Sensordaten in Influx DB schreiben
Hallo,
ich würde gerne 2 Programme vereinen, die alleine bereits auf dem ESP32 funktionieren. Einmal ein Programm welches Daten in eine Influx DB sendet [1] (nach dem tut: ESP32: Getting Started with InfluxDB | Random Nerd Tutorials ) und einmal ein Programm, welches eine SPO2 Messung vornimmt. [2]
1
 * Secure Write Example code for InfluxDBClient library for Arduino
 * Enter WiFi and InfluxDB parameters below
 * Demonstrates connection to any InfluxDB instance accesible via:
 *  - unsecured http://...
 *  - secure https://... (appropriate certificate is required)
 *  - InfluxDB 2 Cloud at https://cloud2.influxdata.com/ (certificate is preconfigured)
 * Measures signal level of the actually connected WiFi network
 * This example demonstrates time handling, secure connection and measurement writing into InfluxDB
 * Data can be immediately seen in a InfluxDB 2 Cloud UI - measurement wifi_status
 * Complete project details at our blog: https://RandomNerdTutorials.com/
#if defined(ESP32)
  #include <WiFiMulti.h>
  WiFiMulti wifiMulti;
#define DEVICE "ESP32"
  #elif defined(ESP8266)
#include <ESP8266WiFiMulti.h>
  ESP8266WiFiMulti wifiMulti;
  #define DEVICE "ESP8266"
#endif
#include <InfluxDbClient.h>
#include <InfluxDbCloud.h>
// WiFi AP SSID
#define WIFI_SSID "REPLACE_WITH_YOUR_SSID"
// WiFi password
#define WIFI_PASSWORD "REPLACE_WITH_YOUR_PASSWORD"
// InfluxDB v2 server url, e.g. https://eu-central-1-1.aws.cloud2.influxdata.com (Use: InfluxDB UI -> Load Data -> Client Libraries)
#define INFLUXDB_URL "REPLACE_WITH_YOUR_DATABASE_URL"
// InfluxDB v2 server or cloud API token (Use: InfluxDB UI -> Data -> API Tokens -> Generate API Token)
#define INFLUXDB_TOKEN "REPLACE_WITH_YOUR_TOKEN"
// InfluxDB v2 organization id (Use: InfluxDB UI -> User -> About -> Common Ids )
#define INFLUXDB_ORG "REPLACE_WITH_YOUR_ORG"
// InfluxDB v2 bucket name (Use: InfluxDB UI ->  Data -> Buckets)
#define INFLUXDB_BUCKET "ESP32"
// Set timezone string according to https://www.gnu.org/software/libc/manual/html_node/TZ-Variable.html
// Examples:
//  Pacific Time: "PST8PDT"
//  Eastern: "EST5EDT"
//  Japanesse: "JST-9"
//  Central Europe: "CET-1CEST,M3.5.0,M10.5.0/3"
#define TZ_INFO "WET0WEST,M3.5.0/1,M10.5.0"
// InfluxDB client instance with preconfigured InfluxCloud certificate
InfluxDBClient client(INFLUXDB_URL, INFLUXDB_ORG, INFLUXDB_BUCKET, INFLUXDB_TOKEN, InfluxDbCloud2CACert);
// InfluxDB client instance without preconfigured InfluxCloud certificate for insecure connection
//InfluxDBClient client(INFLUXDB_URL, INFLUXDB_ORG, INFLUXDB_BUCKET, INFLUXDB_TOKEN);
// Data point
Point sensor("wifi_status");
  // Setup wifi
  WiFi.mode(WIFI_STA);
  wifiMulti.addAP(WIFI_SSID, WIFI_PASSWORD);
  Serial.print("Connecting to wifi");
  while (wifiMulti.run() != WL_CONNECTED) {
    Serial.print(".");
  // Add tags
  sensor.addTag("device", DEVICE);
  sensor.addTag("SSID", WiFi.SSID());
  // Alternatively, set insecure connection to skip server certificate validation
  //client.setInsecure();
  // Accurate time is necessary for certificate validation and writing in batches
  // For the fastest time sync find NTP servers in your area: https://www.pool.ntp.org/zone/
  // Syncing progress and the time will be printed to Serial.
  timeSync(TZ_INFO, "pool.ntp.org", "time.nis.gov");
  // Check server connection
  if (client.validateConnection()) {
    Serial.print("Connected to InfluxDB: ");
    Serial.println(client.getServerUrl());
    Serial.print("InfluxDB connection failed: ");
    Serial.println(client.getLastErrorMessage());
  // Store measured value into point
  sensor.clearFields();
  // Report RSSI of currently connected network
  sensor.addField("rssi", WiFi.RSSI());
  // Print what are we exactly writing
  Serial.print("Writing: ");
  Serial.println(client.pointToLineProtocol(sensor));
  // If no Wifi signal, try to reconnect it
  if (wifiMulti.run() != WL_CONNECTED) {
    Serial.println("Wifi connection lost");
  // Write point
  if (!client.writePoint(sensor)) {
    Serial.print("InfluxDB write failed: ");
  //Wait 10s
  Serial.println("Wait 10s");
  delay(10000);
2
 * @file SPO2.ino
 * @brief Display heart-rate and SPO2 on serial in real-time, normal SPO2 is within 95~100
 * @n Try to fix the sensor on your finger in using to avoid the effect of pressure change on data output.
 * @n This library supports mainboards: ESP8266, FireBeetle-M0, UNO, ESP32, Leonardo, Mega2560
 * @copyright  Copyright (c) 2010 DFRobot Co.Ltd (http://www.dfrobot.com)
 * @licence     The MIT License (MIT)
 * @author [YeHangYu](hangyu.ye@dfrobot.com)
 * @version  V0.1
 * @date  2020-05-29
 * @url https://github.com/DFRobot/DFRobot_MAX30102
#include <DFRobot_MAX30102.h>
DFRobot_MAX30102 particleSensor;
Macro definition options in sensor configuration
sampleAverage: SAMPLEAVG_1 SAMPLEAVG_2 SAMPLEAVG_4
               SAMPLEAVG_8 SAMPLEAVG_16 SAMPLEAVG_32
ledMode:       MODE_REDONLY  MODE_RED_IR  MODE_MULTILED
sampleRate:    PULSEWIDTH_69 PULSEWIDTH_118 PULSEWIDTH_215 PULSEWIDTH_411
pulseWidth:    SAMPLERATE_50 SAMPLERATE_100 SAMPLERATE_200 SAMPLERATE_400
               SAMPLERATE_800 SAMPLERATE_1000 SAMPLERATE_1600 SAMPLERATE_3200
adcRange:      ADCRANGE_2048 ADCRANGE_4096 ADCRANGE_8192 ADCRANGE_16384
  //Init serial
   *@brief Init sensor
   *@param pWire IIC bus pointer object and construction device, can both pass or not pass parameters (Wire in default)
   *@param i2cAddr Chip IIC address (0x57 in default)
   *@return true or false
  while (!particleSensor.begin()) {
    Serial.println("MAX30102 was not found");
   *@brief Use macro definition to configure sensor
   *@param ledBrightness LED brightness, default value: 0x1F(6.4mA), Range: 0~255(0=Off, 255=50mA)
   *@param sampleAverage Average multiple samples then draw once, reduce data throughput, default 4 samples average
   *@param ledMode LED mode, default to use red light and IR at the same time
   *@param sampleRate Sampling rate, default 400 samples every second
   *@param pulseWidth Pulse width: the longer the pulse width, the wider the detection range. Default to be Max range
   *@param adcRange ADC Measurement Range, default 4096 (nA), 15.63(pA) per LSB
  particleSensor.sensorConfiguration(/*ledBrightness=*/50, /*sampleAverage=*/SAMPLEAVG_4, \
                        /*ledMode=*/MODE_MULTILED, /*sampleRate=*/SAMPLERATE_100, \
                        /*pulseWidth=*/PULSEWIDTH_411, /*adcRange=*/ADCRANGE_16384);
int32_t SPO2; //SPO2
int8_t SPO2Valid; //Flag to display if SPO2 calculation is valid
int32_t heartRate; //Heart-rate
int8_t heartRateValid; //Flag to display if heart-rate calculation is valid
  Serial.println(F("Wait about four seconds"));
  particleSensor.heartrateAndOxygenSaturation(/**SPO2=*/&SPO2, /**SPO2Valid=*/&SPO2Valid, /**heartRate=*/&heartRate, /**heartRateValid=*/&heartRateValid);
  //Print result
  Serial.print(F("heartRate="));
  Serial.print(heartRate, DEC);
  Serial.print(F(", heartRateValid="));
  Serial.print(heartRateValid, DEC);
  Serial.print(F("; SPO2="));
  Serial.print(SPO2, DEC);
  Serial.print(F(", SPO2Valid="));
  Serial.println(SPO2Valid, DEC);
Nun habe ich den Code für die Influx DB angepasst, einmal die Lib eingebunden, neben dem Wifi Status habe ich noch einen SPO2 Wert hinzufügen wollen, er kompiliert auch korrekt, bleibt aber nach dem Senden des Wifi Wertes stecken:
#if defined(ESP32)
#endif
// WiFi AP SSID
#define WIFI_SSID "Mesh"
// WiFi password
#define WIFI_PASSWORD "swint654321"
#define INFLUXDB_URL "https://eu-central-1-1.aws.cloud2.influxdata.com"
// InfluxDB v2 server or cloud API authentication token (Use: InfluxDB UI -> Load Data -> Tokens -> <select token>)
#define INFLUXDB_TOKEN "JfqFz5i0hYPkSiAkOpEOhWUU2UVX696Jl8bBfAeiDLr38ZxBfc0JDVm2FNS-Paa3E1rDmSuW1eHwxFqufwoV-Q=="
// InfluxDB v2 organization id (Use: InfluxDB UI -> Settings -> Profile -> <name under tile> )
#define INFLUXDB_ORG "1624facbb0d16ca2"
// InfluxDB v2 bucket name (Use: InfluxDB UI -> Load Data -> Buckets)
// Examples:
#define TZ_INFO "CET-1CEST,M3.5.0,M10.5.0/3"
// Data point Wifi
// Data point spO2
Point O2Sensor("SPO2");
  // Setup wifi
    Serial.print(".");
  // Add tags
  // Write point
  //Max30102 Sensor beginnen
  //Wait 10s
  delay(10000);
  //serial print Maxim 30102 spO2 Data
  //Print result
  // Write point
  if (!client.writePoint(O2Sensor)) {
load:0x40080400,len:3608
entry 0x400805f0
Connecting to wifi
Syncing time....
Synchronized time: Sat Feb 18 11:27:20 2023
Connected to InfluxDB: https://eu-central-1-1.aws.cloud2.influxdata.com
Writing: wifi_status,device=ESP32,SSID=Mesh rssi=-50i
Wait 10s
Kann jemand weiterhelfen? Muss ich ev Tags definieren? Danke!
Hallo,
such mal hier im Forum ein Wenig herum, das Thema kommt immer wieder mal vor.
Ein paar Tips
Achte darauf das es keine doppelten variablen Namen gibt
Du kannst mehrere Tabs in der IDE anlegen, ich schlage drei vor
Haupttab
Tab Sketch1 komplett da rein kopieren
Tab Sketck2 komplett da rein kopieren
Beide Allgemeinteile so da lassen, Variablennamen prüfen damit keine doppelt sind. Falls nötig leicht abändern.
Setup von Sketch 1 und Sketch2 umbenenne in Setup1 und Setup2
Im Setup vom Hauptab ruftst Du beide hintereinander auf
Loop von Skech1 und Sketch2 umbenenne in loop1 und loop2
im Loop vom Haupttab rufst du hintereinander beide Loops auf
Dann sieht dein Haupttab im Wesentlichen so aus.
setup(){
  setup1();
  setup2();
loop(){
  loop1();
  loop2();
Du kannst das auch erst mit nur einem Sketch machen und mal testen und den zweite anschliessend dazu nehmen.
Heinz
Falls es jemand interessiert, ich bin weiter gekommen. Hab mir jetzt mal visual studio mit platformio installiert (sehr übersichtlich) und ein weiteres tutorial gefunden, hier wird gleich mit einem temperatur sensor die Influx DB gefüttert: ESP32/ESP8266: Send BME280 Sensor Readings to InfluxDB | Random Nerd Tutorials
Der Code in dem Beispiel:
  Rui Santos
  Permission is hereby granted, free of charge, to any person obtaining a copy of this software and associated documentation files.
  The above copyright notice and this permission notice shall be included in all copies or substantial portions of the Software.
// Based on this library example: https://github.com/tobiasschuerg/InfluxDB-Client-for-Arduino/blob/master/examples/SecureBatchWrite/SecureBatchWrite.ino
#include <Arduino.h>
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_BME280.h>
#if defined(ESP32)
  #define WIFI_AUTH_OPEN ENC_TYPE_NONE
#endif
// WiFi AP SSID
#define WIFI_SSID "WLAN1-000727"
// WiFi password
#define WIFI_PASSWORD "XXXXX!"
// Examples:
// Data point
Point sensorReadings("measurements");
//BME280
Adafruit_BME280 bme; // I2C
float temperature;
float humidity;
float pressure;
// Initialize BME280
void initBME(){
  if (!bme.begin(0x76)) {
    Serial.println("Could not find a valid BME280 sensor, check wiring!");
    while (1);
  // Setup wifi
    Serial.print(".");
  //Init BME280 sensor
  initBME();
  // Add tags
  sensorReadings.addTag("device", DEVICE);
  sensorReadings.addTag("location", "office");
  sensorReadings.addTag("sensor", "bme280");
  // Get latest sensor readings
  temperature = bme.readTemperature();
  humidity = bme.readHumidity();
  pressure = bme.readPressure()/100.0F;
  // Add readings as fields to point
  sensorReadings.addField("temperature", temperature);
  sensorReadings.addField("humidity", humidity);
  sensorReadings.addField("pressure", pressure);
  Serial.println(client.pointToLineProtocol(sensorReadings));
  // Write point into buffer
  client.writePoint(sensorReadings);
  // Clear fields for next usage. Tags remain the same.
  sensorReadings.clearFields();
  // Wait 10s
  delay(10000);
Der Code kompliliert korrekt. Jetzt habe ich auch den SPO2 Code einmal im visual studio kompliliert und auch der funktioniert (und gibt den richtigen SPO2 Wert aus, Puls passt noch nicht, aber das schaue ich mir später an und liegt wohl an einem Fehler in der Llib).
 * @file SPO2.ino
 * @version  V0.1
 * @date  2020-05-29
  //Init serial
   *@brief Init sensor
  //Print result
Meiner Vermutung nach muss ich jetzt nur mehr die Sensoren tauschen, das werde ich jetzt mal versuchen.
Funkt!
