I am having trouble to get Sim800L-v2.0 to work. I believe that I am supplying the necessary amount of current (5.0V, 2.1A máx power source, using solid copper wires - circuit photo). The Net LED keeps blinking every second, meaning that it was unable to connect to the network.
Serial monitor readings:
15:57:32.630 -> AT
15:57:32.630 -> OK
16:02:15.391 -> at+cops=?
16:02:23.775 -> +COPS: ,(0-4),(0-2)
16:02:23.775 ->
16:02:23.775 -> OK
16:02:29.075 -> AT+CPIN?
16:02:29.075 -> +CME ERROR: SIM not inserted
16:02:51.008 -> AT+CREG?
16:02:51.008 -> +CREG: 0,0
16:02:51.008 ->
16:02:51.008 -> OK
16:02:59.639 -> AT+CSQ
16:02:59.639 -> +CSQ: 0,0
16:02:59.639 ->
16:02:59.639 -> OK
16:08:09.354 -> +CFUN: 1
16:08:09.354 ->
16:08:09.354 -> OK
Inspecting the readings, it indicates that the sim card is not inserted at all, which is odd. While searching for some tips on the subject, I did encounter one or another claiming that the problem might be related to the incorrect capacitor used in the circuit module, not really sure though...
Country: Portugal
Sim card netw.: Altice
Any ideas to solve the issue? Is it a module problem, or am I missing some steps? Thanks in advance!
Code used:
#include <SoftwareSerial.h>
#define TX_PIN 10
#define RX_PIN 11
SoftwareSerial serialGSM(TX_PIN, RX_PIN);
while(!Serial);
serialGSM.listen();
serialGSM.begin(9600);
Serial.println("Ready.");
if(serialGSM.available()){
Serial.write(serialGSM.read());
if(Serial.available()){
serialGSM.write(Serial.read());
