Connecting two ESP32 with I2C Bus
Hello,
I am trying to connect two ESP32 with the I2C bus. The master reads a button and is supposed to send the state of the button to the slave, which will let a LED shine.
Master:
#include <Wire.h>
#define SDA 21
#define SCL 23
int state = 0;
  Wire.begin(SDA,SCL);
  state = digitalRead(14);
  Wire.beginTransmission(2);
  Wire.write(state);
  Wire.endTransmission();
Slave:
#include <Wire.h>
int state = 0;
  ledcSetup(0, 5000, 8);
  ledcAttachPin(19, 0);
  Wire.begin(2);
  Wire.onReceive(receiveEvent);
void receiveEvent(int b){
  state = Wire.read();
  if(state == LOW){
    ledcWrite(0, 255);
  else{
    ledcWrite(0, 0);
I did research and this is my current sketch, the master is compilable, at the slave I get the following error:
sketch\EK512_4.ino.cpp.o:(.literal._Z5setupv+0x10): undefined reference to TwoWire::onReceive(void (*)(int))' sketch\EK512_4.ino.cpp.o: In function setup()':
C:\Users\morit\Desktop\TGM\3\SYT\EK\5.1\EK512_4/EK512_4.ino:25: undefined reference to `TwoWire::onReceive(void (*)(int))'
collect2.exe: error: ld returned 1 exit status
exit status 1
Error compiling for board ESP32 Dev Module.
Things I dont understand:
Can I just put any (imaginary) Adress in beginTransmission (at master), Wire.begin() (at slave)?
Why do I get this error trying to implement onReceive?
Are the specific diffrences - implementing I2C on a ESP?
What did I miss?
Pictures of circuit (bad):
Thanks for your time.
Welcome to the forum
The obvious question is why you are using two ESP32 boards
School
Do breadboard connections fix a compiler error?
I dont think that is has anything to do with the breadboard, i can implement the programm without I2C very easy and the LED and all is working.
No, I just noticed that the breadboard shown with using wires on the other side of the split and offered a suggestion to a possible issue. Sorry to had offended you. I'm out.
I am not offended.
if that's the impression, it's probably because of my bad English. I'm sorry
Update: I2C works now with a ESP32 as master and Arduino Mega as slave, but im still interested in how the solution for ESP32 as both slave and master would look like...
