it's one month that i've bought a sim800l and since i bought, i couldn't connect it to the network.
i'm using lm2596 to adjust the voltage of 5V 2A to 3.8V.
the module powers on and blinks every second, even when the sim card is inserted.
i tried out this code to check it:
Cross posting is against the rules of the forum. The reason is that duplicate posts can waste the time of the people trying to help. Someone might spend 15 minutes writing a detailed answer on this thread, without knowing that someone else already did the same in the other thread.
Repeated cross posting will result in a suspension from the forum.
In the future, please take some time to pick the forum section that best suits the topic of your question and then only post once to that forum section. This is basic forum etiquette, as explained in the sticky "How to use this forum - please read." post you will find at the top of every forum section. It contains a lot of other useful information. Please read it.
Thanks in advance for your cooperation.
Thanks for your warning, the frist one was a mistake and thought it was not posted. so i tried to post it again in this section.
I suggest, you chek that your serial port via tle USB is ok. As you describe your problem it has nothing to do with the gprs moduler. (If yr using
Mega, chance to pins 10 and 11 for serial to the gprs moduler).
