Simplifying the circuit.
Hey all.
I am working on a small project and need some advice on how to approach it.
So far I have gotten the code down on a simulator and is just waiting on getting some of the components home.
I know how to create a PCB and to solder and have basic understanding about electronics.
What I want to do is to control 6 vibration motors separately through the arduino board.
I have found this tutorial that shows how to connect a single motor: How to Build a Vibration Motor Circuit
I am using these vibration motors: http://www.miniinthebox.com/da/diy-1027-flat-vibrating-vibration-motor-soelv-5-stk_p1428065.html
Now my question is: How do I connect the other 5?
Is it just a matter of creating 6 identical circuits from the tutorial or can it be simplyfied?
I don't know enough about the effects of the components to figure that out on my own.
Thanks in advance
Daniel
Yes.
No.
Thanks... Then it should be simple enough. :slight_smile:
Can also use a TPIC6B595 high current output shift register to control up to 8 motors from just 3 Arduino pins. Use one output each in place of the NPN transistor.
Lose the 1N4001 and use 1N4148 instead, it can handle 80mA fine and are much smaller,
neater, cheaper.
