Shift register for Keypad entry
hi,
i didn't got much help online while writing a code to collect the numbers entered from a 4X4 matrix keypad and converting it into a 8 digit number..
here i am pasting a small code (may not be 100% ok, but works ) which collects the keys pressed and converts them into a 8 digit code ..
suggestions are appreciated !!!
:smiley:
// Program to collect the 8 digit pressed data and display on LCD
// You can skip the lcd program and see the result on serial port ..
#include <Keypad.h>
#include <LiquidCrystal.h>
int bitcounter = 0; //  counter unless 8 digits are reached
int bitcount =1; // counter for switch statement to run 8 times .. ( see the switch statement in funtion )
volatile long int a,b,c,d,e,f,g,h,sum;  // these are the variables where data will be collected from keypad ..
LiquidCrystal lcd(21,20,19,18,17,16);
const byte ROWS = 4; //four rows
const byte COLS = 4; //four columns
char hexaKeys[ROWS][COLS] = {
  {'7','8','9','A'},
  {'4','5','6','B'},
  {'1','2','3','C'},
  {'L','0','C','D'}
byte rowPins[ROWS] = {4,5,6,7}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {3,2,1,0}; //connect to the column pinouts of the keypad
//initialize an instance of class NewKeypad
Keypad keypad = Keypad( makeKeymap(hexaKeys), rowPins, colPins, ROWS, COLS);
  lcd.begin(16,2);
  lcd.print("   Restarted   ");
  delay(200);
  lcd.clear();
  bitcount = 1;
  lcd.setCursor(0, 0);
  lcd.print  ( "     Main ");
  lcd.setCursor(0, 1);
  lcd.print("     Loop  " );
  char key = keypad.getKey();
  if (key != NO_KEY){
    if ( key == 'A' )  // jump to 'getnumber' funtion
      lcd.clear();
      lcd.print(" Programing Now");
      lcd.clear();
      lcd.print("Enter 8 digit No");
      getnumber ();  // funtions returns the card entered from keypad ...
  if ( key == 'D' ) // displays the contents on serial port or / and lcd
// Test display code on serial port
//    Serial.print("a = ");
//    Serial.println(a);
//    Serial.print("b = ");
//    Serial.println(b);
//    Serial.print("c = ");
//    Serial.println(c);
//    Serial.print("d = ");
//    Serial.println(d);
//    Serial.print("e = ");
//    Serial.println(e);
//    Serial.print("f = ");
//    Serial.println(f);
//    Serial.print("g = ");
//    Serial.println(g);
//    Serial.print("h = ");
//    Serial.println(h);
//    Serial.print("sum = ");
//    Serial.println(sum);
//    Serial.flush();
    lcd.clear();
    lcd.print(sum); // print the 8 digit number
    lcd.clear();
//temp1=0;
//GET NUMBER ENTRY FUNTIONS
void getnumber ()
  if (key != NO_KEY)
  if ( bitcounter <= 7)
    switch (bitcount)
      case 1: { lcd.clear(); a=key ; lcd.print(a,BYTE); bitcount++; break ; }
      case 2: { b=key;  lcd.print(b,BYTE); bitcount++; break ; }
      case 3: { c=key ; lcd.print(c,BYTE); bitcount++; break ; }
      case 4: { d=key ; lcd.print(d,BYTE); bitcount++; break ; }
      case 5: { e=key ; lcd.print(e,BYTE); bitcount++; break ; }
      case 6: { f=key ;  lcd.print(f,BYTE); bitcount++; break ; }
      case 7: { g=key ; lcd.print(g,BYTE); bitcount++; break ; }
      case 8: {
                        h=key ;
                        lcd.print(h,BYTE);
                        lcd.clear();
                        lcd.print("Data accepted");
                        delay(1000); lcd.clear();
                        lcd.setCursor(0,0);
                        lcd.print("  Press 'A'  ");
                        lcd.setCursor(0,1);
                        lcd.print("    to exit     ");
                        bitcount++; break ;
    bitcounter++;
  bitcounter= 0;
  if ( key != 'A' )  getnumber (); // repeats the 'getnumber' funtion unless exit program is not pressed ..
  else  // this part coverts the input data from keypad into 8 digit number and exit the 'getnumber' funtion
       lcd.print  ( "Program Ends.. ");
       lcd.print("please wait " );
       delay(200);
      lcd.clear();
      lcd.print  ( "Press D to  ");
      lcd.print(" see the result  " );
       delay (2000);
       lcd.clear();
       a= a-48;     b=b-48;     c=c-48;     d=d-48;     e=e-48;     f=f-48;  g=g-48;   h=h-48;   // converting ascii value to interger
      // multiplying numbers to get into 10's places ..
      a=(a<<7)*78125;
      b=(b<<6)*15625;
      c=(c<<5)*3125;
      d=(d<<4)*625;
      e=(e<<3)*125;
      f =(f<<2)*25;
      g=(g<<1)*5;
      sum = a + b + c +d + e + f + g +h; // you get the 8 digit code / number ...
Dear Avi Bari
Would you post these two files: keypad.h and liduidcrystal.h
and serial struct?
Thank you!
Best Regards,
Frank
LiquidCrystal is built in to the Arduino IDE.
Hi Tenom,
liquidcrystal.h are included in IDE. Select import library -> LiquidCrystal.
For keypad.h check this link Arduino Playground - Keypad Library
what exactly u mean by serial struct?
