Hi all, again ![]()
I've tried to make simple protocol, where the PC sends a 4 digit number and the 1st digit of the num is the variable, here 'x', and the other 3 are values of the variable.
For example. 1211 ---> var is 'x' ---> x = 211 ;
The code is below ![]()
int var_select ;
int trueval ;
int x ;
int y ;
int z ;
int serialData = 0;
long int getSerial()
if (Serial.available() > 0)
serialData = Serial.read();
serialData = serialData - '0' ;
Serial.println(serialData);
return serialData ;
getSerial();
if(serialData == 1)
getSerial();
trueval = serialData * 100 ;
getSerial();
trueval = trueval + serialData * 10 ;
getSerial();
trueval = trueval + serialData ;
x = trueval ;
Serial.println(x) ;
serialData = 0 ;
It sets the variable properly to the 3 digit value. The problem is in the function long int getSerial()
Only when I comment out ' Serial.println(serialData); ' , the serial monitor prints garbage for some reason. Allow it to print, then suddenly it works fine.
w/o ' Serial.println(serialData); '
---> Entry : 1231
111
111
111
etc on the serial monitor
with ' Serial.println(serialData); '
---> Entry : 1231
1
2
3
231
Guys HELP
PLEASE ![]()
