Servos backfeeding Voltage
Hello,
I am building a project that uses a 16x12 pwm servo shield to drive several servos. I am powering the shield from a ubs power brick through an adjustable step up/down module, set to 5V.
This module also has an on/off button. If i have a servo plugged into the shield and the power module is disabled, it shows 0 on its Voltage display. However, with a couple of servos, it shows some voltage (up to 1.5) even when disabled.
From my understanding, what is happening is that the control signal from the arduino is somehow "leaking" into the power connections of the servo.
Is this a big issue? Especially if I plan to have multiple servos plugged into the shield ?.
How can I fix it if its necessary? I wanted to disabled/detach a servo, but the shield doesn't seem to allow that.
Thanks
Can you provide a link to or a photo of the exact shield board you are using please? There seem to be a number of variants of such products about.
We understand a schematic diagram much better than a word salad.
A PCA9685 ? is normally powered from VCC of the processor that is controlling the shield.
The servos should be powered with a separate 5volt supply that only has a shared ground with the MCU. Current capacity of that servo supply should match the number of servos.
That is 12* 650mA (7-10Amp supply) for tiny SG-90 servos or 12*2.5Amp for slightly bigger servos. Servos all draw full stall current every time they start moving...
Here is mu setup. The first pic shows one of these "broken" servos. The second one shows a "normal" one being plugged in. The normal one shows 0 on the module, because the module is disabled, the second however shows some voltage, which it shouldn't. the only difference in the setup are the servos themselves.
the voltage with the "broken" servo drops the moment I disconnect the arduino itself, suggesting the voltage is coming from it, therefore coming from the controlling signal.
As for the power, I will have only 10/16 servos plugged in at a time, and I won't be ever moving more than 4 at a time.
The shield itself is clone of the original Adafruit one if I am correct. The power module is connected through a USB cable to a brick outputting 5V/3.1A
I do know the shield, but I don't know the power module.
Please provide a link to the product.
You don't need a buck or boost converter if your supply is already 5volt.
Servos could fail when you mechanically overload them or use them past their swing range.
Cheap SG-90 servos don't always swing the full 180 degrees.
Here is an amazon Link for the module (can't say its 100% the same, since I didn't buy this one, but it almost definitely is).
The servo don't rotate past their range. The angles aren't set to either of the extremes.
My main issue is the fact that a few of those servos "push" power into the module when it is disabled (and therefore the servos should be unpowered)
What you're saying is not possible.
There is no electrical link between USB power from the Mega to the servo or power module.
Power can only come from the power module. Maybe it's broken, or not working as expected.
You should have used a simple female to screw adapter instead of that power module.
Well I understand there is no connection between the main power and the Arduino power on the shield, but it seems that there is one in those specific servos. Because it doesn't happen with the rest of the servos I have.
I got 4 of these servos from the same place. And only one of them doesn't display this behaviour.
I suppose the best course of action will be to just not use those that do and find replacements, unless another solution is found.
Either way, thanks for your help.
Nevermind, its all 4 of those servos doing it now. Unfortunate
I have not experimented this with servos, but generally tiny leakage from signal line to supply line is nothing paranormal. Likely not issue here. But generally, data line should not exceed supply voltage, so it's bad habit to cut power and leave signal running.
The only link is the 220 Ohm resistors between PCA9685 output and servo control pin.
I suppose there could be a bit of leakage into an unpowered servo during the ~2ms servo pulse that the PCA generates. Nothing to worry about though.
You should have a couple of those $2 SG-90 servos in stock. They are just toys.
And get rid of that power module.
It doesn't make sense to convert a 5volt supply into 5volt for the servos.
