I´m having problems using a .c code generated in simulink in Arduino IDE. My goal is to modify the code in arduino ide and upload it to a Wemos D1 mini. What i did was adding the .c and .h files,generated in simulink. to a zip and adding this zip as a library in the IDE. The last error i had was the following:
15 | # include <dlfcn.h>
compilation terminated.
exit status 1
Compilation error: exit status 1
I would appreciate it if someone knows an easier way to do it.
We are going to need a lot more info to help. Start by posting your code - the code generated in simulink as well as the sketch you are modifying in the IDE.
I'm guessing that there are more errors above the one you referenced. In the IDE, there is a handy button labelled "copy error messages" which works well to copy the entire error message so you can post it here as well and then folks can help.
Please use code tags when doing all your code and error messages as well.
How to get the best out of this forum - Using Arduino / Installation & Troubleshooting - Arduino Forum
At the moment the code i generated from simulink is the same as the .ino:
* Filtrado_y_ponderacion_max4466.c
* Code generation for model "Filtrado_y_ponderacion_max4466".
* Model version : 1.14
* Simulink Coder version : 9.5 (R2021a) 14-Nov-2020
* C source code generated on : Mon Apr 3 12:48:56 2023
* Target selection: grt.tlc
* Note: GRT includes extra infrastructure and instrumentation for prototyping
* Embedded hardware selection: Atmel->AVR
* Code generation objective: Debugging
* Validation result: Not run
#include "Filtrado_y_ponderacion_max4466.h"
#include "Filtrado_y_ponderacion_max4466_private.h"
#include <ESP8266WiFi.h>
/* Block signals (default storage) */
B_Filtrado_y_ponderacion_max4_T Filtrado_y_ponderacion_max446_B;
/* Block states (default storage) */
DW_Filtrado_y_ponderacion_max_T Filtrado_y_ponderacion_max44_DW;
/* External outputs (root outports fed by signals with default storage) */
ExtY_Filtrado_y_ponderacion_m_T Filtrado_y_ponderacion_max446_Y;
/* Real-time model */
static RT_MODEL_Filtrado_y_ponderaci_T Filtrado_y_ponderacion_max44_M_;
RT_MODEL_Filtrado_y_ponderaci_T *const Filtrado_y_ponderacion_max44_M =
&Filtrado_y_ponderacion_max44_M_;
/* Model step function */
void Filtrado_y_ponderacion_max4466_step(void)
real_T numAccum;
real_T u0;
int32_T ioIdx;
int16_T i;
char_T *sErr;
for (i = 0; i < 1024; i++) {
/* DiscreteIntegrator: '<Root>/Discrete-Time Integrator' */
Filtrado_y_ponderacion_max446_B.DiscreteTimeIntegrator[i] =
Filtrado_y_ponderacion_max44_DW.DiscreteTimeIntegrator_DSTATE[i];
/* Gain: '<Root>/Ganancia Vref' incorporates:
Filtrado_y_ponderacion_max446_B.GananciaVref[i] =
Filtrado_y_ponderacion_max446_P.GananciaVref_Gain *
Filtrado_y_ponderacion_max446_B.DiscreteTimeIntegrator[i];
/* MinMax: '<S2>/Max' incorporates:
* Constant: '<S2>/Constant'
u0 = Filtrado_y_ponderacion_max446_B.GananciaVref[i];
if ((!(u0 > Filtrado_y_ponderacion_max446_P.Constant_Value)) && (!rtIsNaN
(Filtrado_y_ponderacion_max446_P.Constant_Value))) {
u0 = Filtrado_y_ponderacion_max446_P.Constant_Value;
/* MinMax: '<S2>/Max' */
Filtrado_y_ponderacion_max446_B.Max[i] = u0;
/* Math: '<Root>/Log' incorporates:
* About '<Root>/Log':
* Operator: log
Filtrado_y_ponderacion_max446_B.Log[i] = log
(Filtrado_y_ponderacion_max446_B.Max[i]);
/* Outport: '<Root>/Output' incorporates:
* Gain: '<Root>/Gain2'
* Operator: log
Filtrado_y_ponderacion_max446_Y.Output[i] =
Filtrado_y_ponderacion_max446_P.Gain2_Gain *
Filtrado_y_ponderacion_max446_B.Log[i];
/* S-Function (saudioFromAudioDevice): '<Root>/Audio Device Reader' */
sErr = GetErrorBuffer
(&Filtrado_y_ponderacion_max44_DW.AudioDeviceReader_AudioDeviceLi[0UL]);
LibOutputs_Audio
(&Filtrado_y_ponderacion_max44_DW.AudioDeviceReader_AudioDeviceLi[0UL],
&Filtrado_y_ponderacion_max446_B.AudioDeviceReader[0UL], 5L, 1024L, 0L);
if (*sErr != 0) {
rtmSetErrorStatus(Filtrado_y_ponderacion_max44_M, sErr);
rtmSetStopRequested(Filtrado_y_ponderacion_max44_M, 1);
/* End of S-Function (saudioFromAudioDevice): '<Root>/Audio Device Reader' */
/* S-Function (sdspbiquad): '<S1>/Generated Filter Block' incorporates:
ioIdx = 0L;
u0 = 0.78804816721176729 *
Filtrado_y_ponderacion_max446_B.AudioDeviceReader[ioIdx];
u0 -= -0.22455845805977917 *
Filtrado_y_ponderacion_max44_DW.GeneratedFilterBlock_FILT_STATE[0L];
u0 -= 0.0126066252715464 *
Filtrado_y_ponderacion_max44_DW.GeneratedFilterBlock_FILT_STATE[1L];
numAccum = 0.00032231859289771897 * u0;
numAccum += 0.00064463718579543794 *
numAccum += 0.00032231859289771897 *
Filtrado_y_ponderacion_max44_DW.GeneratedFilterBlock_FILT_STATE[1L] =
Filtrado_y_ponderacion_max44_DW.GeneratedFilterBlock_FILT_STATE[0L] = u0;
u0 = numAccum;
u0 -= -1.8938704947230705 *
Filtrado_y_ponderacion_max44_DW.GeneratedFilterBlock_FILT_STATE[2L];
u0 -= 0.89515976909466144 *
Filtrado_y_ponderacion_max44_DW.GeneratedFilterBlock_FILT_STATE[3L];
numAccum = u0;
numAccum += -2.0 *
numAccum += Filtrado_y_ponderacion_max44_DW.GeneratedFilterBlock_FILT_STATE
[3L];
Filtrado_y_ponderacion_max44_DW.GeneratedFilterBlock_FILT_STATE[3L] =
Filtrado_y_ponderacion_max44_DW.GeneratedFilterBlock_FILT_STATE[2L] = u0;
u0 = numAccum;
u0 -= -1.9946144559930217 *
Filtrado_y_ponderacion_max44_DW.GeneratedFilterBlock_FILT_STATE[4L];
u0 -= 0.99462170701408448 *
Filtrado_y_ponderacion_max44_DW.GeneratedFilterBlock_FILT_STATE[5L];
numAccum = u0;
numAccum += -2.0 *
[5L];
Filtrado_y_ponderacion_max44_DW.GeneratedFilterBlock_FILT_STATE[5L] =
Filtrado_y_ponderacion_max44_DW.GeneratedFilterBlock_FILT_STATE[4L] = u0;
Filtrado_y_ponderacion_max446_B.GeneratedFilterBlock[ioIdx] =
922.43864463225691 * numAccum;
ioIdx++;
/* End of S-Function (sdspbiquad): '<S1>/Generated Filter Block' */
/* Saturate: '<Root>/Saturation' incorporates:
u0 = Filtrado_y_ponderacion_max446_B.GeneratedFilterBlock[i];
if (u0 > Filtrado_y_ponderacion_max446_P.Saturation_UpperSat) {
u0 = Filtrado_y_ponderacion_max446_P.Saturation_UpperSat;
} else if (u0 < Filtrado_y_ponderacion_max446_P.Saturation_LowerSat) {
u0 = Filtrado_y_ponderacion_max446_P.Saturation_LowerSat;
/* Saturate: '<Root>/Saturation' */
Filtrado_y_ponderacion_max446_B.Saturation[i] = u0;
/* Gain: '<Root>/Resitencia Fast' incorporates:
Filtrado_y_ponderacion_max446_B.ResitenciaFast[i] =
Filtrado_y_ponderacion_max446_P.ResitenciaFast_Gain *
Filtrado_y_ponderacion_max446_B.Saturation[i];
/* Update for DiscreteIntegrator: '<Root>/Discrete-Time Integrator' incorporates:
Filtrado_y_ponderacion_max44_DW.DiscreteTimeIntegrator_DSTATE[i] +=
Filtrado_y_ponderacion_max446_P.DiscreteTimeIntegrator_gainval *
Filtrado_y_ponderacion_max446_B.ResitenciaFast[i];
/* Matfile logging */
rt_UpdateTXYLogVars(Filtrado_y_ponderacion_max44_M->rtwLogInfo,
(&Filtrado_y_ponderacion_max44_M->Timing.taskTime0));
/* signal main to stop simulation */
{ /* Sample time: [0.023219954648526078s, 0.0s] */
if ((rtmGetTFinal(Filtrado_y_ponderacion_max44_M)!=-1) &&
!((rtmGetTFinal(Filtrado_y_ponderacion_max44_M)-
Filtrado_y_ponderacion_max44_M->Timing.taskTime0) >
Filtrado_y_ponderacion_max44_M->Timing.taskTime0 * (DBL_EPSILON))) {
rtmSetErrorStatus(Filtrado_y_ponderacion_max44_M, "Simulation finished");
/* Update absolute time for base rate */
/* The "clockTick0" counts the number of times the code of this task has
* been executed. The absolute time is the multiplication of "clockTick0"
* and "Timing.stepSize0". Size of "clockTick0" ensures timer will not
* overflow during the application lifespan selected.
* Timer of this task consists of two 32 bit unsigned integers.
* The two integers represent the low bits Timing.clockTick0 and the high bits
* Timing.clockTickH0. When the low bit overflows to 0, the high bits increment.
if (!(++Filtrado_y_ponderacion_max44_M->Timing.clockTick0)) {
++Filtrado_y_ponderacion_max44_M->Timing.clockTickH0;
Filtrado_y_ponderacion_max44_M->Timing.taskTime0 =
Filtrado_y_ponderacion_max44_M->Timing.clockTick0 *
Filtrado_y_ponderacion_max44_M->Timing.stepSize0 +
Filtrado_y_ponderacion_max44_M->Timing.clockTickH0 *
Filtrado_y_ponderacion_max44_M->Timing.stepSize0 * 4294967296.0;
/* Model initialize function */
void Filtrado_y_ponderacion_max4466_initialize(void)
/* Registration code */
/* initialize non-finites */
rt_InitInfAndNaN(sizeof(real_T));
/* initialize real-time model */
(void) memset((void *)Filtrado_y_ponderacion_max44_M, 0,
sizeof(RT_MODEL_Filtrado_y_ponderaci_T));
rtmSetTFinal(Filtrado_y_ponderacion_max44_M, 9.9845804988662135);
Filtrado_y_ponderacion_max44_M->Timing.stepSize0 = 0.023219954648526078;
/* Setup for data logging */
static RTWLogInfo rt_DataLoggingInfo;
rt_DataLoggingInfo.loggingInterval = (NULL);
Filtrado_y_ponderacion_max44_M->rtwLogInfo = &rt_DataLoggingInfo;
rtliSetLogXSignalInfo(Filtrado_y_ponderacion_max44_M->rtwLogInfo, (NULL));
rtliSetLogXSignalPtrs(Filtrado_y_ponderacion_max44_M->rtwLogInfo, (NULL));
rtliSetLogT(Filtrado_y_ponderacion_max44_M->rtwLogInfo, "tout");
rtliSetLogX(Filtrado_y_ponderacion_max44_M->rtwLogInfo, "");
rtliSetLogXFinal(Filtrado_y_ponderacion_max44_M->rtwLogInfo, "");
rtliSetLogVarNameModifier(Filtrado_y_ponderacion_max44_M->rtwLogInfo, "rt_");
rtliSetLogFormat(Filtrado_y_ponderacion_max44_M->rtwLogInfo, 4);
rtliSetLogMaxRows(Filtrado_y_ponderacion_max44_M->rtwLogInfo, 0);
rtliSetLogDecimation(Filtrado_y_ponderacion_max44_M->rtwLogInfo, 1);
rtliSetLogY(Filtrado_y_ponderacion_max44_M->rtwLogInfo, "");
rtliSetLogYSignalInfo(Filtrado_y_ponderacion_max44_M->rtwLogInfo, (NULL));
rtliSetLogYSignalPtrs(Filtrado_y_ponderacion_max44_M->rtwLogInfo, (NULL));
/* block I/O */
(void) memset(((void *) &Filtrado_y_ponderacion_max446_B), 0,
sizeof(B_Filtrado_y_ponderacion_max4_T));
/* states (dwork) */
(void) memset((void *)&Filtrado_y_ponderacion_max44_DW, 0,
sizeof(DW_Filtrado_y_ponderacion_max_T));
/* external outputs */
(void) memset(&Filtrado_y_ponderacion_max446_Y.Output[0], 0,
1024U*sizeof(real_T));
rt_StartDataLoggingWithStartTime(Filtrado_y_ponderacion_max44_M->rtwLogInfo,
0.0, rtmGetTFinal(Filtrado_y_ponderacion_max44_M),
Filtrado_y_ponderacion_max44_M->Timing.stepSize0, (&rtmGetErrorStatus
(Filtrado_y_ponderacion_max44_M)));
char_T *sErr;
/* Start for S-Function (saudioFromAudioDevice): '<Root>/Audio Device Reader' */
CreateHostLibrary("hostlibaudio.dll",
[0UL]);
if (*sErr == 0) {
LibCreate_Audio
0L, "Default", 1L, 0L, 1L, 44100.0, 3L, 1024L, 10240L, 1024L, 5L, NULL);
if (*sErr != 0) {
DestroyHostLibrary
if (*sErr != 0) {
/* End of Start for S-Function (saudioFromAudioDevice): '<Root>/Audio Device Reader' */
int16_T i;
/* InitializeConditions for DiscreteIntegrator: '<Root>/Discrete-Time Integrator' */
Filtrado_y_ponderacion_max44_DW.DiscreteTimeIntegrator_DSTATE[i] =
Filtrado_y_ponderacion_max446_P.DiscreteTimeIntegrator_IC;
/* End of InitializeConditions for DiscreteIntegrator: '<Root>/Discrete-Time Integrator' */
/* InitializeConditions for S-Function (sdspbiquad): '<S1>/Generated Filter Block' */
for (i = 0; i < 6; i++) {
Filtrado_y_ponderacion_max44_DW.GeneratedFilterBlock_FILT_STATE[i] = 0.0;
/* End of InitializeConditions for S-Function (sdspbiquad): '<S1>/Generated Filter Block' */
/* Model terminate function */
void Filtrado_y_ponderacion_max4466_terminate(void)
char_T *sErr;
/* Terminate for S-Function (saudioFromAudioDevice): '<Root>/Audio Device Reader' */
LibTerminate(&Filtrado_y_ponderacion_max44_DW.AudioDeviceReader_AudioDeviceLi
[0UL]);
if (*sErr != 0) {
LibDestroy_Audio
(&Filtrado_y_ponderacion_max44_DW.AudioDeviceReader_AudioDeviceLi[0UL], 0L,
1L);
DestroyHostLibrary
/* End of Terminate for S-Function (saudioFromAudioDevice): '<Root>/Audio Device Reader' */
The error I'm having is the following:
In file included from c:\Users\Usuario\Documents\Arduino\libraries\Filtrado_y_ponderacion_max4466_grt_rtw/HostLib_Audio.h:38,
from c:\Users\Usuario\Documents\Arduino\libraries\Filtrado_y_ponderacion_max4466_grt_rtw/Filtrado_y_ponderacion_max4466.h:29,
from C:\Users\Usuario\Documents\Arduino\prueba_simulink\prueba_simulink.ino:17:
c:\Users\Usuario\Documents\Arduino\libraries\Filtrado_y_ponderacion_max4466_grt_rtw/DAHostLib_rtw.h:15:12: fatal error: dlfcn.h: No such file or directory
exit status 1
And there's the problem - no such file or directory. The compiler can not locate dlfcn.h. Where is it located on your system
I get it but I don't know what that file does. Is this a specific file from my project or is something from Arduino IDE.
It looks like your DAHostLib_rtw.h file is the one that is trying to include it. That file is part your "library" you installed
I took a look to the file you mentioned. I modified the file and upload the zip library again. I closed the IDE and when i opend it the following warning was displayed:
Some indexes could not be updated. Get "c:\Users\Usuario\Documents\dlfcn\dlfcn-win32-master\build\bin\Debug": unsupported protocol scheme "c": c:\Users\Usuario\Documents\dlfcn\dlfcn-win32-master\build\bin\Debug
After that i verified the coded and this error was found:
Using board 'd1_mini' from platform in folder: C:\Users\Usuario\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.1
Using core 'esp8266' from platform in folder: C:\Users\Usuario\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.1
"C:\\Users\\Usuario\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\python3\\3.7.2-post1/python3" -I "C:\\Users\\Usuario\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.1/tools/mkbuildoptglobals.py" "C:\\Users\\Usuario\\AppData\\Local\\Programs\\Arduino IDE\\resources\\app\\node_modules\\arduino-ide-extension\\build" 10607 "C:\\Users\\Usuario\\AppData\\Local\\Temp\\arduino\\sketches\\48629FD1D5845F21FB7469EFC7BFC69A" "C:\\Users\\Usuario\\AppData\\Local\\Temp\\arduino\\sketches\\48629FD1D5845F21FB7469EFC7BFC69A/core/build.opt" "C:\\Users\\Usuario\\Documents\\Arduino\\prueba_simulink/prueba_simulink.ino.globals.h" "C:\\Users\\Usuario\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.1\\cores\\esp8266/CommonHFile.h"
Note: optional global include file 'C:\Users\Usuario\Documents\Arduino\prueba_simulink\prueba_simulink.ino.globals.h' does not exist.
Read more at https://arduino-esp8266.readthedocs.io/en/latest/faq/a06-global-build-options.html
Detecting libraries used...
"C:\\Users\\Usuario\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 "@C:\\Users\\Usuario\\AppData\\Local\\Temp\\arduino\\sketches\\48629FD1D5845F21FB7469EFC7BFC69A/core/build.opt" "-IC:\\Users\\Usuario\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.1/tools/sdk/include" "-IC:\\Users\\Usuario\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.1/tools/sdk/lwip2/include" "-IC:\\Users\\Usuario\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.1/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\Usuario\\AppData\\Local\\Temp\\arduino\\sketches\\48629FD1D5845F21FB7469EFC7BFC69A/core" -c "@C:\\Users\\Usuario\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.1/tools/warnings/none-g++" -Os -g -free -fipa-pta -Werror=return-type -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10607 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_WEMOS_D1MINI\"" "-DARDUINO_BOARD_ID=\"d1_mini\"" -DFLASHMODE_DIO "-IC:\\Users\\Usuario\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.1\\cores\\esp8266" "-IC:\\Users\\Usuario\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.1\\variants\\d1_mini" "C:\\Users\\Usuario\\AppData\\Local\\Temp\\arduino\\sketches\\48629FD1D5845F21FB7469EFC7BFC69A\\sketch\\prueba_simulink.ino.cpp" -o nul
Alternatives for Filtrado_y_ponderacion_max4466.h: [Filtrado_y_ponderacion_max4466_grt_rtw]
ResolveLibrary(Filtrado_y_ponderacion_max4466.h)
-> candidates: [Filtrado_y_ponderacion_max4466_grt_rtw]
"C:\\Users\\Usuario\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 "@C:\\Users\\Usuario\\AppData\\Local\\Temp\\arduino\\sketches\\48629FD1D5845F21FB7469EFC7BFC69A/core/build.opt" "-IC:\\Users\\Usuario\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.1/tools/sdk/include" "-IC:\\Users\\Usuario\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.1/tools/sdk/lwip2/include" "-IC:\\Users\\Usuario\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.1/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\Usuario\\AppData\\Local\\Temp\\arduino\\sketches\\48629FD1D5845F21FB7469EFC7BFC69A/core" -c "@C:\\Users\\Usuario\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.1/tools/warnings/none-g++" -Os -g -free -fipa-pta -Werror=return-type -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10607 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_WEMOS_D1MINI\"" "-DARDUINO_BOARD_ID=\"d1_mini\"" -DFLASHMODE_DIO "-IC:\\Users\\Usuario\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.1\\cores\\esp8266" "-IC:\\Users\\Usuario\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.1\\variants\\d1_mini" "-Ic:\\Users\\Usuario\\Documents\\Arduino\\libraries\\Filtrado_y_ponderacion_max4466_grt_rtw" "C:\\Users\\Usuario\\AppData\\Local\\Temp\\arduino\\sketches\\48629FD1D5845F21FB7469EFC7BFC69A\\sketch\\prueba_simulink.ino.cpp" -o nul
Alternatives for windows.h: []
ResolveLibrary(windows.h)
-> candidates: []
c:\Users\Usuario\Documents\Arduino\libraries\Filtrado_y_ponderacion_max4466_grt_rtw/DAHostLib_rtw.h:12:12: fatal error: windows.h: No such file or directory
12 | # include <windows.h>
Using library Filtrado_y_ponderacion_max4466_grt_rtw in folder: C:\Users\Usuario\Documents\Arduino\libraries\Filtrado_y_ponderacion_max4466_grt_rtw (legacy)
exit status 1
since I don't use Simulink or really know what sort of zip file it is generating, I really can't help any more. It looks an awful lot like you are trying to build something for Windows (the windows.h file) but that doesn't have anything to do with and ESP8266 or any AVR boards.
