[?] What is the best coupler for 28BYJ-48 ?
The shaft is half rounded and the following coupler doesn't work.
Any help?
Any help?
TOPIC SPLIT
PLEASE DO NOT HIJACK / NECRO POST !
Could you take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
A shaft coupler that fits the outer diameter of the flatted shaft and a setscrew to engage the flat will work.
The coupler DOES work all you have to do is rotate so that both screws are on the shaft OR so that just one screw goes onto the flat.
No problems here with those.
