Share tips you have come across
My Logic Analyser connections.
Tom.... :smiley: :+1: :coffee: :australia:
  • What, no resistor code colours for channel wires ?
:cry:
I'm not ADD, well not yet in my old age anyway....
Guilty! :flushed_face:
Sharpie should make a special color pack for engineers...
Brown, Black, Red, Orange, Yellow, Green, Blue, Purple, Gray, White, Silver, Gold...
(Yes, silver, white, and Gold already exist. I think Gray is the tough one, since it can tend to look like black or purple.) (The existing 12-packs seem to have about 5 colors in the blue/green range, and a pink.)
:+1:
  • Heat shrink is my friend for marking wires of the same colour.
No Gold or Silver
:cry:
Making a Gender Changer
  • Below discusses one flaw with single row male gender changers.
Prototyping Breadboard Soldering
  • I have made up a few soldered prototyping breadboards this last few days.
  • This is an addendum to a previous post showing a method that new people might want to master.
Below are a few new images:
Wire Identification, Numbering, and Labeling
Option 1 — Numeric Identification (00–99 / 000–999)
  • Use two heat-shrink color bands to identify wires (00–99).
    For 000–999, use three bands.
  • Obtain 10 different colored heat-shrink tubes (e.g., 1/8" or 3/16", or ~3 mm I.D.).
  • Cut 2–3 mm rings from each color.
  • Place the rings on both ends of the wire, then shrink using hot air.
  • Cover the rings with clear heat shrink to prevent movement and improve durability.
Option 2 — Functional Color Coding
  • Use specific color ring combinations to indicate wire function.
  • Example:
    • Three black rings → Ground (GND)
  • This method can supplement or replace numeric identification.
Option 3 — Written Labels
  • Cut a 1 cm length of white 1/8" heat shrink.
  • Insert a thin, stiff material (e.g., ~1/32" PCB) to flatten and stabilize the tubing.
  • Using a fine-tip permanent marker (e.g., ultra-fine Sharpie), label the wire’s function (e.g. +12V).
  • Remove the insert and pass the wire through the labeled heat shrink.
  • Apply heat to shrink it onto the wire.
  • Cover with a 2 cm length of clear heat shrink to protect the label from smudging and wear.
  • Shrinking your writing makes it smaller and gives sharper edges.
These work well too:
You'd think that nore places would sell a color-coded assortment (full, 11-color) of heatshrink, or at least the 7 or 8 less common colors (black, red, white, and clear are pretty easy to find.)
How well does white HS, colored with a sharpie, hold up if you put clear over it?
  • The Sharpie as seen in image D has proven successful over 10 years.
Machine Pin Headers, Bending Protection
  • Gold plated Machine Pin Headers are often used to marry two PCBs.
  • Male headers often bend while wiring a PCB.
  • Use the technique below to prevent damaging the header pins.
:wrench: Turn Your Logic Analyzer into a Real-Time Firmware Debugger
For Reference:
  • Some might be interested in this Turtorial:
Razor Saw Cutting Board
  • Make yourself a Cutting Board to make sizing of headers easy work.
  • One of my favourite tools is my 52 TPI 0.01” thick Razor Saw.
  • When cutting headers, most of the plastic remains intact after cutting.
    Only 10 thou plastic is removed.
    No plastic shattering occurs.
  • The following images show how to make a cutting board for your razor saw.
  • The 80-grit sandpaper prevents the board from moving while cutting items.
  • The FR4 Stop Plates register the work when cutting headers.
Edit
Oops, since the saw cuts on a pull stroke, the cutting board should be turned 180° :woozy_face:
New High Grip Tweezers
  • I have been trying out a new pair of $14.00 tweezers sold by Amazon.
  • What makes these tweezers stand out is their quality, tip strength and their ability to grip components.
  • These are Stainless Steel Tweezers with Nano Laser Etching on the inside of the tweezer’s tips.
  • It is the tip etching that really makes these tweezers work so well.
    Older tweezers are smooth or have very little tip treatment.
  • The following images demonstrate the new tweezer’s attributes.
  • One down side is they are ferromagnetic but they can easily be demagnetized if need arises.
    Possibly 403 stainless steel.
  • I’ll keep the old but use the new.
The Boot Tweezer Version
I've found that if you need or want an electric motor to sound like a gasoline engine, a simple hack I came up with is to stick a stripped piece of solid core 22-gauge wire in a configuration where the very tip of the wire comes in contacts with the propeller. I've found this does a decent job at replicating an engines noise in my airplane project, but be warned, it can get noisy.
