Simple Intruder Alarm w/ Arduino Nano ESP32 and Twilio
Hi all,
Made a simple (and whimsically named) intruder alarm using a PIR motion sensor and an Arduino ESP32, and using Twilio to send SMS arm/disarm/alert messages. I used the available twilio.hpp library. An account at Twilio will cost you about a penny per SMS.
Code below; the PDF contains all other instructions.
Intrudalizer Manual.pdf (2.6 MB)
I am sure I'll refine the code more but it does work well, just what I intended. Possible future:
  • add hardware watchdog (deliberately left off for now: I want to avoid ANY chance of constant restarts and consequent SMSs)
  • Debounce the switch (seems not needed because after the switch cage, there is an SMS send action, which takes over a second, by which time any bounce would surely be over).
  • Refinement, if needed, of the failed SMS sequence.
But that's all just "perhaps". As it, it works. Enjoy!
 Intruder Alarm with text messaging: "Intrudalizer 2000 Pro"
 By: Michael Willems - michael@willems.ca
 Needs:
    -Arduino Nano ESP32
    -WiFi connectivity (2.4 GHz)
    -Twilio account
    -twilio-esp32-client library (from Arduino IDE)
    -PIR sensor
    -LEDs, resistor, SPDT switch, pushbutton.
 Alarm is activated with switch (flashing yellow); 60 seconds later it's active (solid yellow).
 Sends SMS to phone upon bootup, arm, disarm, and alarm.
 After an alarm, it stays in alarmed status for an hour, and then it resets so that
 new alarms can be generated and new alarm SMSs can be sent.
 Version of 11 Aug 2023
 Change log:
  0.5  added infinite 4-sec retry on all SMS messages.
       also added "green LED off" while sending SMS.
  0.41 simplified message text
  0.4  added a 2x retry to a failed SMS on trigger
  0.32 minor changes, tidied up, removed unnecessary pushbotton, removed serialWrite.
  0.31 documentation/comments added
  0.3  added one hour trigger reset
  0.2  added SMS on arm/disarm
  0.1  made it work
// INCLUDES, DECLARATIONS:
#include "WiFi.h"
#include "twilio.hpp"
// define WiFi and SMS credentials:
const char *ssid = "xxxxx";
const char *password = "xxxxx";
Twilio *twilio;
// Values from Twilio (from the dashboard):
static const char *account_sid = "xxxxx";
static const char *auth_token = "xxxxx";
static const char *from_number = "xxxxx";
static const char *to_number = "xxxxx";
static const char *messageStart =    "Boyer: Startup------";
static const char *messageAlert =    "Boyer: MOTION DETECT";
static const char *messageArmed =    "Boyer: Armed";
static const char *messageDisarmed = "Boyer: Disarmed";
String response;
// define misc pins:
int PIRpin = 2;
int Switch = 10;
// on-board LEDs:
int activeled = 13;  // flashes 1x/sec to indicate functioning
int blueled = 16;    // blue when WiFi is connected
// External LEDs:
int OkLed = 3;       // WiFi and SMS OK
int WiFiErrLed = 4;  // WiFi Error
int SmsErrLed = 5;   // SMS Error
int ArmLed = 6;      // Armed
int TrigLed = 7;     // Motion seen!
// Counters etc:
unsigned long oneseccounter;
unsigned long quartersecondcounter;
unsigned long fourseccounter;
unsigned long prearmtimer;  // delay before armed is active (default: 60000)
unsigned long prearmdelay = 60000;
unsigned long rearmtimer;  // "no new alarm" time after alarm (default: 3600000)
unsigned long rearmdelay = 3600000;
unsigned long resendtimer; // TBD: resend an SMS on error
unsigned long resenddelay = 60000;
boolean ArmedStat = false;       // Flag: are we armed?
boolean PreArmInhibit = false;   // Flag: are we stil in pre-arm time, so no alarms yet please?
boolean TriggeredStat = false;   // Flag: is the alarm triggered?
boolean TriggerNotSent = false;  // to allow resends if trigger SMS not sent correctly
boolean ArmedNotSent = false;    // same for armed
boolean DisarmedNotSent = false; // same for disarmed
boolean StartNotSent = false;    // same for start
// THE SETUP (RUNS ONCE):
  pinMode(PIRpin, INPUT);
  pinMode(Switch, INPUT_PULLUP);
  pinMode(activeled, OUTPUT);
  pinMode(blueled, OUTPUT);
  pinMode(OkLed, OUTPUT);       // green
  pinMode(WiFiErrLed, OUTPUT);  // red
  pinMode(SmsErrLed, OUTPUT);   // red
  pinMode(ArmLed, OUTPUT);      // yellow
  pinMode(TrigLed, OUTPUT);     // blue
  // Set inital LED status:
  digitalWrite(OkLed, LOW);
  digitalWrite(WiFiErrLed, HIGH);
  digitalWrite(SmsErrLed, HIGH);
  digitalWrite(ArmLed, LOW);
  digitalWrite(TrigLed, LOW);
  // Now connect to WiFi and wait until connected:
  WiFi.begin(ssid, password);
    digitalWrite(activeled, LOW);
    analogWrite(blueled, LOW);
    delay(250);                 // and if we use a hardware watchdog, don't forget to reset it here!
  // We are connected, so indicate this:
  analogWrite(blueled, HIGH);
  digitalWrite(activeled, HIGH);
  digitalWrite(WiFiErrLed, LOW);
  delay(250);
  // start Twilio instance:
  twilio = new Twilio(account_sid, auth_token);
  // Now send SMS:
  String response;
  SendStartMessage();
  // set the timers to start:
  fourseccounter = millis();
  oneseccounter = millis();
  quartersecondcounter = millis();
// THE LOOP (RUNS CONTINUOUSLY):
  // -----------now do the "once every second" things:-------------------------
  if ((millis() - oneseccounter) > 1000) {
    //Toggle the on-board 'active' LED:
    digitalWrite(activeled, !digitalRead(activeled));
    // is WiFi connected? If not, turn off the blue and OK LED, and turn on WiFi Error LED:
    if (WiFi.status() != WL_CONNECTED) {
      analogWrite(WiFiErrLed, HIGH);
      // wifi is OK, so turn the on-board blue LED on, and turn WiFi error light off:
      analogWrite(WiFiErrLed, LOW);
      digitalWrite(OkLed, HIGH);
    // Now reset counter so we can start counting another second:
  // End of "once a second" things.
  // Every quarter second" - flashing the light while armed+inhibited:-------
  if ((millis() - quartersecondcounter) > 250) {
    if ((ArmedStat == true) && (PreArmInhibit == true)) {
      digitalWrite(ArmLed, !digitalRead(ArmLed));
  // --------------"every four seconds": the SMS error routines---------------
  if ((millis() - fourseccounter) > 4000) {
    if (StartNotSent == true) {
      SendStartMessage();
    if (ArmedNotSent == true) {
      SendArmedMessage();
    if (TriggerNotSent == true) {
      SendTriggerMessage();
    if (DisarmedNotSent == true) {
      SendDisarmedMessage();
  // Now the "always do this" things:----------------------------------------
  // Arm/Disarm routines:
  if (digitalRead(Switch) == LOW) {  //switch is turned on (up)
    if ((millis() - prearmtimer) > prearmdelay) {
      digitalWrite(ArmLed, HIGH);  // turn on "Armed" light just in case it's not on yet
    if (ArmedStat == false) {      // i.e. it was just now turned to ARM...
      ArmedStat = true;            // so next loop it knows it's not only just been armed, so not another SMS
      // Send "Armed" SMS:
      SendArmedMessage();
      // Start Inhibit timer (minute to get out of the room):
      PreArmInhibit = true;
      prearmtimer = millis();
  } else {                      // Switch is turned down (off)
    digitalWrite(ArmLed, LOW);  // so turn off Armed LED
    if (ArmedStat == true) {    // i.e. it was just turned to DISARM...
      // Send "Disarmed" SMS:
      ArmedStat = false;  // so next loop it knows it's not only just been disarmed, so not another SMS
  // Trigger Event Routines:
  if (digitalRead(PIRpin) == HIGH) {                        // The PIR is giving an trigger indication...
    digitalWrite(TrigLed, HIGH);                            // ..so, turn on the Trigger LED just in case it's not on yet.
    if ((ArmedStat == true) && (PreArmInhibit == false)) {  // we are armed and we are not inhibited
      if (TriggeredStat == false) {                         // we WERE not triggered, but now we are.
        // So, send an SMS: we are fully armed and had a motion alert.
        TriggeredStat = true;   // Trigger status ON (so we won't send another SMS, for a start!)
        rearmtimer = millis();  // Start the re-arm timer (after which we will turn triggered status off)
  } else {  // the PIR is not giving an trigger indication
    if ((ArmedStat == false) || (PreArmInhibit == true)) {
      digitalWrite(TrigLed, LOW);  // ...we are not [yet] armed, so turn off Trigger LED after PIR stops activating
      TriggeredStat = false;       // also, since we are not armed and not triggered, turn off triggered status
  // If we are past the rearm timer, re-arm the system, ie turn off blue LED & get ready to send SMS if triggered+armed
  // It is safe to do this even when we are not armed: all it does is say we are not triggered and turn off blue LED.
  // It is better to do this unnecessarily than to risk missing a condition and not re-arming in error.
  // This will never happen within an hour of sending a trigger SMS (that's what this condition is for)
  if (((millis() - rearmtimer) > rearmdelay) && (digitalRead(PIRpin) == LOW)) {
    digitalWrite(TrigLed, LOW);  // ...we are not triggered, so turn off Trigger LED after PIR stops activating
  //--end of loop code here--
// THE FUNCTIONS (CALLED AS NEEDED):
void SendStartMessage() {
  bool success = twilio->send_message(to_number, from_number, messageStart, response);
  if (success) {    // SMS sent successfully.
    digitalWrite(SmsErrLed, LOW);
  } else {          // uh oh, SMS failure
    StartNotSent = true;
void SendTriggerMessage() {
  bool success = twilio->send_message(to_number, from_number, messageAlert, response);
    TriggerNotSent = true;
void SendArmedMessage() {
  bool success = twilio->send_message(to_number, from_number, messageArmed, response);
    ArmedNotSent = true;
void SendDisarmedMessage() {
  bool success = twilio->send_message(to_number, from_number, messageDisarmed, response);
    DisarmedNotSent = true;
Thanks for sharing.
I like your box :face_with_spiral_eyes: !
Great work!
The 3D printed front panel turned out great.
You can even colour in the front of the letters on the front panel with a waterproof pen.
Sorry - the PDF was missing.
Here it is:
Intrudalizer Manual.pdf (2.5 MB)
Sorry Paul, the PDF was missing. Here it is:
Great project, the only improvement I could suggest is to add an annotated schematic.
You are absolutely right. So here it is :slight_smile:
  • Hope the output of the PIR is 0v to 3v :grimacing:
  • Hope your LEDs have series dropping resistors :grimacing:
Well spotted. But don’t worry:
The PIR indeed outputs 3.3V, not 5.
The LEDs indeed have 100R resistors in series.
I of course documented those things both in the updated manual.
The SMS mechanism was a little less robust than I had assumed, but more importantly, good practice made me add one thing:
  • The SMS messages (booted, armed, disarmed, alert) now repeat every four seconds until they succeed, if they did not work the first time.
  • The green "OK" LED turns off whenever an SMS is being sent, and it turns on again afterward. Because just like "no means no", also "OK means OK". And it's not OK until we have confirmed the the SMS was sent successfully.
