Sensor shield v5
I need to ask how much voltage i can provide to sensor shield externally?
Im giving power to Arduino and Arduino gives power to shield but my servo motors are jittering
Someone says power Shield externally
What is the range of external voltage supply to sensor shield?
Since you are using motors, and they appear to be the problem, you will probably be better off using a motor shield than a sensor shield, as it is designed for this purpose.
sensor shield is good for servo
Hi Unfortunately there is no standard for Sensor Shield numbers!
If the shield you have is like this, you can power the 3-pin connectors separately:
http://www.yourduino.com/sunshop/index.php?l=product_detail&p=407
See the lower left blue connectors for external power connection. MOVE the jumper to activate that.
DISCLAIMER: Mentioned stuff from my own shop...
