SingleTact sensor
Hi, I used singleTact sensor for my project, It perfectly works with Arduino, and its a demo application. the problem is I can not print data in serial (by serial.print()) in Arduino code. there is code from the company which works perfectly with their software (windows app).
Please help to print data in the serial monitor without using the company software.
Thanks
here is the code:
// Copyright (c) 2015 Pressure Profile Systems
// Licensed under the MIT license. This file may not be copied, modified, or
// distributed except according to those terms.
#include <Wire.h> //For I2C/SMBus
#include <Timer1.h> //For timestamp
#define CMD_READ 0x01
#define CMD_WRITE 0x02
#define CMD_TOGGLE_GPIO 0x03
#define CMD_WRITE_CAL 0x04
#define TOGGLE_ALL 0x08
#define TOGGLE_NONE 0x00
//Constants
//General I2C packet structure
const byte I2C_HEADER1 = 0;
const byte I2C_HEADER2 = 1;
const byte I2C_HEADER3 = 2;
const byte I2C_HEADER4 = 3;
const byte I2C_ADDRESS_BYTE = 4;
const byte I2C_TIMOUT_BYTE = 5;
const byte I2C_ID_BYTE = 6;
const byte I2C_NUM_FOOTER_BYTES = 4;
const byte I2C_TO_SENSOR_BUFFER_LENGTH = 32;
const byte I2C_TIMEOUT = 100; //100ms
//From PC
const byte I2C_FROMPC_CMD = 7;
const byte I2C_FROMPC_READWRITE_LOCATION = 8;
const byte I2C_FROMPC_NUM_BYTES_TO_READWRITE = 9;
const byte SERIAL_FROMPC_BUFFER_LENGTH = 43;
const byte MINIMUM_FROMPC_PACKETLENGTH = 13; //I2C_FROMPC_NUM_BYTES_TO_READWRITE + 4 footer bytes
//To PC
const byte I2C_TOPC_TIMESTAMP = 7;
const byte I2C_TOPC_NBYTES = 11;
const byte SERIAL_TOPC_BUFFER_LENGTH = 77;
// Pin 13 has an LED connected.
int led = 13;
// Pin 2, 3, 4, 5, 6, 7 are reserved for Power Line
int singleTact1 = 2;
int singleTact2 = 3;
int singleTact3 = 4;
int singleTact4 = 5;
int singleTact5 = 6;
int singleTact6 = 7;
//From Arduino to sensor
byte outgoingI2CBuffer[I2C_TO_SENSOR_BUFFER_LENGTH];
//From Arduino to PC host
byte serialToPCBuffer[SERIAL_TOPC_BUFFER_LENGTH];
byte serialToPCBufferIndex_ = 0;
//From PC host to Arduino
byte serialIncomingBuffer[SERIAL_FROMPC_BUFFER_LENGTH];
byte serialIncomingBufferIndex_ = 0;
unsigned long timeStamp_;
//Zero a buffer
void BlankBuffer(byte* buffer, byte length)
for(int i = 0; i < length; i++)
buffer[i] = 0;
void ResetSerialBuffer()
for(int i = 0; i < SERIAL_FROMPC_BUFFER_LENGTH; i++)
serialIncomingBuffer[i] = 0;
int i;
Wire.begin(); // join i2c bus (address optional for master)
pinMode(led, OUTPUT);
Serial.begin(115200); // start serial for output
//Serial.flush();
pinMode(singleTact1, OUTPUT);
pinMode(singleTact2, OUTPUT);
pinMode(singleTact3, OUTPUT);
pinMode(singleTact4, OUTPUT);
pinMode(singleTact5, OUTPUT);
pinMode(singleTact6, OUTPUT);
BlankBuffer(outgoingI2CBuffer, I2C_TO_SENSOR_BUFFER_LENGTH);
//Never changes, so just set now
serialToPCBuffer[I2C_HEADER1] = 0xFF;
serialToPCBuffer[I2C_HEADER2] = 0xFF;
serialToPCBuffer[I2C_HEADER3] = 0xFF;
serialToPCBuffer[I2C_HEADER4] = 0xFF;
digitalWrite(led, HIGH);
timeStamp_ = 0;
startTimer1(100); //Timer for timestamp
//Check the full footer
boolean Checkfooter(int endOfPacket)
for(int i = 0; i < 4; i++)
if(serialIncomingBuffer[endOfPacket - i] != 0xFE)
return false; //Footer corrupt
return true; //Footer all good
//Check available header bytes (called as each one comes in, building upto 4)
boolean Checkheader(int checkMaxIndex)
for(int j = 0; j <= checkMaxIndex && j < 4; j ++)
if(serialIncomingBuffer[j] != 0xFF)
return false; //Header corrupt
return true; //Header all good
//Returns true if we have a new serial data packet, otherwise returns false
//Corrupt data is removed from buffer
boolean ProcessIncomingSerialData()
byte i2cPacketLength; //Working variable
if(Serial.available() > 0)
//Read the new byte
serialIncomingBuffer[serialIncomingBufferIndex_] = Serial.read();
//No new data
return false;
if(false == Checkheader(serialIncomingBufferIndex_))
ResetSerialBuffer(); //Header not correct, reset buffer
return false;
//Do we have enough data to process
if(serialIncomingBufferIndex_ >MINIMUM_FROMPC_PACKETLENGTH)
if(CMD_READ == serialIncomingBuffer[I2C_FROMPC_CMD])
i2cPacketLength = 0;
i2cPacketLength = serialIncomingBuffer[I2C_FROMPC_NUM_BYTES_TO_READWRITE];
//Do we have a full packet
if(serialIncomingBufferIndex_ >= (i2cPacketLength + MINIMUM_FROMPC_PACKETLENGTH + 1))
  if(Checkfooter(serialIncomingBufferIndex_))
    //We have a good packet
    return true;
    //Corrupt packet, reset
    return false;
//We have run out of buffer space - something has gone wrong, so just reset the buffer
if(serialIncomingBufferIndex_ >= (SERIAL_FROMPC_BUFFER_LENGTH -1))
serialIncomingBufferIndex_++; //Move the index on
return false; //Not at the end of the packet yet
// Define the function which will handle the notifications
ISR(timer1Event)
resetTimer1();
timeStamp_++;
byte inputBuffer[43];
byte finishedPacket = false;
byte timeout = 5;
byte i = 0;
byte lengthReceived = 0;
if(ProcessIncomingSerialData())
if(CMD_WRITE == serialIncomingBuffer[I2C_FROMPC_CMD])
//We are changing settings
if(serialIncomingBuffer[I2C_FROMPC_NUM_BYTES_TO_READWRITE] > 0)
//Create return packet for the PC
serialToPCBuffer[I2C_ADDRESS_BYTE] = serialIncomingBuffer[I2C_ADDRESS_BYTE];
serialToPCBuffer[I2C_TIMOUT_BYTE] = 0; //We did not timeout
serialToPCBuffer[I2C_ID_BYTE] = serialIncomingBuffer[I2C_ID_BYTE];
serialToPCBuffer[I2C_TOPC_NBYTES] = 0; //No data, just ack
    serialToPCBuffer[I2C_TOPC_NBYTES+1] = 0xFE;
    serialToPCBuffer[I2C_TOPC_NBYTES+2] = 0xFE;
    serialToPCBuffer[I2C_TOPC_NBYTES+3] = 0xFE;
    serialToPCBuffer[I2C_TOPC_NBYTES+4] = 0xFE;
    //Transfer data
    for(int i = 0; i < serialIncomingBuffer[I2C_FROMPC_NUM_BYTES_TO_READWRITE]+4; i++)
    outgoingI2CBuffer[i] = serialIncomingBuffer[i+I2C_FROMPC_CMD];
    //Send I2C packet
    Wire.beginTransmission(serialIncomingBuffer[I2C_ADDRESS_BYTE]); // transmit to device
    Wire.write(outgoingI2CBuffer, I2C_TO_SENSOR_BUFFER_LENGTH);
    Wire.endTransmission();    // stop transmitting
    //Send serial ack to PC
    for(int i = 0; i < (I2C_TOPC_NBYTES+5); i++)
    Serial.write(serialToPCBuffer[i]);
else if(CMD_READ == serialIncomingBuffer[I2C_FROMPC_CMD])
  byte i2cPacketLength = serialIncomingBuffer[I2C_FROMPC_NUM_BYTES_TO_READWRITE];
  serialToPCBuffer[I2C_TOPC_NBYTES] = i2cPacketLength;
  serialToPCBuffer[I2C_TOPC_TIMESTAMP] = (timeStamp_ >> 24);
  serialToPCBuffer[I2C_TOPC_TIMESTAMP + 1 ] = (timeStamp_ >> 16) & 0xFF;
  serialToPCBuffer[I2C_TOPC_TIMESTAMP + 2 ] = (timeStamp_ >> 8) & 0xFF;
  serialToPCBuffer[I2C_TOPC_TIMESTAMP + 3 ] = timeStamp_ & 0xFF;
  //Perform I2C Read
  outgoingI2CBuffer[0] = CMD_READ;
  outgoingI2CBuffer[1] = serialIncomingBuffer[I2C_FROMPC_READWRITE_LOCATION];
  outgoingI2CBuffer[2] = serialIncomingBuffer[I2C_FROMPC_NUM_BYTES_TO_READWRITE];
  //Send I2C packet
  Wire.write(outgoingI2CBuffer, 3); //Only requires 3 bytes
  Wire.requestFrom(serialIncomingBuffer[I2C_ADDRESS_BYTE], serialIncomingBuffer[I2C_FROMPC_NUM_BYTES_TO_READWRITE]);
  //Parse request
  int i = 0;
  int i2cTimeout = I2C_TIMEOUT; //1s
  while( i < i2cPacketLength && i2cTimeout > 0)    // slave may send less than requested
    if(Wire.available())
      serialToPCBuffer[I2C_TOPC_NBYTES + 1 + i] = Wire.read(); // receive a byte as character
      i++;
      delay(1); //Wait 1ms
      i2cTimeout--;
  if(0 == timeout)
    serialToPCBuffer[I2C_TIMOUT_BYTE] = 1;
  //Add footer
  serialToPCBuffer[I2C_TOPC_NBYTES + 1 + i2cPacketLength] = 0xFE;
  serialToPCBuffer[I2C_TOPC_NBYTES + 2 + i2cPacketLength] = 0xFE;
  serialToPCBuffer[I2C_TOPC_NBYTES + 3 + i2cPacketLength] = 0xFE;
  serialToPCBuffer[I2C_TOPC_NBYTES + 4 + i2cPacketLength] = 0xFE;
  //Send to PC
  for(int i = 0; i < (I2C_TOPC_NBYTES + 5 + i2cPacketLength); i++)
// Transmit the Calibration Data to the Interface Board
if(CMD_WRITE_CAL == serialIncomingBuffer[I2C_FROMPC_CMD])
    //Transfer data
    //Send I2C packet
// Toggle the GPIO Pin to set the I2C address when doing Calibration test
else if (CMD_TOGGLE_GPIO == serialIncomingBuffer[I2C_FROMPC_CMD])
  int toggle = serialToPCBuffer[I2C_FROMPC_CMD+1];
  if (TOGGLE_ALL == serialIncomingBuffer[I2C_FROMPC_CMD+1])
    digitalWrite(singleTact1, HIGH);
    digitalWrite(singleTact2, HIGH);
    digitalWrite(singleTact3, HIGH);
    digitalWrite(singleTact4, HIGH);
    digitalWrite(singleTact5, HIGH);
    digitalWrite(singleTact6, HIGH);
  else if (TOGGLE_NONE == serialIncomingBuffer[I2C_FROMPC_CMD+1])
    digitalWrite(singleTact1, LOW);
    digitalWrite(singleTact2, LOW);
    digitalWrite(singleTact3, LOW);
    digitalWrite(singleTact4, LOW);
    digitalWrite(singleTact5, LOW);
    digitalWrite(singleTact6, LOW);
    delay(50);
    Wire.begin();
    digitalWrite(serialIncomingBuffer[I2C_FROMPC_CMD+1], HIGH);
    Serial.print("T");
ResetSerialBuffer();  //Reset and wait for next command
Hello, do yourself a favour and please read How to get the best out of this forum and modify your post accordingly (including code tags and necessary documentation of your ask).
thanks
