248 -> *wm:connectTimeout not set, ESP waitForConnectResult...
17:17:44.079 -> *wm:AutoConnect: SUCCESS
17:17:44.079 -> *wm:STA IP Address: 192.168.0.130
17:17:44.079 -> Wifi Connected
17:17:45.113 -> lightSeedDisplay
17:17:45.113 -> 1.0.7
17:17:45.113 -> ALREADY UPDATED
17:17:45.113 -> Screen 1 :SCREEN 1
17:17:45.113 -> Screen 2 :SCREEN 2
17:17:45.113 -> Screen 4 :SCREEN 4
17:17:45.113 -> Screen 5 :SCREEN 5
17:17:45.403 -> Data Received
and this is getting printed at my master side
17:18:32.663 -> Sent JSON: {"id":123,"status":"OK","value":50.5}
17:18:34.695 -> Data Transmission Successful
17:18:34.695 -> Sent JSON: {"id":123,"status":"OK","value":50.5}
17:18:36.704 -> Data Transmission Successful
17:18:36.704 -> Sent JSON: {"id":123,"status":"OK","value":50.5}
17:18:38.698 -> Data Transmission Successful
17:18:38.698 -> Sent JSON: {"id":123,"status":"OK","value":50.5}
17:18:40.682 -> Data Transmission Successful
Update your code to include it all.
How's your wiring? Pullups?
no i dont have any pullups currently but i have tested with example code and it was working without pullups
after adding pullups too it is still the same issue
Too much confusion here..
okay soo i have created a sample code which does exactly what my real code does and i am having the very same issue with it
this is my master code
// Master: i2c_json_master.ino
#include <Wire.h>
  Wire.begin(); // Join I2C bus as master
  // Create a JSON packet
  doc["sensor"] = "temperature";
  doc["value"] = 24.7;
  doc["unit"] = "C";
  char buffer[200];
  size_t len = serializeJson(doc, buffer);
  // Send JSON over I2C to slave
  Wire.write((uint8_t*)buffer, len);
  Serial.println("Sent JSON to slave:");
  Serial.println(buffer);
  delay(2000);
THIS IS MY SLAVE CODE
#include <Wire.h>
#include <Adafruit_MCP23X17.h>
#define EXPANDER_ADDR 0x27
bool flag = false;
String json;
Adafruit_MCP23X17 mcp;
void vProcessData()
  DeserializationError error = deserializeJson(doc, json);
  if (error) {
    Serial.print("JSON parse failed: ");
    Serial.println(error.c_str());
    return;
  // Print parsed values
  const char* sensor = doc["sensor"];
  float value = doc["value"];
  const char* unit = doc["unit"];
  Serial.print("Sensor: "); Serial.println(sensor);
  Serial.print("Value: "); Serial.print(value); Serial.print(" "); Serial.println(unit);
  // Optionally, read expander inputs
  Serial.print("Expander inputs: ");
  Serial.print(mcp.digitalRead(8)); Serial.print(",");
  Serial.print(mcp.digitalRead(9)); Serial.print(",");
  Serial.println(mcp.digitalRead(10));
void onReceive(int len) {
  // Read incoming JSON into buffer
  while (Wire.available()) {
    char c = Wire.read();
    json += c;
  Serial.println("Received JSON:");
  flag = true;
  // Deserialize
  // Initialize I2C as slave
  Wire.begin(SLAVE_ADDR);
  // Initialize MCP23017 I2C expander
  mcp.begin_I2C(EXPANDER_ADDR);
  // Configure GPIO 8,9,10 as inputs (on port B: pins 8-15)
  mcp.pinMode(8, INPUT);
  mcp.pinMode(9, INPUT);
  mcp.pinMode(10, INPUT);
  Serial.println("Slave ready, MCP23017 initialized");
  // Main loop does nothing; work happens in onReceive
  if(flag)
    flag = false;
    vProcessData();
  delay(100);
If you don't specify the I2C pins, afaik wire is using 8 and 9 on Esp32-s3.
Good catch.
Anyway, it's valid only if that specific board has been defined.
For generic S3 it would point to 8 & 9.
Better approach is to define it in code.
Have you tried eliminating the while (Wire.available()) and reading the data into a buffer first?
Something like...
uint8_t RxData[200];
void OnReceive(int len) {
  for (int b = 0; b < len; b++) {
    RxData[b] = Wire.read();
no this isn't working as well
Maybe it won't help but I send a 50 byte payload between two XIAO ESP32-S3's over I2C and use this code, which I know works, for testing the connection...
Controller Sender
#include <Wire.h>
uint8_t TxData[50] = { 9, 8, 7, 6, 5, 4, 3, 2, 1 };
  Wire.begin();
  Wire.beginTransmission(0x42);
  Wire.write(TxData, 50);
  for (int x = 0; x < 50; x++) {
    TxData[x]++;
    if (TxData[x] > 9) {
      TxData[x] = 0;
Peripheral Receiver
#include <Wire.h>
uint8_t RxData[50];
bool Received = false;
void handler(int howmany) {
  for (int i = 0; i < howmany; i++) {
    RxData[i] = Wire.read();
  Received = true;
  Wire.begin(0x42, 5, 6, 100000UL);
  Wire.onReceive(handler);
  if (Received) {
    Serial.print(millis());
    Serial.print(" - ");
    for (int a = 0; a < 50; a++) {
      Serial.print(RxData[a]);
    Received = false;
  delay(10);
Just loaded and tried it and saw the expected serial output:
107917 - 98765432100000000000000000000000000000000000000000
108927 - 09876543211111111111111111111111111111111111111111
109927 - 10987654322222222222222222222222222222222222222222
110937 - 21098765433333333333333333333333333333333333333333
111947 - 32109876544444444444444444444444444444444444444444
112947 - 43210987655555555555555555555555555555555555555555
so i made some changes in mcp initialization and now my onReceive function is executing but now my main loop of the slave side isnt working
This is my master code
#include <Wire.h>
  Wire.begin(D4, D5, 100000);  // Join I2C bus as master
  doc["unit"] = "C";
  char buffer[200];
  int status = Wire.endTransmission();
  if (status == 0) {
    Serial.println("JSON sending failed");
  delay(2000);
and this is my slave code
#include <Wire.h>
bool flag = false;
char json[256];
void vProcessData()
  if (error) {
    return;
  for(int i = 0; i < len; i++){
    json[i] = Wire.read();
    // char c = Wire.read();
    // json += c;
  json[len] = '\0';
  flag = true;
  // Deserialize
  Wire.begin(SLAVE_ADDR,D4, D5,100000);
  mcp.begin_I2C(EXPANDER_ADDR, &Wire1);
  Serial.println("Loop");
  if(flag)
    flag = false;
    vProcessData();
  delay(100);
"not working" and "isn't working" is not the most efficient feedback for debugging.
What happens, what's the output?
What do you get on serial monitor, if anything?
Is it successfully compiling?
