I mam trying to change the default sketch when I create a new file. I opened the settings and went to Sketch:Ino Blueprint, and changed it to the the copied path to my desired sketch, which is just sitting in the main folder. I tried both with and without quotation marks, I reinstalled the IDE, but no matter what I do, it just completely ignores that setting and opens the standard default sketch when I try to create a new file. Does anyone have any advice on how to fix this? it is driving me insane.
Did you put the full path to your desired blueprint .ino file into the Arduino > Sketch:Ino Blueprint dialogue ? No quotation marks should be used
Note that the text for the dialogue says
Absolute filesystem path to the default
.inoblueprint file. If specified, the content of the blueprint file will be used for every new sketch created by the IDE. The sketches will be generated with the default Arduino content if not specified. Unaccessible blueprint files are ignored. A restart of the IDE is needed for this setting to take effect.
Did you only read the title? Yes, I did it without quotation marks. I also tried with, just in case that changed anything. I restarted the IDE every time. The path is C:\Users\omnia\Documents\Arduino\blank\blank.ino
No. I read your whole post, which is why I confirmed that you should not use quotation marks. I asked about the path because it was not clear from your post whether you had used the full path or not
Ok then. Do you have any suggestions on how to fix this?
Hi @omnia_et_nihil. I'm going to ask you to provide some additional information that might help us to identify the problem.
This procedure is not intended to solve the problem. The purpose is to gather more information.
Please do this:
- Select File > Quit from the Arduino IDE menus if it is running.
All Arduino IDE windows will close. - Start Windows "File Explorer".
- Open the Arduino IDE installation folder.
ⓘ The default installation location is at one of the following paths:-
C:\Program Files\Arduino IDE -
(whereC:\Users\<username>\AppData\Local\Programs\Arduino IDE<username>is your Windows username)
If looking for it with your file manager or command line, note that the AppDatafolder is hidden by default. On Windows "File Explorer", you can make it visible by opening the "View" menu, then checking the box next to "☐ Hidden items".
- In the folder listing of the Arduino IDE installation folder, hold the Shift key while clicking the right hand button on the mouse.
A context menu will open. - Select "Open PowerShell window here" from the menu.
Windows PowerShell will now open with the current directory set to the Arduino IDE installation folder. - Type the following command:
& ".\Arduino IDE" - Press the Enter key.
Debug output should now be printed to the PowerShell window as Arduino IDE starts. - Wait for Arduino IDE to finish starting.
- Select File > New Sketch from the Arduino IDE menus.
- Verify that the new sketch that was created has the default contents instead of the custom contents you expect from your "Arduino › Sketch: Ino Blueprint" setting.
- Switch back to the PowerShell window.
- Press the Ctrl+Shift+A keyboard shortcut.
This will select all the text in the PowerShell window. - Press the Ctrl+C keyboard shortcut.
This will copy the contents of the PowerShell window to the clipboard. - Open a forum reply here by clicking the "Reply" button.
- Click the
<CODE/>icon on the post composer toolbar.
This will add the forum's code block markup (```) to your reply to make sure the error messages are correctly formatted.
- Press the Ctrl+V keyboard shortcut.
This will paste the output into the code block. - Move the cursor outside of the code block markup before you add any additional text to your reply.
- Click the "Reply" button to post the output.
Please let me know if you have any questions or problems while following those instructions.
This fails at step 6. I get the following output
& : The term '.\Arduino IDE' is not recognized as the name of a cmdlet, function, script file, or operable program.
Check the spelling of the name, or if a path was included, verify that the path is correct and try again.
At line:1 char:3
+ & ".\Arduino IDE"
+ CategoryInfo : ObjectNotFound: (.\Arduino IDE:String) [], CommandNotFoundException
+ FullyQualifiedErrorId : CommandNotFoundException
This error means that you did not open the PowerShell terminal in the Arduino IDE installation folder.
Make sure to carefully follow steps (3) and (4) from my instructions.
At step (3), check to be sure the folder contains file named Arduino IDE.exe (File Explorer might only show the name as Arduino IDE). If you can't find the Arduino IDE installation folder, let us know and we'll try to provide further assistance.
I can see from this part of your screenshot that Windows fails to open the PowerShell terminal in the Arduino IDE installation folder:
PowerShell falls back on instead opening the terminal in the C:\Windows\system32 folder. This is the reason why step (6) in my instructions fail.
Apparently Windows is not quoting the path when it passes it to PowerShell. Such quoting is essential in this case because the Arduino IDE folder name contains a space.
It seems there is some problem with the configuration of your system because the instructions I provided work fine for me, and for the many other people I have used these instructions to support. For now we can simply work around the problem. Please try following these modified instructions:
Please do this:
- Open the Arduino IDE installation folder:
C:\Users\ziad\AppData\Local\Programs\Arduino IDE - In the folder listing of the Arduino IDE installation folder, hold the Shift key while clicking the right hand button on the mouse.
cd "C:\Users\ziad\AppData\Local\Programs\Arduino IDE" - Press the Enter key.
- Click the
Sorry for the late response. Life got busy. Still having the issue though. Character limit forced me to put this in two parts.
Set-Location : A positional parameter cannot be found that accepts argument 'IDE'.
At line:1 char:1
+ Set-Location -literalPath C:\Users\ziad\AppData\Local\Programs\Arduin ...
+ CategoryInfo : InvalidArgument: (:) [Set-Location], ParameterBindingException
+ FullyQualifiedErrorId : PositionalParameterNotFound,Microsoft.PowerShell.Commands.SetLocationCommand
PS C:\Windows\system32> cd "C:\Users\ziad\AppData\Local\Programs\Arduino IDE"
PS C:\Users\ziad\AppData\Local\Programs\Arduino IDE> & ".\Arduino IDE"
Arduino IDE 2.3.6
Checking for frontend application configuration customizations. Module path: C:\Users\ziad\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\electron-main.js, destination 'package.json': C:\Users\ziad\AppData\Local\Programs\Arduino IDE\resources\app\package.json
Setting 'theia.frontend.config.appVersion' application configuration value to: "2.3.6" (type of string)
Setting 'theia.frontend.config.cliVersion' application configuration value to: "1.2.0" (type of string)
Setting 'theia.frontend.config.buildDate' application configuration value to: "2025-04-09T11:26:55.498Z" (type of string)
Frontend application configuration after modifications: {"applicationName":"Arduino IDE","defaultTheme":{"light":"arduino-theme","dark":"arduino-theme-dark"},"defaultIconTheme":"none","electron":{"windowOptions":{},"showWindowEarly":true,"splashScreenOptions":{},"uriScheme":"arduino-ide"},"defaultLocale":"","validatePreferencesSchema":false,"reloadOnReconnect":true,"uriScheme":"theia","preferences":{"window.title":"${rootName}${activeEditorShort}${appName}","files.autoSave":"afterDelay","editor.minimap.enabled":false,"editor.tabSize":2,"editor.scrollBeyondLastLine":false,"editor.quickSuggestions":{"other":false,"comments":false,"strings":false},"editor.maxTokenizationLineLength":500,"editor.bracketPairColorization.enabled":false,"breadcrumbs.enabled":false,"workbench.tree.renderIndentGuides":"none","explorer.compactFolders":false},"appVersion":"2.3.6","cliVersion":"1.2.0","buildDate":"2025-04-09T11:26:55.498Z"}
Starting backend process. PID: 33024
Showing main window early
Using browser-only version of superagent in non-browser environment
Configuration directory URI: 'file:///c%3A/Users/ziad/.arduinoIDE'
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2025-04-24T16:09:33.022Z root INFO Backend u.initialize: 13.1 ms [Finished 0.278 s after backend start]
2025-04-24T16:09:33.023Z root INFO Backend Object.initialize: 12.3 ms [Finished 0.278 s after backend start]
2025-04-24T16:09:33.023Z root INFO Backend a.initialize: 0.9 ms [Finished 0.278 s after backend start]
2025-04-24T16:09:33.023Z root INFO Backend a.initialize: 0.8 ms [Finished 0.278 s after backend start]
2025-04-24T16:09:33.023Z root INFO Backend u.initialize: 0.9 ms [Finished 0.279 s after backend start]
2025-04-24T16:09:33.024Z root INFO Backend l.initialize: 13.0 ms [Finished 0.279 s after backend start]
2025-04-24T16:09:33.028Z root INFO configured all backend app contributions
2025-04-24T16:09:33.028Z root INFO Backend l.onStart: 0.6 ms [Finished 0.284 s after backend start]
2025-04-24T16:09:33.028Z root INFO Backend d.onStart: 0.1 ms [Finished 0.284 s after backend start]
2025-04-24T16:09:33.028Z root INFO Backend a.onStart: 0.1 ms [Finished 0.284 s after backend start]
2025-04-24T16:09:33.028Z config INFO >>> Initializing CLI configuration...
2025-04-24T16:09:33.028Z root INFO Backend x.onStart: 0.2 ms [Finished 0.285 s after backend start]
2025-04-24T16:09:33.028Z config INFO Loading CLI configuration from c:\Users\ziad\.arduinoIDE\arduino-cli.yaml...
2025-04-24T16:09:33.028Z daemon INFO Starting daemon from C:\Users\ziad\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2025-04-24T16:09:33.028Z root INFO Backend w.onStart: 0.1 ms [Finished 0.285 s after backend start]
2025-04-24T16:09:33.028Z discovery-log INFO start
2025-04-24T16:09:33.028Z discovery-log INFO start new deferred
2025-04-24T16:09:33.028Z root INFO Backend v.onStart: 0.1 ms [Finished 0.285 s after backend start]
2025-04-24T16:09:33.028Z root INFO Backend a.onStart: 0.0 ms [Finished 0.285 s after backend start]
2025-04-24T16:09:33.031Z root INFO Theia app listening on http://127.0.0.1:54171.
2025-04-24T16:09:33.031Z root INFO Finished starting backend application: 2.2 ms [Finished 0.287 s after backend start]
Restoring workspace roots: c:\Users\ziad\Documents\Arduino\Fencing\Auto Tracker\P3\AT_P3_Controller,c:\Users\ziad\Documents\Arduino\Fencing\Utility module\remote_adapter
2025-04-24T16:09:33.031Z root WARN The local plugin referenced by local-dir:/c%3A/Users/ziad/.arduinoIDE/plugins does not exist.
2025-04-24T16:09:33.031Z root WARN The local plugin referenced by local-dir:/c%3A/Users/ziad/.arduinoIDE/deployedPlugins does not exist.
2025-04-24T16:09:33.031Z root WARN The local plugin referenced by local-dir:C:\Users\ziad\.arduinoIDE\plugins does not exist.
2025-04-24T16:09:33.033Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":["https://files.seeedstudio.com/arduino/package_seeeduino_boards_index.json","https://raw.githubusercontent.com/espressif/arduino-esp32/gh-pages/package_esp32_index.json"]},"directories":{"builtin":{"libraries":"C:\\Users\\ziad\\AppData\\Local\\Arduino15\\libraries"},"data":"c:\\Users\\ziad\\AppData\\Local\\Arduino15","user":"c:\\Users\\ziad\\Documents\\Arduino"},"locale":"en"}
2025-04-24T16:09:33.033Z config INFO 'directories.data' and 'directories.user' are set in the CLI configuration model.
2025-04-24T16:09:33.033Z config INFO Loaded the CLI configuration.
isTempSketch: false. Input was c:\Users\ziad\Documents\Arduino\Fencing\Auto Tracker\P3\AT_P3_Controller\AT_P3_Controller.ino
2025-04-24T16:09:33.038Z root ERROR Detected JSONC parser errors:
2025-04-24T16:09:33.038Z root ERROR ----- CONTENT START -----
2025-04-24T16:09:33.038Z root ERROR {
"window.titleBarStyle": "native",
"workbench.colorTheme": "arduino-theme-dark",
"editor.fontSize": 14,
"files.autoSave": "afterDelay",
"editor.quickSuggestions": {
"other": false,
"comments": false,
"strings": false
"arduino.window.autoScale": true,
"window.zoomLevel": 0,
"arduino.compile.verbose": false,
"arduino.compile.warnings": "Default",
"arduino.upload.verbose": true,
"arduino.upload.verify": false,
"arduino.sketchbook.showAllFiles": false,
"editor.bracketPairColorization.enabled": true,
"editor.autoClosingBrackets": "never",
"arduino.sketch.inoBlueprint": "C:\\Users\\ziad\\Documents\\Arduino\\blank\\blank.ino",
"editor.foldingImportsByDefault": true
}#in
2025-04-24T16:09:33.038Z root ERROR ----- CONTENT END -----
2025-04-24T16:09:33.038Z root ERROR - InvalidSymbol at 739
2025-04-24T16:09:33.039Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///c%3A/Users/ziad/AppData/Local/Arduino15","sketchDirUri":"file:///c%3A/Users/ziad/Documents/Arduino","additionalUrls":["https://files.seeedstudio.com/arduino/package_seeeduino_boards_index.json","https://raw.githubusercontent.com/espressif/arduino-esp32/gh-pages/package_esp32_index.json"],"network":"none","locale":"en"}
2025-04-24T16:09:33.039Z config INFO Validating the CLI configuration...
2025-04-24T16:09:33.039Z config INFO The CLI config is valid.
2025-04-24T16:09:33.039Z config INFO <<< Initialized the CLI configuration.
isTempSketch: false. Input was c:\Users\ziad\Documents\Arduino\Fencing\Utility module\remote_adapter\remote_adapter.ino
2025-04-24T16:09:33.059Z root INFO Resolve plugins list: 30.2 ms [Finished 0.316 s after backend start]
2025-04-24T16:09:33.079Z daemon INFO time="2025-04-24T09:09:33-07:00" level=info msg="arduino-cli version 1.2.0"
2025-04-24T16:09:33.089Z daemon INFO time="2025-04-24T09:09:33-07:00" level=info msg="Using config file: c:\\Users\\ziad\\.arduinoIDE\\arduino-cli.yaml"
time="2025-04-24T09:09:33-07:00" level=info msg="Executing `arduino-cli daemon`"
Daemon is now listening on 127.0.0.1:54172
{"IP":"127.0.0.1","Port":"54172"}
2025-04-24T16:09:33.089Z daemon INFO Daemon is running.
2025-04-24T16:09:33.110Z daemon INFO time="2025-04-24T09:09:33-07:00" level=info msg="Checking signature" index="c:\\Users\\ziad\\AppData\\Local\\Arduino15\\package_index.json" signatureFile="c:\\Users\\ziad\\AppData\\Local\\Arduino15\\package_index.json.sig" trusted=true
time="2025-04-24T09:09:33-07:00" level=info msg="Missing signature file" index="c:\\Users\\ziad\\AppData\\Local\\Arduino15\\package_seeeduino_boards_index.json"
time="2025-04-24T09:09:33-07:00" level=info msg="Missing signature file" index="c:\\Users\\ziad\\AppData\\Local\\Arduino15\\package_esp32_index.json"
time="2025-04-24T09:09:33-07:00" level=info msg="Loading hardware from: c:\\Users\\ziad\\AppData\\Local\\Arduino15\\packages"
time="2025-04-24T09:09:33-07:00" level=info msg="Loading package Seeeduino from: C:\\Users\\ziad\\AppData\\Local\\Arduino15\\packages\\Seeeduino\\hardware"
time="2025-04-24T09:09:33-07:00" level=info msg="Missing signature file" index="C:\\Users\\ziad\\AppData\\Local\\Arduino15\\packages\\Seeeduino\\hardware\\mbed\\2.9.3\\installed.json"
time="2025-04-24T09:09:33-07:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2025-04-24T09:09:33-07:00" level=info msg="Loaded platform" platform="Seeeduino:mbed@2.9.3"
time="2025-04-24T09:09:33-07:00" level=info msg="Missing signature file" index="C:\\Users\\ziad\\AppData\\Local\\Arduino15\\packages\\Seeeduino\\hardware\\nrf52\\1.1.10\\installed.json"
2025-04-24T16:09:33.111Z daemon INFO time="2025-04-24T09:09:33-07:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2025-04-24T09:09:33-07:00" level=info msg="Loaded platform" platform="Seeeduino:nrf52@1.1.10"
time="2025-04-24T09:09:33-07:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\ziad\\AppData\\Local\\Arduino15\\packages\\Seeeduino\\tools"
time="2025-04-24T09:09:33-07:00" level=info msg="Loading tools from dir: C:\\Users\\ziad\\AppData\\Local\\Arduino15\\packages\\Seeeduino\\tools"
time="2025-04-24T09:09:33-07:00" level=info msg="Loaded tool" tool="Seeeduino:CMSIS@5.7.0"
2025-04-24T16:09:33.111Z daemon INFO time="2025-04-24T09:09:33-07:00" level=info msg="Loaded tool" tool="Seeeduino:arm-none-eabi-gcc@7-2017q4"
time="2025-04-24T09:09:33-07:00" level=info msg="Loaded tool" tool="Seeeduino:arm-none-eabi-gcc@9-2019q4"
2025-04-24T16:09:33.111Z daemon INFO time="2025-04-24T09:09:33-07:00" level=info msg="Loaded tool" tool="Seeeduino:bossac@1.9.1-arduino2"
2025-04-24T16:09:33.111Z daemon INFO time="2025-04-24T09:09:33-07:00" level=info msg="Loaded tool" tool="Seeeduino:dfu-util@0.10.0-arduino1"
2025-04-24T16:09:33.111Z daemon INFO time="2025-04-24T09:09:33-07:00" level=info msg="Loaded tool" tool="Seeeduino:nrfjprog@9.4.0"
2025-04-24T16:09:33.112Z daemon INFO time="2025-04-24T09:09:33-07:00" level=info msg="Loaded tool" tool="Seeeduino:openocd@0.11.0-arduino2"
2025-04-24T16:09:33.112Z daemon INFO time="2025-04-24T09:09:33-07:00" level=info msg="Loading package arduino from: C:\\Users\\ziad\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware"
2025-04-24T16:09:33.117Z daemon INFO time="2025-04-24T09:09:33-07:00" level=info msg="Missing signature file" index="C:\\Users\\ziad\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\installed.json"
time="2025-04-24T09:09:33-07:00" level=info msg="Loaded platform" platform="arduino:avr@1.8.6"
time="2025-04-24T09:09:33-07:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\ziad\\AppData\\Local\\Arduino15\\packages\\arduino\\tools"
time="2025-04-24T09:09:33-07:00" level=info msg="Loading tools from dir: C:\\Users\\ziad\\AppData\\Local\\Arduino15\\packages\\arduino\\tools"
time="2025-04-24T09:09:33-07:00" level=info msg="Loaded tool" tool="arduino:arduinoOTA@1.3.0"
time="2025-04-24T09:09:33-07:00" level=info msg="Loaded tool" tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
time="2025-04-24T09:09:33-07:00" level=info msg="Loaded tool" tool="arduino:avrdude@6.3.0-arduino17"
time="2025-04-24T09:09:33-07:00" level=info msg="Loaded tool" tool="arduino:dfu-util@0.11.0-arduino5"
2025-04-24T16:09:33.121Z daemon INFO time="2025-04-24T09:09:33-07:00" level=info msg="Loading package builtin from: C:\\Users\\ziad\\AppData\\Local\\Arduino15\\packages\\builtin"
time="2025-04-24T09:09:33-07:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\ziad\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
time="2025-04-24T09:09:33-07:00" level=info msg="Loading tools from dir: C:\\Users\\ziad\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
time="2025-04-24T09:09:33-07:00" level=info msg="Loaded tool" tool="builtin:ctags@5.8-arduino11"
time="2025-04-24T09:09:33-07:00" level=info msg="Loaded tool" tool="builtin:dfu-discovery@0.1.2"
time="2025-04-24T09:09:33-07:00" level=info msg="Loaded tool" tool="builtin:mdns-discovery@1.0.9"
time="2025-04-24T09:09:33-07:00" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.4.1"
time="2025-04-24T09:09:33-07:00" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.14.1"
time="2025-04-24T09:09:33-07:00" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.15.0"
time="2025-04-24T09:09:33-07:00" level=info msg="Loading package esp32 from: C:\\Users\\ziad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware"
time="2025-04-24T09:09:33-07:00" level=info msg="Missing signature file" index="C:\\Users\\ziad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.1.3\\installed.json"
2025-04-24T16:09:33.172Z daemon INFO time="2025-04-24T09:09:33-07:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2025-04-24T09:09:33-07:00" level=info msg="Loaded platform" platform="esp32:esp32@3.1.3"
2025-04-24T16:09:33.172Z daemon INFO time="2025-04-24T09:09:33-07:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\ziad\\AppData\\Local\\Arduino15\\packages\\esp32\\tools"
time="2025-04-24T09:09:33-07:00" level=info msg="Loading tools from dir: C:\\Users\\ziad\\AppData\\Local\\Arduino15\\packages\\esp32\\tools"
2025-04-24T16:09:33.178Z daemon INFO time="2025-04-24T09:09:33-07:00" level=info msg="Loaded tool" tool="esp32:esp-rv32@2405"
time="2025-04-24T09:09:33-07:00" level=info msg="Loaded tool" tool="esp32:esp-x32@2405"
time="2025-04-24T09:09:33-07:00" level=info msg="Loaded tool" tool="esp32:esp32-arduino-libs@idf-release_v5.3-489d7a2b-v1"
time="2025-04-24T09:09:33-07:00" level=info msg="Loaded tool" tool="esp32:esptool_py@4.9.dev3"
time="2025-04-24T09:09:33-07:00" level=info msg="Loaded tool" tool="esp32:mklittlefs@3.0.0-gnu12-dc7f933"
time="2025-04-24T09:09:33-07:00" level=info msg="Loaded tool" tool="esp32:mkspiffs@0.2.3"
time="2025-04-24T09:09:33-07:00" level=info msg="Loaded tool" tool="esp32:openocd-esp32@v0.12.0-esp32-20241016"
time="2025-04-24T09:09:33-07:00" level=info msg="Loaded tool" tool="esp32:riscv32-esp-elf-gdb@14.2_20240403"
time="2025-04-24T09:09:33-07:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp-elf-gdb@14.2_20240403"
2025-04-24T16:09:33.184Z daemon INFO time="2025-04-24T09:09:33-07:00" level=info msg="Adding libraries dir" dir="C:\\Users\\ziad\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries" isSingleLibrary=false location=platform
time="2025-04-24T09:09:33-07:00" level=info msg="Adding libraries dir" dir="C:\\Users\\ziad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.1.3\\libraries" isSingleLibrary=false location=platform
2025-04-24T16:09:33.190Z daemon INFO time="2025-04-24T09:09:33-07:00" level=info msg="Adding libraries dir" dir="C:\\Users\\ziad\\AppData\\Local\\Arduino15\\packages\\Seeeduino\\hardware\\nrf52\\1.1.10\\libraries" isSingleLibrary=false location=platform
time="2025-04-24T09:09:33-07:00" level=info msg="Adding libraries dir" dir="C:\\Users\\ziad\\AppData\\Local\\Arduino15\\packages\\Seeeduino\\hardware\\mbed\\2.9.3\\libraries" isSingleLibrary=false location=platform
time="2025-04-24T09:09:33-07:00" level=info msg="Loading libraries index file" index="c:\\Users\\ziad\\AppData\\Local\\Arduino15\\library_index.json"
2025-04-24T16:09:33.294Z root INFO Deploy plugins list: 265.1 ms [Finished 0.551 s after backend start]
2025-04-24T16:09:33.296Z daemon INFO time="2025-04-24T09:09:33-07:00" level=info msg="Adding libraries dir" dir="C:\\Users\\ziad\\AppData\\Local\\Arduino15\\libraries" isSingleLibrary=false location=ide
2025-04-24T16:09:33.298Z daemon INFO time="2025-04-24T09:09:33-07:00" level=info msg="Adding libraries dir" dir="c:\\Users\\ziad\\Documents\\Arduino\\libraries" isSingleLibrary=false location=user
2025-04-24T16:09:33.889Z root INFO creating connection for 1
2025-04-24T16:09:33.890Z root INFO creating connection for 2
2025-04-24T16:09:34.288Z root WARN A command editor.action.toggleStickyScroll is already registered.
2025-04-24T16:09:34.289Z root WARN A command editor.action.toggleStickyScroll is already registered.
Opening channel for service path '/services/electron-window'.
Opening channel for service path '/services/ide-updater'.
2025-04-24T16:09:34.335Z root INFO Start frontend contributions: 138.2 ms [Finished 1.294 s after frontend start]
2025-04-24T16:09:34.335Z root INFO Changed application state from 'init' to 'started_contributions'.
2025-04-24T16:09:34.342Z root INFO Start frontend contributions: 137.6 ms [Finished 1.281 s after frontend start]
2025-04-24T16:09:34.342Z root INFO Changed application state from 'init' to 'started_contributions'.
2025-04-24T16:09:34.342Z root INFO Changed application state from 'started_contributions' to 'attached_shell'.
2025-04-24T16:09:34.342Z root INFO >>> Restoring the layout state...
2025-04-24T16:09:34.356Z root INFO [8514ef7d-1035-423c-94c2-e30e5e0ba2f4] Waiting for backend deployment: 26.5 ms [Finished 1.319 s after frontend start]
2025-04-24T16:09:34.357Z root INFO [bfc8c407-056c-4f84-b319-d1b3870b4a2b] Waiting for backend deployment: 26.2 ms [Finished 1.306 s after frontend start]
2025-04-24T16:09:34.455Z daemon INFO time="2025-04-24T09:09:34-07:00" level=warning msg="Error loading library" error="rpc error: code = Internal desc = loading library from C:\\Users\\ziad\\AppData\\Local\\Arduino15\\packages\\Seeeduino\\hardware\\mbed\\2.9.3\\libraries\\Spi_Flash: invalid library: no header files found"
2025-04-24T16:09:34.458Z discovery-log INFO start resolved watching
2025-04-24T16:09:34.803Z sketches-service WARN Warning! The request sketch path was different than the response sketch path from the CLI. This could be a potential bug. Request: <c:\Users\ziad\Documents\Arduino\Fencing\Auto Tracker\P3\AT_P3_Controller\AT_P3_Controller.ino>, response: <c:\Users\ziad\Documents\Arduino\Fencing\Auto Tracker\P3\AT_P3_Controller>.
2025-04-24T16:09:34.804Z sketches-service WARN Warning! The request sketch path was different than the response sketch path from the CLI. This could be a potential bug. Request: <c:\Users\ziad\Documents\Arduino\Fencing\Utility module\remote_adapter\remote_adapter.ino>, response: <c:\Users\ziad\Documents\Arduino\Fencing\Utility module\remote_adapter>.
2025-04-24T16:09:34.804Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"COM1","label":"COM1","protocol":"serial","protocolLabel":"Serial Port","propertiesMap":[],"hardwareId":""}},"error":""}
2025-04-24T16:09:34.804Z root INFO [hosted-plugin: 5804] PLUGIN_HOST(5804) starting instance
[Object: null prototype] {}
2025-04-24T16:09:34.804Z root INFO [hosted-plugin: 8840] PLUGIN_HOST(8840) starting instance
2025-04-24T16:09:34.959Z root INFO [8514ef7d-1035-423c-94c2-e30e5e0ba2f4] Sync of 23 plugins: 603.7 ms [Finished 1.923 s after frontend start]
2025-04-24T16:09:34.982Z root INFO ------- SERIALIZED LAYOUT DATA -------
2025-04-24T16:09:34.982Z root INFO {"version":5,"mainPanel":{"main":{"type":"tab-area","widgets":[{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///c%3A/Users/ziad/Documents/Arduino/Fencing/Auto%20Tracker/P3/AT_P3_Controller/AT_P3_Controller.ino"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":19,\"column\":5},\"position\":{\"lineNumber\":19,\"column\":5}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":1,\"column\":1},\"firstPositionDeltaTop\":0},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":48,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///c%3A/Users/ziad/Documents/Arduino/Fencing/Auto%20Tracker/P3/AT_P3_Controller/functions.h"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":true,\"selectionStart\":{\"lineNumber\":110,\"column\":35},\"position\":{\"lineNumber\":109,\"column\":37}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":19,\"column\":1},\"firstPositionDeltaTop\":-17},\"contributionsState\":{\"editor.contrib.folding\":{\"collapsedRegions\":[{\"startLineNumber\":25,\"endLineNumber\":55,\"isCollapsed\":true,\"source\":0,\"checksum\":926220},{\"startLineNumber\":59,\"endLineNumber\":82,\"isCollapsed\":true,\"source\":0,\"checksum\":545785},{\"startLineNumber\":85,\"endLineNumber\":102,\"isCollapsed\":true,\"source\":0,\"checksum\":-554183}],\"lineCount\":136,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///c%3A/Users/ziad/Documents/Arduino/Fencing/Auto%20Tracker/P3/AT_P3_Controller/pages.h"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":1,\"column\":1},\"position\":{\"lineNumber\":1,\"column\":1}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":1,\"column\":1},\"firstPositionDeltaTop\":0},\"contributionsState\":{\"editor.contrib.folding\":{\"collapsedRegions\":[{\"startLineNumber\":10,\"endLineNumber\":308,\"isCollapsed\":true,\"source\":0,\"checksum\":345910},{\"startLineNumber\":36,\"endLineNumber\":65,\"isCollapsed\":true,\"source\":0,\"checksum\":-852413},{\"startLineNumber\":67,\"endLineNumber\":68,\"isCollapsed\":true,\"source\":0,\"checksum\":479817},{\"startLineNumber\":73,\"endLineNumber\":95,\"isCollapsed\":true,\"source\":0,\"checksum\":-448071},{\"startLineNumber\":97,\"endLineNumber\":119,\"isCollapsed\":true,\"source\":0,\"checksum\":609017},{\"startLineNumber\":121,\"endLineNumber\":150,\"isCollapsed\":true,\"source\":0,\"checksum\":-162774},{\"startLineNumber\":152,\"endLineNumber\":181,\"isCollapsed\":true,\"source\":0,\"checksum\":498822}],\"lineCount\":366,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///c%3A/Users/ziad/Documents/Arduino/Fencing/Auto%20Tracker/P3/AT_P3_Controller/variables.h"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":true,\"selectionStart\":{\"lineNumber\":38,\"column\":28},\"position\":{\"lineNumber\":37,\"column\":26}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":15,\"column\":1},\"firstPositionDeltaTop\":0},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":69,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"}],"currentIndex":0}},"mainPanelPinned":[false,false,false,false],"bottomPanel":{"config":{"main":{"type":"tab-area","widgets":[{"constructionOptions":{"factoryId":"outputView"},"innerWidgetState":"{\"locked\":false}"}],"currentIndex":0}},"pinned":[false],"size":354,"expanded":false},"leftPanel":{"type":"sidepanel","items":[{"widget":{"constructionOptions":{"factoryId":"arduino-sketchbook-widget"}},"rank":1,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"boards-list-widget"}},"rank":2,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"library-list-widget"}},"rank":3,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"debug"},"innerWidgetState":"{\"parts\":[{\"partId\":\"debug:threads:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:threads\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"debug:frames:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:frames\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"debug:variables:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:variables\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"debug:watch:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:watch\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"debug:breakpoints:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:breakpoints\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"plugin-view:cortex-debug.peripherals\",\"collapsed\":true,\"hidden\":true,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"plugin-view\",\"options\":{\"id\":\"plugin-view:cortex-debug.peripherals\",\"viewId\":\"cortex-debug.peripherals\"}},\"innerWidgetState\":\"{\\\"label\\\":\\\"Cortex Peripherals\\\",\\\"widgets\\\":[],\\\"suppressUpdateViewVisibility\\\":false,\\\"currentViewContainerId\\\":\\\"debug\\\"}\"}},{\"partId\":\"plugin-view:cortex-debug.registers\",\"collapsed\":true,\"hidden\":true,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"plugin-view\",\"options\":{\"id\":\"plugin-view:cortex-debug.registers\",\"viewId\":\"cortex-debug.registers\"}},\"innerWidgetState\":\"{\\\"label\\\":\\\"Cortex Registers\\\",\\\"widgets\\\":[],\\\"suppressUpdateViewVisibility\\\":false,\\\"currentViewContainerId\\\":\\\"debug\\\"}\"}}],\"title\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}}"},"rank":4,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"search-view-container"},"innerWidgetState":"{\"parts\":[{\"partId\":\"search-in-workspace\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"search-view-container\",\"originalContainerTitle\":{\"label\":\"Search\",\"iconClass\":\"codicon codicon-search\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"search-in-workspace\"},\"innerWidgetState\":\"{\\\"matchCaseState\\\":{\\\"className\\\":\\\"codicon codicon-case-sensitive\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Match Case\\\"},\\\"wholeWordState\\\":{\\\"className\\\":\\\"codicon codicon-whole-word\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Match Whole Word\\\"},\\\"regExpState\\\":{\\\"className\\\":\\\"codicon codicon-regex\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Use Regular Expression\\\"},\\\"includeIgnoredState\\\":{\\\"className\\\":\\\"codicon codicon-eye\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Include Ignored Files\\\"},\\\"showSearchDetails\\\":false,\\\"searchInWorkspaceOptions\\\":{\\\"matchCase\\\":false,\\\"matchWholeWord\\\":false,\\\"useRegExp\\\":false,\\\"includeIgnored\\\":false,\\\"include\\\":[],\\\"exclude\\\":[],\\\"maxResults\\\":2000},\\\"searchTerm\\\":\\\"\\\",\\\"replaceTerm\\\":\\\"\\\",\\\"showReplaceField\\\":false,\\\"searchHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0},\\\"replaceHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0},\\\"includeHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0},\\\"excludeHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0}}\"}}],\"title\":{\"label\":\"Search\",\"iconClass\":\"fa fa-arduino-search\",\"closeable\":true}}"},"rank":5,"expanded":false,"pinned":false}],"size":367},"rightPanel":{"type":"sidepanel","items":[]}}
2025-04-24T16:09:34.982Z root INFO ------- END SERIALIZED LAYOUT DATA -------
2025-04-24T16:09:35.120Z root INFO [bfc8c407-056c-4f84-b319-d1b3870b4a2b] Sync of 23 plugins: 765.3 ms [Finished 2.071 s after frontend start]
2025-04-24T16:09:35.139Z root INFO ------- SERIALIZED LAYOUT DATA -------
2025-04-24T16:09:35.140Z root INFO {"version":5,"mainPanel":{"main":{"type":"tab-area","widgets":[{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///c%3A/Users/ziad/Documents/Arduino/Fencing/Utility%20module/remote_adapter/remote_adapter.ino"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":47,\"column\":32},\"position\":{\"lineNumber\":47,\"column\":32}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":45,\"column\":1},\"firstPositionDeltaTop\":-14},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":116,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///c%3A/Users/ziad/Documents/Arduino/Fencing/Utility%20module/remote_adapter/README.md"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":1,\"column\":1},\"position\":{\"lineNumber\":1,\"column\":1}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":1,\"column\":1},\"firstPositionDeltaTop\":0},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":3,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///c%3A/Users/ziad/Documents/Arduino/Fencing/Utility%20module/remote_adapter/control.h"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":1,\"column\":1},\"position\":{\"lineNumber\":1,\"column\":1}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":1,\"column\":1},\"firstPositionDeltaTop\":0},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":168,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///c%3A/Users/ziad/Documents/Arduino/Fencing/Utility%20module/remote_adapter/debugHelpers.cpp"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":1,\"column\":1},\"position\":{\"lineNumber\":1,\"column\":1}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":1,\"column\":1},\"firstPositionDeltaTop\":0},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":55,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///c%3A/Users/ziad/Documents/Arduino/Fencing/Utility%20module/remote_adapter/debugHelpers.h"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":1,\"column\":1},\"position\":{\"lineNumber\":1,\"column\":1}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":1,\"column\":1},\"firstPositionDeltaTop\":0},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":56,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///c%3A/Users/ziad/Documents/Arduino/Fencing/Utility%20module/remote_adapter/functions.h"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":1,\"column\":1},\"position\":{\"lineNumber\":1,\"column\":1}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":1,\"column\":1},\"firstPositionDeltaTop\":0},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":822,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///c%3A/Users/ziad/Documents/Arduino/Fencing/Utility%20module/remote_adapter/interface.cpp"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":1,\"column\":1},\"position\":{\"lineNumber\":1,\"column\":1}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":1,\"column\":1},\"firstPositionDeltaTop\":0},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":344,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///c%3A/Users/ziad/Documents/Arduino/Fencing/Utility%20module/remote_adapter/interface.h"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":18,\"column\":4},\"position\":{\"lineNumber\":18,\"column\":4}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":1,\"column\":1},\"firstPositionDeltaTop\":0},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":59,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///c%3A/Users/ziad/Documents/Arduino/Fencing/Utility%20module/remote_adapter/variables.h"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":1,\"column\":1},\"position\":{\"lineNumber\":1,\"column\":1}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":29,\"column\":1},\"firstPositionDeltaTop\":-18},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":119,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"},{"constructionOptions":{"factoryId":"settings_widget"},"innerWidgetState":"{\"scopeTabBarState\":{\"scopeDetails\":{\"scope\":1,\"activeScopeIsFolder\":false}},\"editorState\":{\"firstVisibleChildID\":\"commonly-used@commonly-used\"},\"searchbarWidgetState\":{\"searchTerm\":\"blue\"}}"}],"currentIndex":9}},"mainPanelPinned":[false,false,false,false,false,false,false,false,false,false],"bottomPanel":{"config":{"main":{"type":"tab-area","widgets":[{"constructionOptions":{"factoryId":"outputView"},"innerWidgetState":"{\"locked\":false}"}],"currentIndex":0}},"pinned":[false],"size":354,"expanded":false},"leftPanel":{"type":"sidepanel","items":[{"widget":{"constructionOptions":{"factoryId":"arduino-sketchbook-widget"}},"rank":1,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"boards-list-widget"}},"rank":2,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"library-list-widget"}},"rank":3,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"debug"},"innerWidgetState":"{\"parts\":[{\"partId\":\"debug:threads:-1\",\"collapsed\":false,\"hidden\":false,\"relativeSize\":1.384,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:threads\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"debug:frames:-1\",\"collapsed\":false,\"hidden\":false,\"relativeSize\":1.384,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:frames\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"debug:variables:-1\",\"collapsed\":false,\"hidden\":false,\"relativeSize\":1.384,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:variables\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"debug:watch:-1\",\"collapsed\":false,\"hidden\":false,\"relativeSize\":1.384,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:watch\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"debug:breakpoints:-1\",\"collapsed\":false,\"hidden\":false,\"relativeSize\":1.384,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:breakpoints\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"plugin-view:cortex-debug.peripherals\",\"collapsed\":true,\"hidden\":true,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"plugin-view\",\"options\":{\"id\":\"plugin-view:cortex-debug.peripherals\",\"viewId\":\"cortex-debug.peripherals\"}},\"innerWidgetState\":\"{\\\"label\\\":\\\"Cortex Peripherals\\\",\\\"widgets\\\":[],\\\"suppressUpdateViewVisibility\\\":false,\\\"currentViewContainerId\\\":\\\"debug\\\"}\"}},{\"partId\":\"plugin-view:cortex-debug.registers\",\"collapsed\":true,\"hidden\":true,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"plugin-view\",\"options\":{\"id\":\"plugin-view:cortex-debug.registers\",\"viewId\":\"cortex-debug.registers\"}},\"innerWidgetState\":\"{\\\"label\\\":\\\"Cortex Registers\\\",\\\"widgets\\\":[],\\\"suppressUpdateViewVisibility\\\":false,\\\"currentViewContainerId\\\":\\\"debug\\\"}\"}}],\"title\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}}"},"rank":4,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"search-view-container"},"innerWidgetState":"{\"parts\":[{\"partId\":\"search-in-workspace\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"search-view-container\",\"originalContainerTitle\":{\"label\":\"Search\",\"iconClass\":\"codicon codicon-search\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"search-in-workspace\"},\"innerWidgetState\":\"{\\\"matchCaseState\\\":{\\\"className\\\":\\\"codicon codicon-case-sensitive\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Match Case\\\"},\\\"wholeWordState\\\":{\\\"className\\\":\\\"codicon codicon-whole-word\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Match Whole Word\\\"},\\\"regExpState\\\":{\\\"className\\\":\\\"codicon codicon-regex\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Use Regular Expression\\\"},\\\"includeIgnoredState\\\":{\\\"className\\\":\\\"codicon codicon-eye\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Include Ignored Files\\\"},\\\"showSearchDetails\\\":false,\\\"searchInWorkspaceOptions\\\":{\\\"matchCase\\\":false,\\\"matchWholeWord\\\":false,\\\"useRegExp\\\":false,\\\"includeIgnored\\\":false,\\\"include\\\":[],\\\"exclude\\\":[],\\\"maxResults\\\":2000},\\\"searchTerm\\\":\\\"\\\",\\\"replaceTerm\\\":\\\"\\\",\\\"showReplaceField\\\":false,\\\"searchHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0},\\\"replaceHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0},\\\"includeHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0},\\\"excludeHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0}}\"}}],\"title\":{\"label\":\"Search\",\"iconClass\":\"fa fa-arduino-search\",\"closeable\":true}}"},"rank":5,"expanded":false,"pinned":false}],"size":367},"rightPanel":{"type":"sidepanel","items":[]},"activeWidgetId":"settings_widget"}
2025-04-24T16:09:35.140Z root INFO ------- END SERIALIZED LAYOUT DATA -------
2025-04-24T16:09:35.208Z root INFO <<< The layout has been successfully restored.
2025-04-24T16:09:35.229Z root INFO Initialize the workbench layout: 826.1 ms [Finished 2.128 s after frontend start]
2025-04-24T16:09:35.230Z root INFO Changed application state from 'attached_shell' to 'initialized_layout'.
2025-04-24T16:09:35.230Z root INFO [8514ef7d-1035-423c-94c2-e30e5e0ba2f4] Loading plugin contributions
2025-04-24T16:09:35.230Z root INFO [8514ef7d-1035-423c-94c2-e30e5e0ba2f4] Load contributions of 23 plugins: 64.2 ms [Finished 2.193 s after frontend start]
2025-04-24T16:09:35.286Z root WARN 'cpp' language is remapped from 'source.cpp.embedded.macro' to 'source.cpp' scope
2025-04-24T16:09:35.286Z root WARN a registered grammar configuration for 'cpp' language is overridden
2025-04-24T16:09:35.406Z root INFO <<< The layout has been successfully restored.
2025-04-24T16:09:35.467Z root ERROR [hosted-plugin: 5804] Conflict in settings file Default: Ignoring cortex-debug.armToolchainPath.linux as cortex-debug.armToolchainPath is null
2025-04-24T16:09:35.467Z root ERROR [hosted-plugin: 5804] Conflict in settings file Default: Ignoring cortex-debug.armToolchainPath.osx as cortex-debug.armToolchainPath is null
Conflict in settings file Default: Ignoring cortex-debug.armToolchainPath.windows as cortex-debug.armToolchainPath is null
Conflict in settings file Default: Ignoring cortex-debug.JLinkGDBServerPath.linux as cortex-debug.JLinkGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.JLinkGDBServerPath.osx as cortex-debug.JLinkGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.JLinkGDBServerPath.windows as cortex-debug.JLinkGDBServerPath is null
2025-04-24T16:09:35.467Z root ERROR [hosted-plugin: 5804] Conflict in settings file Default: Ignoring cortex-debug.openocdPath.linux as cortex-debug.openocdPath is null
2025-04-24T16:09:35.467Z root ERROR [hosted-plugin: 5804] Conflict in settings file Default: Ignoring cortex-debug.openocdPath.osx as cortex-debug.openocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.openocdPath.windows as cortex-debug.openocdPath is null
2025-04-24T16:09:35.467Z root ERROR [hosted-plugin: 5804] Conflict in settings file Default: Ignoring cortex-debug.pyocdPath.linux as cortex-debug.pyocdPath is null
2025-04-24T16:09:35.467Z root ERROR [hosted-plugin: 5804] Conflict in settings file Default: Ignoring cortex-debug.pyocdPath.osx as cortex-debug.pyocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.pyocdPath.windows as cortex-debug.pyocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.PEGDBServerPath.linux as cortex-debug.PEGDBServerPath is null
2025-04-24T16:09:35.467Z root ERROR [hosted-plugin: 5804] Conflict in settings file Default: Ignoring cortex-debug.PEGDBServerPath.osx as cortex-debug.PEGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.PEGDBServerPath.windows as cortex-debug.PEGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.stutilPath.linux as cortex-debug.stutilPath is null
2025-04-24T16:09:35.467Z root ERROR [hosted-plugin: 5804] Conflict in settings file Default: Ignoring cortex-debug.stutilPath.osx as cortex-debug.stutilPath is null
Conflict in settings file Default: Ignoring cortex-debug.stutilPath.windows as cortex-debug.stutilPath is null
Conflict in settings file Default: Ignoring cortex-debug.stlinkPath.linux as cortex-debug.stlinkPath is null
2025-04-24T16:09:35.467Z root ERROR [hosted-plugin: 5804] Conflict in settings file Default: Ignoring cortex-debug.stlinkPath.osx as cortex-debug.stlinkPath is null
Conflict in settings file Default: Ignoring cortex-debug.stlinkPath.windows as cortex-debug.stlinkPath is null
2025-04-24T16:09:35.467Z root ERROR [hosted-plugin: 5804] Conflict in settings file Default: Ignoring cortex-debug.stm32cubeprogrammer.linux as cortex-debug.stm32cubeprogrammer is null
Conflict in settings file Default: Ignoring cortex-debug.stm32cubeprogrammer.osx as cortex-debug.stm32cubeprogrammer is null
2025-04-24T16:09:35.467Z root ERROR [hosted-plugin: 5804] Conflict in settings file Default: Ignoring cortex-debug.stm32cubeprogrammer.windows as cortex-debug.stm32cubeprogrammer is null
2025-04-24T16:09:35.471Z root INFO [hosted-plugin: 5804] PLUGIN_HOST(5804): PluginManagerExtImpl/init()
2025-04-24T16:09:35.472Z root INFO [hosted-plugin: 5804] PLUGIN_HOST(5804): initializing(vscode-arduino-api@0.1.2 with C:\Users\ziad\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-04-24T16:09:35.492Z root INFO Initialize the workbench layout: 1068.6 ms [Finished 2.357 s after frontend start]
2025-04-24T16:09:35.493Z root INFO Changed application state from 'attached_shell' to 'initialized_layout'.
2025-04-24T16:09:35.493Z root INFO [bfc8c407-056c-4f84-b319-d1b3870b4a2b] Loading plugin contributions
2025-04-24T16:09:35.493Z root INFO [bfc8c407-056c-4f84-b319-d1b3870b4a2b] Load contributions of 23 plugins: 85.1 ms [Finished 2.443 s after frontend start]
2025-04-24T16:09:35.501Z root INFO [hosted-plugin: 5804] PLUGIN_HOST(5804): initializing(json-language-features@1.88.1 with C:\Users\ziad\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-04-24T16:09:35.505Z root INFO [hosted-plugin: 5804] PLUGIN_HOST(5804): initializing(cortex-debug@1.5.1 with C:\Users\ziad\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-04-24T16:09:35.506Z root INFO [hosted-plugin: 5804] Debugger contribution has been registered: cortex-debug
2025-04-24T16:09:35.506Z root INFO [hosted-plugin: 5804] PLUGIN_HOST(5804): initializing(vscode-arduino-tools@0.1.3 with C:\Users\ziad\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-04-24T16:09:35.506Z root INFO [hosted-plugin: 5804] PLUGIN_HOST(5804): initializing(cpp@1.88.1 with C:\Users\ziad\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-04-24T16:09:35.507Z root INFO [hosted-plugin: 5804] PLUGIN_HOST(5804): initializing(json@1.88.1 with C:\Users\ziad\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-04-24T16:09:35.507Z root INFO [hosted-plugin: 5804] PLUGIN_HOST(5804): initializing(vscode-language-pack-bg@1.48.3 with C:\Users\ziad\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-04-24T16:09:35.508Z root INFO [hosted-plugin: 5804] PLUGIN_HOST(5804): initializing(vscode-language-pack-cs@1.96.0 with C:\Users\ziad\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-04-24T16:09:35.508Z root INFO [hosted-plugin: 5804] PLUGIN_HOST(5804): initializing(vscode-language-pack-de@1.96.0 with C:\Users\ziad\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-04-24T16:09:35.508Z root INFO [hosted-plugin: 5804] PLUGIN_HOST(5804): initializing(vscode-language-pack-es@1.96.0 with C:\Users\ziad\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-04-24T16:09:35.509Z root INFO [hosted-plugin: 5804] PLUGIN_HOST(5804): initializing(vscode-language-pack-fr@1.96.0 with C:\Users\ziad\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-04-24T16:09:35.509Z root INFO [hosted-plugin: 5804] PLUGIN_HOST(5804): initializing(vscode-language-pack-hu@1.48.3 with C:\Users\ziad\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-04-24T16:09:35.509Z root INFO [hosted-plugin: 5804] PLUGIN_HOST(5804): initializing(vscode-language-pack-it@1.96.0 with C:\Users\ziad\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-04-24T16:09:35.509Z root INFO [hosted-plugin: 5804] PLUGIN_HOST(5804): initializing(vscode-language-pack-ja@1.96.0 with C:\Users\ziad\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-04-24T16:09:35.510Z root INFO [hosted-plugin: 5804] PLUGIN_HOST(5804): initializing(vscode-language-pack-ko@1.96.0 with C:\Users\ziad\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-04-24T16:09:35.510Z root INFO [hosted-plugin: 5804] PLUGIN_HOST(5804): initializing(vscode-language-pack-nl@1.48.3 with C:\Users\ziad\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-04-24T16:09:35.510Z root INFO [hosted-plugin: 5804] PLUGIN_HOST(5804): initializing(vscode-language-pack-pl@1.96.0 with C:\Users\ziad\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-04-24T16:09:35.510Z root INFO [hosted-plugin: 5804] PLUGIN_HOST(5804): initializing(vscode-language-pack-pt-BR@1.96.0 with C:\Users\ziad\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-04-24T16:09:35.511Z root INFO [hosted-plugin: 5804] PLUGIN_HOST(5804): initializing(vscode-language-pack-ru@1.96.0 with C:\Users\ziad\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-04-24T16:09:35.511Z root INFO [hosted-plugin: 5804] PLUGIN_HOST(5804): initializing(vscode-language-pack-tr@1.96.0 with C:\Users\ziad\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-04-24T16:09:35.511Z root INFO [hosted-plugin: 5804] PLUGIN_HOST(5804): initializing(vscode-language-pack-uk@1.48.3 with C:\Users\ziad\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-04-24T16:09:35.511Z root INFO [hosted-plugin: 5804] PLUGIN_HOST(5804): initializing(vscode-language-pack-zh-hans@1.96.0 with C:\Users\ziad\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-04-24T16:09:35.511Z root INFO [hosted-plugin: 5804] PLUGIN_HOST(5804): initializing(vscode-language-pack-zh-hant@1.96.0 with C:\Users\ziad\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-04-24T16:09:35.513Z root INFO [hosted-plugin: 5804] PLUGIN_HOST(5804): PluginManagerExtImpl/loadPlugin(C:\Users\ziad\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-builtin-json-language-features\extension\client\dist\node\jsonClientMain)
2025-04-24T16:09:35.527Z root WARN 'cpp' language is remapped from 'source.cpp.embedded.macro' to 'source.cpp' scope
2025-04-24T16:09:35.527Z root WARN a registered grammar configuration for 'cpp' language is overridden
2025-04-24T16:09:35.537Z root INFO [hosted-plugin: 5804] PLUGIN_HOST(5804): PluginManagerExtImpl/loadPlugin(C:\Users\ziad\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-arduino-tools\extension\dist\extension.js)
2025-04-24T16:09:35.549Z root INFO [hosted-plugin: 5804] PLUGIN_HOST(5804): PluginManagerExtImpl/loadPlugin(C:\Users\ziad\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-arduino-api\extension\dist\extension.js)
2025-04-24T16:09:35.551Z root INFO [hosted-plugin: 5804] calling activation function on VS Code Arduino Tools
2025-04-24T16:09:35.551Z root INFO [hosted-plugin: 5804] calling activation function on Arduino IDE API for VS Code extensions
2025-04-24T16:09:35.567Z root INFO [8514ef7d-1035-423c-94c2-e30e5e0ba2f4] Starting plugins.
2025-04-24T16:09:35.578Z root INFO [hosted-plugin: 5804] PLUGIN_HOST(5804): PluginManagerExtImpl/loadPlugin(C:\Users\ziad\AppData\Local\Programs\Arduino IDE\resources\app\plugins\cortex-debug\extension\dist\extension.js)
2025-04-24T16:09:35.599Z root INFO [hosted-plugin: 5804] Debug configuration provider has been registered: cortex-debug, trigger: 1
2025-04-24T16:09:35.599Z root INFO [hosted-plugin: 5804] calling activation function on Cortex-Debug
2025-04-24T16:09:35.602Z root INFO [hosted-plugin: 5804] GDB server console created
2025-04-24T16:09:35.618Z root INFO [8514ef7d-1035-423c-94c2-e30e5e0ba2f4] Start of 23 plugins: 387.9 ms [Finished 2.583 s after frontend start]
2025-04-24T16:09:35.664Z root INFO [hosted-plugin: 5804] calling activation function on JSON Language Features (built-in)
2025-04-24T16:09:35.696Z root ERROR [hosted-plugin: 8840] Conflict in settings file Default: Ignoring cortex-debug.armToolchainPath.linux as cortex-debug.armToolchainPath is null
2025-04-24T16:09:35.696Z root ERROR [hosted-plugin: 8840] Conflict in settings file Default: Ignoring cortex-debug.armToolchainPath.osx as cortex-debug.armToolchainPath is null
2025-04-24T16:09:35.696Z root ERROR [hosted-plugin: 8840] Conflict in settings file Default: Ignoring cortex-debug.JLinkGDBServerPath.osx as cortex-debug.JLinkGDBServerPath is null
2025-04-24T16:09:35.696Z root ERROR [hosted-plugin: 8840] Conflict in settings file Default: Ignoring cortex-debug.openocdPath.linux as cortex-debug.openocdPath is null
2025-04-24T16:09:35.696Z root ERROR [hosted-plugin: 8840] Conflict in settings file Default: Ignoring cortex-debug.openocdPath.osx as cortex-debug.openocdPath is null
2025-04-24T16:09:35.696Z root ERROR [hosted-plugin: 8840] Conflict in settings file Default: Ignoring cortex-debug.openocdPath.windows as cortex-debug.openocdPath is null
2025-04-24T16:09:35.696Z root ERROR [hosted-plugin: 8840] Conflict in settings file Default: Ignoring cortex-debug.PEGDBServerPath.osx as cortex-debug.PEGDBServerPath is null
2025-04-24T16:09:35.696Z root ERROR [hosted-plugin: 8840] Conflict in settings file Default: Ignoring cortex-debug.stutilPath.windows as cortex-debug.stutilPath is null
2025-04-24T16:09:35.696Z root ERROR [hosted-plugin: 8840] Conflict in settings file Default: Ignoring cortex-debug.stlinkPath.windows as cortex-debug.stlinkPath is null
2025-04-24T16:09:35.696Z root ERROR [hosted-plugin: 8840] Conflict in settings file Default: Ignoring cortex-debug.stm32cubeprogrammer.windows as cortex-debug.stm32cubeprogrammer is null
2025-04-24T16:09:35.704Z root INFO [hosted-plugin: 8840] PLUGIN_HOST(8840): PluginManagerExtImpl/init()
2025-04-24T16:09:35.706Z root INFO [hosted-plugin: 8840] PLUGIN_HOST(8840): initializing(vscode-arduino-api@0.1.2 with C:\Users\ziad\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-04-24T16:09:35.734Z root INFO [hosted-plugin: 8840] PLUGIN_HOST(8840): initializing(json-language-features@1.88.1 with C:\Users\ziad\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-04-24T16:09:35.735Z root INFO [hosted-plugin: 8840] PLUGIN_HOST(8840): initializing(cortex-debug@1.5.1 with C:\Users\ziad\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-04-24T16:09:35.736Z root INFO [hosted-plugin: 8840] Debugger contribution has been registered: cortex-debug
2025-04-24T16:09:35.737Z root INFO [hosted-plugin: 8840] PLUGIN_HOST(8840): initializing(vscode-arduino-tools@0.1.3 with C:\Users\ziad\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-04-24T16:09:35.738Z root INFO [hosted-plugin: 8840] PLUGIN_HOST(8840): initializing(cpp@1.88.1 with C:\Users\ziad\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-04-24T16:09:35.738Z root INFO [hosted-plugin: 8840] PLUGIN_HOST(8840): initializing(json@1.88.1 with C:\Users\ziad\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-04-24T16:09:35.738Z root INFO [hosted-plugin: 8840] PLUGIN_HOST(8840): initializing(vscode-language-pack-bg@1.48.3 with C:\Users\ziad\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-04-24T16:09:35.739Z root INFO [hosted-plugin: 8840] PLUGIN_HOST(8840): initializing(vscode-language-pack-cs@1.96.0 with C:\Users\ziad\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
PLUGIN_HOST(8840): initializing(vscode-language-pack-de@1.96.0 with C:\Users\ziad\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-04-24T16:09:35.740Z root INFO [hosted-plugin: 8840] PLUGIN_HOST(8840): initializing(vscode-language-pack-es@1.96.0 with C:\Users\ziad\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-04-24T16:09:35.740Z root INFO [hosted-plugin: 8840] PLUGIN_HOST(8840): initializing(vscode-language-pack-fr@1.96.0 with C:\Users\ziad\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-04-24T16:09:35.741Z root INFO [hosted-plugin: 8840] PLUGIN_HOST(8840): initializing(vscode-language-pack-hu@1.48.3 with C:\Users\ziad\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-04-24T16:09:35.741Z root INFO [hosted-plugin: 8840] PLUGIN_HOST(8840): initializing(vscode-language-pack-it@1.96.0 with C:\Users\ziad\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-04-24T16:09:35.741Z root INFO [hosted-plugin: 8840] PLUGIN_HOST(8840): initializing(vscode-language-pack-ja@1.96.0 with C:\Users\ziad\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-04-24T16:09:35.741Z root INFO [hosted-plugin: 8840] PLUGIN_HOST(8840): initializing(vscode-language-pack-ko@1.96.0 with C:\Users\ziad\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-04-24T16:09:35.741Z root INFO [hosted-plugin: 8840] PLUGIN_HOST(8840): initializing(vscode-language-pack-nl@1.48.3 with C:\Users\ziad\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-04-24T16:09:35.742Z root INFO [hosted-plugin: 8840] PLUGIN_HOST(8840): initializing(vscode-language-pack-pl@1.96.0 with C:\Users\ziad\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-04-24T16:09:35.742Z root INFO [hosted-plugin: 8840] PLUGIN_HOST(8840): initializing(vscode-language-pack-pt-BR@1.96.0 with C:\Users\ziad\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-04-24T16:09:35.742Z root INFO [hosted-plugin: 8840] PLUGIN_HOST(8840): initializing(vscode-language-pack-ru@1.96.0 with C:\Users\ziad\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-04-24T16:09:35.742Z root INFO [hosted-plugin: 8840] PLUGIN_HOST(8840): initializing(vscode-language-pack-tr@1.96.0 with C:\Users\ziad\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-04-24T16:09:35.743Z root INFO [hosted-plugin: 8840] PLUGIN_HOST(8840): initializing(vscode-language-pack-uk@1.48.3 with C:\Users\ziad\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-04-24T16:09:35.743Z root INFO [hosted-plugin: 8840] PLUGIN_HOST(8840): initializing(vscode-language-pack-zh-hans@1.96.0 with C:\Users\ziad\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-04-24T16:09:35.743Z root INFO [hosted-plugin: 8840] PLUGIN_HOST(8840): initializing(vscode-language-pack-zh-hant@1.96.0 with C:\Users\ziad\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-04-24T16:09:35.748Z root INFO [hosted-plugin: 8840] PLUGIN_HOST(8840): PluginManagerExtImpl/loadPlugin(C:\Users\ziad\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-builtin-json-language-features\extension\client\dist\node\jsonClientMain)
2025-04-24T16:09:35.771Z root INFO [hosted-plugin: 8840] PLUGIN_HOST(8840): PluginManagerExtImpl/loadPlugin(C:\Users\ziad\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-arduino-tools\extension\dist\extension.js)
2025-04-24T16:09:35.782Z root INFO [hosted-plugin: 8840] PLUGIN_HOST(8840): PluginManagerExtImpl/loadPlugin(C:\Users\ziad\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-arduino-api\extension\dist\extension.js)
2025-04-24T16:09:35.784Z root INFO [hosted-plugin: 8840] calling activation function on VS Code Arduino Tools
2025-04-24T16:09:35.784Z root INFO [hosted-plugin: 8840] calling activation function on Arduino IDE API for VS Code extensions
2025-04-24T16:09:35.790Z root INFO [bfc8c407-056c-4f84-b319-d1b3870b4a2b] Starting plugins.
2025-04-24T16:09:35.807Z root INFO [hosted-plugin: 8840] PLUGIN_HOST(8840): PluginManagerExtImpl/loadPlugin(C:\Users\ziad\AppData\Local\Programs\Arduino IDE\resources\app\plugins\cortex-debug\extension\dist\extension.js)
2025-04-24T16:09:35.824Z root INFO [hosted-plugin: 8840] Debug configuration provider has been registered: cortex-debug, trigger: 1
2025-04-24T16:09:35.824Z root INFO [hosted-plugin: 8840] calling activation function on Cortex-Debug
2025-04-24T16:09:35.826Z root INFO [hosted-plugin: 8840] GDB server console created
2025-04-24T16:09:35.831Z root INFO [bfc8c407-056c-4f84-b319-d1b3870b4a2b] Start of 23 plugins: 337.3 ms [Finished 2.782 s after frontend start]
2025-04-24T16:09:35.890Z root INFO [hosted-plugin: 8840] calling activation function on JSON Language Features (built-in)
2025-04-24T16:09:36.142Z root INFO Frontend application start: 1869.0 ms [Finished 3.399 s after backend start]
Checking for update
2025-04-24T16:09:36.157Z root INFO Replace loading indicator with ready workbench UI (animation): 829.7 ms [Finished 3.024 s after frontend start]
2025-04-24T16:09:36.157Z root INFO Changed application state from 'initialized_layout' to 'ready'.
2025-04-24T16:09:36.158Z root WARN Linked preference "workbench.colorCustomizations" not found.
2025-04-24T16:09:36.313Z root ERROR ---- !!!SLOW!!! DURATION: search took 154.480 ms. Args: [{"type":"Updatable"}] ----
2025-04-24T16:09:36.401Z root INFO Frontend application start: 2127.0 ms [Finished 3.658 s after backend start]
2025-04-24T16:09:36.407Z root INFO Replace loading indicator with ready workbench UI (animation): 825.4 ms [Finished 3.270 s after frontend start]
2025-04-24T16:09:36.407Z root INFO Changed application state from 'initialized_layout' to 'ready'.
2025-04-24T16:09:36.407Z root WARN Linked preference "workbench.colorCustomizations" not found.
2025-04-24T16:09:36.420Z root INFO Starting language server: esp32:esp32:XIAO_ESP32C3:UploadSpeed=921600,CDCOnBoot=default,CPUFreq=160,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,EraseFlash=none
2025-04-24T16:09:36.424Z daemon INFO time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="arduino:dfu-util@0.11.0-arduino5"
time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="esp32:esp-rv32@2405"
time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="esp32:esp-x32@2405"
time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="esp32:esp32-arduino-libs@idf-release_v5.3-489d7a2b-v1"
time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="esp32:esptool_py@4.9.dev3"
time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="esp32:mklittlefs@3.0.0-gnu12-dc7f933"
time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="esp32:mkspiffs@0.2.3"
time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="esp32:openocd-esp32@v0.12.0-esp32-20241016"
time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="esp32:riscv32-esp-elf-gdb@14.2_20240403"
time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="esp32:xtensa-esp-elf-gdb@14.2_20240403"
time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="builtin:ctags@5.8-arduino11"
time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="builtin:serial-discovery@1.4.1"
time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="Seeeduino:nrfjprog@9.4.0"
time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="Seeeduino:openocd@0.11.0-arduino2"
time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="Seeeduino:CMSIS@5.7.0"
time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="arduino:arduinoOTA@1.3.0"
time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="arduino:avrdude@6.3.0-arduino17"
time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="builtin:dfu-discovery@0.1.2"
time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="builtin:serial-monitor@0.15.0"
time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="builtin:mdns-discovery@1.0.9"
time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="Seeeduino:arm-none-eabi-gcc@9-2019q4"
time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="Seeeduino:bossac@1.9.1-arduino2"
2025-04-24T16:09:36.431Z daemon INFO time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="arduino:dfu-util@0.11.0-arduino5"
2025-04-24T16:09:36.431Z daemon INFO time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="esp32:riscv32-esp-elf-gdb@14.2_20240403"
2025-04-24T16:09:36.431Z daemon INFO time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="builtin:dfu-discovery@0.1.2"
2025-04-24T16:09:36.431Z daemon INFO time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="builtin:serial-discovery@1.4.1"
2025-04-24T16:09:36.431Z daemon INFO time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="arduino:arduinoOTA@1.3.0"
2025-04-24T16:09:36.431Z daemon INFO time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="builtin:serial-monitor@0.15.0"
2025-04-24T16:09:36.431Z daemon INFO time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="Seeeduino:arm-none-eabi-gcc@9-2019q4"
2025-04-24T16:09:36.431Z daemon INFO time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="builtin:mdns-discovery@1.0.9"
2025-04-24T16:09:36.431Z daemon INFO time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="arduino:avrdude@6.3.0-arduino17"
2025-04-24T16:09:36.440Z daemon INFO time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="arduino:dfu-util@0.11.0-arduino5"
2025-04-24T16:09:36.440Z daemon INFO time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="esp32:esp32-arduino-libs@idf-release_v5.3-489d7a2b-v1"
2025-04-24T16:09:36.440Z daemon INFO time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="arduino:arduinoOTA@1.3.0"
2025-04-24T16:09:36.441Z daemon INFO time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="arduino:avrdude@6.3.0-arduino17"
2025-04-24T16:09:36.510Z daemon INFO time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="arduino:dfu-util@0.11.0-arduino5"
time="2025-04-24T09:09:36-07:00" level=info msg="Adding libraries dir" dir="C:\\Users\\ziad\\AppData\\Local\\Arduino15\\libraries" isSingleLibrary=false location=ide
time="2025-04-24T09:09:36-07:00" level=info msg="Adding libraries dir" dir="C:\\Users\\ziad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.1.3\\libraries" isSingleLibrary=false location=platform
time="2025-04-24T09:09:36-07:00" level=info msg="Adding libraries dir" dir="c:\\Users\\ziad\\Documents\\Arduino\\libraries" isSingleLibrary=false location=user
2025-04-24T16:09:36.511Z fwuploader ERROR Error: Process exited with exit code: 1
at ChildProcess.<anonymous> (C:\Users\ziad\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:1104768)
at ChildProcess.emit (node:events:519:28)
at ChildProcess._handle.onexit (node:internal/child_process:294:12)
2025-04-24T16:09:36.589Z daemon INFO time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="arduino:dfu-util@0.11.0-arduino5"
2025-04-24T16:09:36.589Z daemon INFO time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="esp32:esptool_py@4.9.dev3"
2025-04-24T16:09:36.589Z daemon INFO time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="arduino:arduinoOTA@1.3.0"
2025-04-24T16:09:36.589Z daemon INFO time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="Seeeduino:bossac@1.9.1-arduino2"
2025-04-24T16:09:36.589Z daemon INFO time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
2025-04-24T16:09:36.589Z daemon INFO time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="builtin:ctags@5.8-arduino11"
2025-04-24T16:09:36.590Z root INFO Starting language server: esp32:esp32:XIAO_ESP32C3:UploadSpeed=921600,CDCOnBoot=default,CPUFreq=160,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,EraseFlash=none
2025-04-24T16:09:36.594Z daemon INFO time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="arduino:dfu-util@0.11.0-arduino5"
2025-04-24T16:09:36.594Z daemon INFO time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="esp32:esp-x32@2405"
2025-04-24T16:09:36.594Z daemon INFO time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="builtin:serial-monitor@0.15.0"
2025-04-24T16:09:36.594Z daemon INFO time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="Seeeduino:CMSIS@5.7.0"
2025-04-24T16:09:36.594Z daemon INFO time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="builtin:serial-discovery@1.4.1"
2025-04-24T16:09:36.594Z daemon INFO time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="builtin:mdns-discovery@1.0.9"
2025-04-24T16:09:36.594Z daemon INFO time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
2025-04-24T16:09:36.600Z daemon INFO time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="arduino:dfu-util@0.11.0-arduino5"
2025-04-24T16:09:36.600Z daemon INFO time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="esp32:esp-x32@2405"
2025-04-24T16:09:36.600Z daemon INFO time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="Seeeduino:CMSIS@5.7.0"
2025-04-24T16:09:36.600Z daemon INFO time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="arduino:arduinoOTA@1.3.0"
2025-04-24T16:09:36.600Z daemon INFO time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="builtin:dfu-discovery@0.1.2"
2025-04-24T16:09:36.600Z daemon INFO time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="builtin:mdns-discovery@1.0.9"
2025-04-24T16:09:36.600Z daemon INFO time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
2025-04-24T16:09:36.601Z daemon INFO time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="Seeeduino:arm-none-eabi-gcc@9-2019q4"
2025-04-24T16:09:36.605Z daemon INFO time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="arduino:dfu-util@0.11.0-arduino5"
2025-04-24T16:09:36.605Z daemon INFO time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="esp32:esp-x32@2405"
2025-04-24T16:09:36.605Z daemon INFO time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="builtin:mdns-discovery@1.0.9"
2025-04-24T16:09:36.605Z daemon INFO time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="builtin:serial-monitor@0.15.0"
2025-04-24T16:09:36.606Z daemon INFO time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="Seeeduino:CMSIS@5.7.0"
2025-04-24T16:09:36.606Z daemon INFO time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="arduino:arduinoOTA@1.3.0"
2025-04-24T16:09:36.606Z daemon INFO time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="Seeeduino:openocd@0.11.0-arduino2"
2025-04-24T16:09:36.610Z daemon INFO time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="arduino:dfu-util@0.11.0-arduino5"
2025-04-24T16:09:36.611Z daemon INFO time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="esp32:esp32-arduino-libs@idf-release_v5.3-489d7a2b-v1"
2025-04-24T16:09:36.611Z daemon INFO time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="builtin:serial-monitor@0.15.0"
2025-04-24T16:09:36.611Z daemon INFO time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="builtin:ctags@5.8-arduino11"
2025-04-24T16:09:36.611Z daemon INFO time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
2025-04-24T16:09:36.611Z daemon INFO time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="arduino:arduinoOTA@1.3.0"
2025-04-24T16:09:36.616Z daemon INFO time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="arduino:dfu-util@0.11.0-arduino5"
2025-04-24T16:09:36.616Z daemon INFO time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="esp32:esptool_py@4.9.dev3"
Part two:
2025-04-24T16:09:36.616Z daemon INFO time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="builtin:serial-discovery@1.4.1"
2025-04-24T16:09:36.616Z daemon INFO time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="arduino:arduinoOTA@1.3.0"
2025-04-24T16:09:36.616Z daemon INFO time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="arduino:avrdude@6.3.0-arduino17"
2025-04-24T16:09:36.616Z daemon INFO time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="Seeeduino:arm-none-eabi-gcc@9-2019q4"
2025-04-24T16:09:36.616Z daemon INFO time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="Seeeduino:nrfjprog@9.4.0"
2025-04-24T16:09:36.621Z daemon INFO time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="arduino:dfu-util@0.11.0-arduino5"
2025-04-24T16:09:36.621Z daemon INFO time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="esp32:esptool_py@4.9.dev3"
2025-04-24T16:09:36.621Z daemon INFO time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="arduino:avrdude@6.3.0-arduino17"
2025-04-24T16:09:36.621Z daemon INFO time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="builtin:serial-monitor@0.15.0"
2025-04-24T16:09:36.621Z daemon INFO time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="Seeeduino:arm-none-eabi-gcc@9-2019q4"
2025-04-24T16:09:36.621Z daemon INFO time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="Seeeduino:openocd@0.11.0-arduino2"
2025-04-24T16:09:36.625Z daemon INFO time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="arduino:dfu-util@0.11.0-arduino5"
2025-04-24T16:09:36.625Z daemon INFO time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="esp32:esp32-arduino-libs@idf-release_v5.3-489d7a2b-v1"
2025-04-24T16:09:36.625Z daemon INFO time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="builtin:dfu-discovery@0.1.2"
2025-04-24T16:09:36.625Z daemon INFO time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="arduino:arduinoOTA@1.3.0"
2025-04-24T16:09:36.625Z daemon INFO time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="builtin:ctags@5.8-arduino11"
2025-04-24T16:09:36.625Z daemon INFO time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="arduino:avrdude@6.3.0-arduino17"
2025-04-24T16:09:36.630Z daemon INFO time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="arduino:dfu-util@0.11.0-arduino5"
2025-04-24T16:09:36.630Z daemon INFO time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="esp32:riscv32-esp-elf-gdb@14.2_20240403"
2025-04-24T16:09:36.630Z daemon INFO time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="Seeeduino:bossac@1.9.1-arduino2"
2025-04-24T16:09:36.631Z daemon INFO time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
2025-04-24T16:09:36.631Z daemon INFO time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="arduino:avrdude@6.3.0-arduino17"
2025-04-24T16:09:36.636Z daemon INFO time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="arduino:dfu-util@0.11.0-arduino5"
2025-04-24T16:09:36.636Z daemon INFO time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="esp32:esp32-arduino-libs@idf-release_v5.3-489d7a2b-v1"
2025-04-24T16:09:36.636Z daemon INFO time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="builtin:serial-monitor@0.15.0"
2025-04-24T16:09:36.636Z daemon INFO time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="Seeeduino:arm-none-eabi-gcc@9-2019q4"
2025-04-24T16:09:36.636Z daemon INFO time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="builtin:ctags@5.8-arduino11"
2025-04-24T16:09:36.636Z daemon INFO time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="builtin:serial-discovery@1.4.1"
2025-04-24T16:09:36.637Z daemon INFO time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
2025-04-24T16:09:36.637Z daemon INFO time="2025-04-24T09:09:36-07:00" level=info msg="Tool required for debug" tool="arduino:arduinoOTA@1.3.0"
2025-04-24T16:09:36.639Z daemon INFO time="2025-04-24T09:09:36-07:00" level=info msg="Adding libraries dir" dir="C:\\Users\\ziad\\AppData\\Local\\Arduino15\\libraries" isSingleLibrary=false location=ide
2025-04-24T16:09:36.639Z daemon INFO time="2025-04-24T09:09:36-07:00" level=info msg="Adding libraries dir" dir="C:\\Users\\ziad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.1.3\\libraries" isSingleLibrary=false location=platform
2025-04-24T16:09:36.639Z daemon INFO time="2025-04-24T09:09:36-07:00" level=info msg="Adding libraries dir" dir="c:\\Users\\ziad\\Documents\\Arduino\\libraries" isSingleLibrary=false location=user
Update for version 2.3.6 is not available (latest version: 2.3.6, downgrade is allowed).
2025-04-24T16:09:38.575Z daemon INFO time="2025-04-24T09:09:38-07:00" level=info msg="Resolving include viscalib.h for arch esp32"
time="2025-04-24T09:09:38-07:00" level=info msg=" found better lib" lib=ViscaLIB-patch-1 prio=517
2025-04-24T16:09:38.720Z daemon INFO time="2025-04-24T09:09:38-07:00" level=info msg="Resolving include BTAddress.h for arch esp32"
time="2025-04-24T09:09:38-07:00" level=info msg=" found better lib" lib=BluetoothSerial prio=3F4
2025-04-24T16:09:40.102Z daemon INFO time="2025-04-24T09:09:40-07:00" level=info msg="Resolving include BLEDevice.h for arch esp32"
time="2025-04-24T09:09:40-07:00" level=info msg=" found better lib" lib=BLE prio=3F4
2025-04-24T16:09:41.186Z daemon INFO time="2025-04-24T09:09:41-07:00" level=info msg="Adding libraries dir" dir="C:\\Users\\ziad\\AppData\\Local\\Arduino15\\libraries" isSingleLibrary=false location=ide
2025-04-24T16:09:41.187Z daemon INFO time="2025-04-24T09:09:41-07:00" level=info msg="Adding libraries dir" dir="C:\\Users\\ziad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.1.3\\libraries" isSingleLibrary=false location=platform
2025-04-24T16:09:41.187Z daemon INFO time="2025-04-24T09:09:41-07:00" level=info msg="Adding libraries dir" dir="c:\\Users\\ziad\\Documents\\Arduino\\libraries" isSingleLibrary=false location=user
2025-04-24T16:09:41.549Z daemon INFO time="2025-04-24T09:09:41-07:00" level=info msg="Resolving include LED.h for arch esp32"
time="2025-04-24T09:09:41-07:00" level=info msg=" found better lib" lib=GPIO_basics prio=3EB
2025-04-24T16:09:44.547Z daemon INFO time="2025-04-24T09:09:44-07:00" level=info msg="Resolving include SG_Remote.h for arch esp32"
time="2025-04-24T09:09:44-07:00" level=info msg=" found better lib" lib=SG_remote prio=6A7
2025-04-24T16:09:47.577Z root ERROR Detected JSONC parser errors:
2025-04-24T16:09:47.577Z root ERROR ----- CONTENT START -----
2025-04-24T16:09:47.577Z root ERROR {
"window.titleBarStyle": "native",
"workbench.colorTheme": "arduino-theme-dark",
"editor.fontSize": 14,
"files.autoSave": "afterDelay",
"editor.quickSuggestions": {
"other": false,
"comments": false,
"strings": false
"arduino.window.autoScale": true,
"window.zoomLevel": 0,
"arduino.compile.verbose": false,
"arduino.compile.warnings": "Default",
"arduino.upload.verbose": true,
"arduino.upload.verify": false,
"arduino.sketchbook.showAllFiles": false,
"editor.bracketPairColorization.enabled": true,
"editor.autoClosingBrackets": "never",
"arduino.sketch.inoBlueprint": "C:\\Users\\ziad\\Documents\\Arduino\\blank\\blank.ino",
"editor.foldingImportsByDefault": true
}#in
2025-04-24T16:09:47.577Z root ERROR ----- CONTENT END -----
2025-04-24T16:09:47.577Z root ERROR - InvalidSymbol at 739
2025-04-24T16:09:47.861Z root INFO creating connection for 3
2025-04-24T16:09:48.232Z root WARN A command editor.action.toggleStickyScroll is already registered.
Opening channel for service path '/services/electron-window'.
Opening channel for service path '/services/ide-updater'.
2025-04-24T16:09:48.279Z root INFO Start frontend contributions: 99.2 ms [Finished 0.671 s after frontend start]
2025-04-24T16:09:48.279Z root INFO Changed application state from 'init' to 'started_contributions'.
2025-04-24T16:09:48.292Z root INFO [de4d00ac-d920-426b-9673-616b538ae1a4] Waiting for backend deployment: 24.9 ms [Finished 0.694 s after frontend start]
2025-04-24T16:09:48.588Z root INFO [hosted-plugin: 32660] PLUGIN_HOST(32660) starting instance
[Object: null prototype] {}
2025-04-24T16:09:48.862Z root INFO [de4d00ac-d920-426b-9673-616b538ae1a4] Sync of 23 plugins: 570.2 ms [Finished 1.264 s after frontend start]
2025-04-24T16:09:48.870Z root INFO Changed application state from 'started_contributions' to 'attached_shell'.
2025-04-24T16:09:48.870Z root INFO >>> Restoring the layout state...
2025-04-24T16:09:48.870Z root INFO <<< Nothing to restore.
2025-04-24T16:09:48.902Z root INFO Initialize the workbench layout: 10.2 ms [Finished 1.282 s after frontend start]
2025-04-24T16:09:48.903Z root INFO Changed application state from 'attached_shell' to 'initialized_layout'.
2025-04-24T16:09:48.903Z root INFO [de4d00ac-d920-426b-9673-616b538ae1a4] Loading plugin contributions
2025-04-24T16:09:48.903Z root INFO [de4d00ac-d920-426b-9673-616b538ae1a4] Load contributions of 23 plugins: 18.6 ms [Finished 1.303 s after frontend start]
2025-04-24T16:09:48.931Z root WARN 'cpp' language is remapped from 'source.cpp.embedded.macro' to 'source.cpp' scope
2025-04-24T16:09:48.931Z root WARN a registered grammar configuration for 'cpp' language is overridden
2025-04-24T16:09:49.115Z root ERROR [hosted-plugin: 32660] Conflict in settings file Default: Ignoring cortex-debug.armToolchainPath.linux as cortex-debug.armToolchainPath is null
2025-04-24T16:09:49.115Z root ERROR [hosted-plugin: 32660] Conflict in settings file Default: Ignoring cortex-debug.armToolchainPath.osx as cortex-debug.armToolchainPath is null
2025-04-24T16:09:49.115Z root ERROR [hosted-plugin: 32660] Conflict in settings file Default: Ignoring cortex-debug.JLinkGDBServerPath.windows as cortex-debug.JLinkGDBServerPath is null
2025-04-24T16:09:49.115Z root ERROR [hosted-plugin: 32660] Conflict in settings file Default: Ignoring cortex-debug.openocdPath.osx as cortex-debug.openocdPath is null
2025-04-24T16:09:49.115Z root ERROR [hosted-plugin: 32660] Conflict in settings file Default: Ignoring cortex-debug.openocdPath.windows as cortex-debug.openocdPath is null
2025-04-24T16:09:49.115Z root ERROR [hosted-plugin: 32660] Conflict in settings file Default: Ignoring cortex-debug.pyocdPath.linux as cortex-debug.pyocdPath is null
2025-04-24T16:09:49.115Z root ERROR [hosted-plugin: 32660] Conflict in settings file Default: Ignoring cortex-debug.pyocdPath.windows as cortex-debug.pyocdPath is null
2025-04-24T16:09:49.115Z root ERROR [hosted-plugin: 32660] Conflict in settings file Default: Ignoring cortex-debug.PEGDBServerPath.osx as cortex-debug.PEGDBServerPath is null
2025-04-24T16:09:49.115Z root ERROR [hosted-plugin: 32660] Conflict in settings file Default: Ignoring cortex-debug.stutilPath.linux as cortex-debug.stutilPath is null
2025-04-24T16:09:49.115Z root ERROR [hosted-plugin: 32660] Conflict in settings file Default: Ignoring cortex-debug.stlinkPath.linux as cortex-debug.stlinkPath is null
2025-04-24T16:09:49.115Z root ERROR [hosted-plugin: 32660] Conflict in settings file Default: Ignoring cortex-debug.stlinkPath.windows as cortex-debug.stlinkPath is null
2025-04-24T16:09:49.115Z root ERROR [hosted-plugin: 32660] Conflict in settings file Default: Ignoring cortex-debug.stm32cubeprogrammer.osx as cortex-debug.stm32cubeprogrammer is null
2025-04-24T16:09:49.132Z root INFO [hosted-plugin: 32660] PLUGIN_HOST(32660): PluginManagerExtImpl/init()
2025-04-24T16:09:49.133Z root INFO [hosted-plugin: 32660] PLUGIN_HOST(32660): initializing(vscode-arduino-api@0.1.2 with C:\Users\ziad\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-04-24T16:09:49.164Z root INFO [hosted-plugin: 32660] PLUGIN_HOST(32660): initializing(json-language-features@1.88.1 with C:\Users\ziad\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-04-24T16:09:49.169Z root INFO [hosted-plugin: 32660] PLUGIN_HOST(32660): initializing(cortex-debug@1.5.1 with C:\Users\ziad\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-04-24T16:09:49.169Z root INFO [hosted-plugin: 32660] Debugger contribution has been registered: cortex-debug
2025-04-24T16:09:49.169Z root INFO [hosted-plugin: 32660] PLUGIN_HOST(32660): initializing(vscode-arduino-tools@0.1.3 with C:\Users\ziad\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-04-24T16:09:49.170Z root INFO [hosted-plugin: 32660] PLUGIN_HOST(32660): initializing(cpp@1.88.1 with C:\Users\ziad\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-04-24T16:09:49.170Z root INFO [hosted-plugin: 32660] PLUGIN_HOST(32660): initializing(json@1.88.1 with C:\Users\ziad\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-04-24T16:09:49.171Z root INFO [hosted-plugin: 32660] PLUGIN_HOST(32660): initializing(vscode-language-pack-bg@1.48.3 with C:\Users\ziad\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-04-24T16:09:49.171Z root INFO [hosted-plugin: 32660] PLUGIN_HOST(32660): initializing(vscode-language-pack-cs@1.96.0 with C:\Users\ziad\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-04-24T16:09:49.171Z root INFO [hosted-plugin: 32660] PLUGIN_HOST(32660): initializing(vscode-language-pack-de@1.96.0 with C:\Users\ziad\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-04-24T16:09:49.172Z root INFO [hosted-plugin: 32660] PLUGIN_HOST(32660): initializing(vscode-language-pack-es@1.96.0 with C:\Users\ziad\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-04-24T16:09:49.172Z root INFO [hosted-plugin: 32660] PLUGIN_HOST(32660): initializing(vscode-language-pack-fr@1.96.0 with C:\Users\ziad\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-04-24T16:09:49.173Z root INFO [hosted-plugin: 32660] PLUGIN_HOST(32660): initializing(vscode-language-pack-hu@1.48.3 with C:\Users\ziad\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-04-24T16:09:49.173Z root INFO [hosted-plugin: 32660] PLUGIN_HOST(32660): initializing(vscode-language-pack-it@1.96.0 with C:\Users\ziad\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-04-24T16:09:49.174Z root INFO [hosted-plugin: 32660] PLUGIN_HOST(32660): initializing(vscode-language-pack-ja@1.96.0 with C:\Users\ziad\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-04-24T16:09:49.174Z root INFO [hosted-plugin: 32660] PLUGIN_HOST(32660): initializing(vscode-language-pack-ko@1.96.0 with C:\Users\ziad\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-04-24T16:09:49.175Z root INFO [hosted-plugin: 32660] PLUGIN_HOST(32660): initializing(vscode-language-pack-nl@1.48.3 with C:\Users\ziad\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-04-24T16:09:49.175Z root INFO [hosted-plugin: 32660] PLUGIN_HOST(32660): initializing(vscode-language-pack-pl@1.96.0 with C:\Users\ziad\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-04-24T16:09:49.175Z root INFO [hosted-plugin: 32660] PLUGIN_HOST(32660): initializing(vscode-language-pack-pt-BR@1.96.0 with C:\Users\ziad\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-04-24T16:09:49.176Z root INFO [hosted-plugin: 32660] PLUGIN_HOST(32660): initializing(vscode-language-pack-ru@1.96.0 with C:\Users\ziad\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-04-24T16:09:49.176Z root INFO [hosted-plugin: 32660] PLUGIN_HOST(32660): initializing(vscode-language-pack-tr@1.96.0 with C:\Users\ziad\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-04-24T16:09:49.177Z root INFO [hosted-plugin: 32660] PLUGIN_HOST(32660): initializing(vscode-language-pack-uk@1.48.3 with C:\Users\ziad\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-04-24T16:09:49.177Z root INFO [hosted-plugin: 32660] PLUGIN_HOST(32660): initializing(vscode-language-pack-zh-hans@1.96.0 with C:\Users\ziad\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-04-24T16:09:49.178Z root INFO [hosted-plugin: 32660] PLUGIN_HOST(32660): initializing(vscode-language-pack-zh-hant@1.96.0 with C:\Users\ziad\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-04-24T16:09:49.220Z root INFO [hosted-plugin: 32660] PLUGIN_HOST(32660): PluginManagerExtImpl/loadPlugin(C:\Users\ziad\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-builtin-json-language-features\extension\client\dist\node\jsonClientMain)
2025-04-24T16:09:49.247Z root INFO [hosted-plugin: 32660] PLUGIN_HOST(32660): PluginManagerExtImpl/loadPlugin(C:\Users\ziad\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-arduino-api\extension\dist\extension.js)
2025-04-24T16:09:49.249Z root INFO [hosted-plugin: 32660] calling activation function on Arduino IDE API for VS Code extensions
2025-04-24T16:09:49.250Z root INFO [de4d00ac-d920-426b-9673-616b538ae1a4] Starting plugins.
2025-04-24T16:09:49.273Z root INFO [hosted-plugin: 32660] PLUGIN_HOST(32660): PluginManagerExtImpl/loadPlugin(C:\Users\ziad\AppData\Local\Programs\Arduino IDE\resources\app\plugins\cortex-debug\extension\dist\extension.js)
2025-04-24T16:09:49.290Z root INFO [hosted-plugin: 32660] Debug configuration provider has been registered: cortex-debug, trigger: 1
2025-04-24T16:09:49.290Z root INFO [hosted-plugin: 32660] calling activation function on Cortex-Debug
2025-04-24T16:09:49.293Z root INFO [hosted-plugin: 32660] GDB server console created
2025-04-24T16:09:49.295Z root INFO [de4d00ac-d920-426b-9673-616b538ae1a4] Start of 23 plugins: 384.8 ms [Finished 1.697 s after frontend start]
2025-04-24T16:09:49.355Z root INFO [hosted-plugin: 32660] calling activation function on JSON Language Features (built-in)
2025-04-24T16:09:49.818Z root INFO Frontend application start: 1598.5 ms [Finished 17.074 s after backend start]
2025-04-24T16:09:49.823Z root INFO Replace loading indicator with ready workbench UI (animation): 852.4 ms [Finished 2.157 s after frontend start]
2025-04-24T16:09:49.824Z root INFO Changed application state from 'initialized_layout' to 'ready'.
2025-04-24T16:09:49.824Z root WARN Linked preference "workbench.colorCustomizations" not found.
2025-04-24T16:09:49.835Z root INFO Executing startup tasks:
2025-04-24T16:09:49.835Z root INFO - 'arduino-use-inherited-boards-data' , args: [{"fqbn":"esp32:esp32:XIAO_ESP32C3","data":{"configOptions":[{"label":"Upload Speed","option":"UploadSpeed","values":[{"value":"921600","label":"921600","selected":true},{"value":"115200","label":"115200","selected":false},{"value":"256000","label":"256000","selected":false},{"value":"230400","label":"230400","selected":false},{"value":"512000","label":"512000","selected":false}]},{"label":"USB CDC On Boot","option":"CDCOnBoot","values":[{"value":"default","label":"Enabled","selected":true},{"value":"cdc","label":"Disabled","selected":false}]},{"label":"CPU Frequency","option":"CPUFreq","values":[{"value":"160","label":"160MHz (WiFi)","selected":true},{"value":"80","label":"80MHz (WiFi)","selected":false},{"value":"40","label":"40MHz","selected":false},{"value":"20","label":"20MHz","selected":false},{"value":"10","label":"10MHz","selected":false}]},{"label":"Flash Frequency","option":"FlashFreq","values":[{"value":"80","label":"80MHz","selected":true},{"value":"40","label":"40MHz","selected":false}]},{"label":"Flash Mode","option":"FlashMode","values":[{"value":"qio","label":"QIO","selected":true},{"value":"dio","label":"DIO","selected":false}]},{"label":"Flash Size","option":"FlashSize","values":[{"value":"4M","label":"4MB (32Mb)","selected":true},{"value":"8M","label":"8MB (64Mb)","selected":false},{"value":"2M","label":"2MB (16Mb)","selected":false},{"value":"16M","label":"16MB (128Mb)","selected":false}]},{"label":"Partition Scheme","option":"PartitionScheme","values":[{"value":"default","label":"Default 4MB with spiffs (1.2MB APP/1.5MB SPIFFS)","selected":true},{"value":"defaultffat","label":"Default 4MB with ffat (1.2MB APP/1.5MB FATFS)","selected":false},{"value":"default_8MB","label":"8M with spiffs (3MB APP/1.5MB SPIFFS)","selected":false},{"value":"minimal","label":"Minimal (1.3MB APP/700KB SPIFFS)","selected":false},{"value":"no_ota","label":"No OTA (2MB APP/2MB SPIFFS)","selected":false},{"value":"noota_3g","label":"No OTA (1MB APP/3MB SPIFFS)","selected":false},{"value":"noota_ffat","label":"No OTA (2MB APP/2MB FATFS)","selected":false},{"value":"noota_3gffat","label":"No OTA (1MB APP/3MB FATFS)","selected":false},{"value":"huge_app","label":"Huge APP (3MB No OTA/1MB SPIFFS)","selected":false},{"value":"min_spiffs","label":"Minimal SPIFFS (1.9MB APP with OTA/190KB SPIFFS)","selected":false},{"value":"fatflash","label":"16M Flash (2MB APP/12.5MB FATFS)","selected":false},{"value":"app3M_fat9M_16MB","label":"16M Flash (3MB APP/9.9MB FATFS)","selected":false},{"value":"rainmaker","label":"RainMaker 4MB","selected":false},{"value":"rainmaker_4MB","label":"RainMaker 4MB No OTA","selected":false},{"value":"rainmaker_8MB","label":"RainMaker 8MB","selected":false}]},{"label":"Core Debug Level","option":"DebugLevel","values":[{"value":"none","label":"None","selected":true},{"value":"error","label":"Error","selected":false},{"value":"warn","label":"Warn","selected":false},{"value":"info","label":"Info","selected":false},{"value":"debug","label":"Debug","selected":false},{"value":"verbose","label":"Verbose","selected":false}]},{"label":"Erase All Flash Before Sketch Upload","option":"EraseFlash","values":[{"value":"none","label":"Disabled","selected":true},{"value":"all","label":"Enabled","selected":false}]}],"programmers":[{"id":"esptool","name":"Esptool","platform":"esp32:esp32@3.1.3"}]}}]
2025-04-24T16:09:49.836Z root INFO - 'arduino-use-inherited-boards-config' , args: [{"selectedBoard":{"name":"XIAO_ESP32C3","fqbn":"esp32:esp32:XIAO_ESP32C3"},"selectedPort":{"address":"COM11","addressLabel":"COM11","protocol":"serial","protocolLabel":"Serial Port (USB)","properties":{"pid":"0x1001","serialNumber":"","vid":"0x303A"}}},{"arduino+serial://COM11":{"name":"XIAO_ESP32C3","fqbn":"esp32:esp32:XIAO_ESP32C3"}}]
2025-04-24T16:09:49.974Z root INFO Starting language server: esp32:esp32:XIAO_ESP32C3:UploadSpeed=921600,CDCOnBoot=default,CPUFreq=160,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,EraseFlash=none
2025-04-24T16:09:50.039Z daemon INFO time="2025-04-24T09:09:49-07:00" level=info msg="Tool required for debug" tool="arduino:dfu-util@0.11.0-arduino5"
time="2025-04-24T09:09:49-07:00" level=info msg="Tool required for debug" tool="esp32:esp-rv32@2405"
time="2025-04-24T09:09:49-07:00" level=info msg="Tool required for debug" tool="esp32:esp-x32@2405"
time="2025-04-24T09:09:49-07:00" level=info msg="Tool required for debug" tool="esp32:esp32-arduino-libs@idf-release_v5.3-489d7a2b-v1"
time="2025-04-24T09:09:49-07:00" level=info msg="Tool required for debug" tool="esp32:esptool_py@4.9.dev3"
time="2025-04-24T09:09:49-07:00" level=info msg="Tool required for debug" tool="esp32:mklittlefs@3.0.0-gnu12-dc7f933"
time="2025-04-24T09:09:49-07:00" level=info msg="Tool required for debug" tool="esp32:mkspiffs@0.2.3"
time="2025-04-24T09:09:49-07:00" level=info msg="Tool required for debug" tool="esp32:openocd-esp32@v0.12.0-esp32-20241016"
time="2025-04-24T09:09:49-07:00" level=info msg="Tool required for debug" tool="esp32:riscv32-esp-elf-gdb@14.2_20240403"
time="2025-04-24T09:09:49-07:00" level=info msg="Tool required for debug" tool="esp32:xtensa-esp-elf-gdb@14.2_20240403"
time="2025-04-24T09:09:49-07:00" level=info msg="Tool required for debug" tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
time="2025-04-24T09:09:49-07:00" level=info msg="Tool required for debug" tool="Seeeduino:nrfjprog@9.4.0"
time="2025-04-24T09:09:49-07:00" level=info msg="Tool required for debug" tool="builtin:dfu-discovery@0.1.2"
time="2025-04-24T09:09:49-07:00" level=info msg="Tool required for debug" tool="builtin:serial-monitor@0.15.0"
time="2025-04-24T09:09:49-07:00" level=info msg="Tool required for debug" tool="arduino:avrdude@6.3.0-arduino17"
time="2025-04-24T09:09:49-07:00" level=info msg="Tool required for debug" tool="Seeeduino:bossac@1.9.1-arduino2"
time="2025-04-24T09:09:49-07:00" level=info msg="Tool required for debug" tool="builtin:mdns-discovery@1.0.9"
time="2025-04-24T09:09:49-07:00" level=info msg="Tool required for debug" tool="Seeeduino:CMSIS@5.7.0"
time="2025-04-24T09:09:49-07:00" level=info msg="Tool required for debug" tool="Seeeduino:arm-none-eabi-gcc@9-2019q4"
time="2025-04-24T09:09:49-07:00" level=info msg="Tool required for debug" tool="arduino:arduinoOTA@1.3.0"
time="2025-04-24T09:09:49-07:00" level=info msg="Tool required for debug" tool="Seeeduino:openocd@0.11.0-arduino2"
time="2025-04-24T09:09:49-07:00" level=info msg="Tool required for debug" tool="builtin:ctags@5.8-arduino11"
time="2025-04-24T09:09:49-07:00" level=info msg="Tool required for debug" tool="builtin:serial-discovery@1.4.1"
time="2025-04-24T09:09:50-07:00" level=info msg="Tool required for debug" tool="builtin:mdns-discovery@1.0.9"
time="2025-04-24T09:09:50-07:00" level=info msg="Tool required for debug" tool="builtin:serial-discovery@1.4.1"
time="2025-04-24T09:09:50-07:00" level=info msg="Tool required for debug" tool="arduino:arduinoOTA@1.3.0"
time="2025-04-24T09:09:50-07:00" level=info msg="Tool required for debug" tool="arduino:dfu-util@0.11.0-arduino5"
time="2025-04-24T09:09:50-07:00" level=info msg="Tool required for debug" tool="esp32:esp-rv32@2405"
time="2025-04-24T09:09:50-07:00" level=info msg="Tool required for debug" tool="esp32:esp-x32@2405"
time="2025-04-24T09:09:50-07:00" level=info msg="Tool required for debug" tool="esp32:esp32-arduino-libs@idf-release_v5.3-489d7a2b-v1"
time="2025-04-24T09:09:50-07:00" level=info msg="Tool required for debug" tool="esp32:esptool_py@4.9.dev3"
time="2025-04-24T09:09:50-07:00" level=info msg="Tool required for debug" tool="esp32:mklittlefs@3.0.0-gnu12-dc7f933"
time="2025-04-24T09:09:50-07:00" level=info msg="Tool required for debug" tool="esp32:mkspiffs@0.2.3"
time="2025-04-24T09:09:50-07:00" level=info msg="Tool required for debug" tool="esp32:openocd-esp32@v0.12.0-esp32-20241016"
time="2025-04-24T09:09:50-07:00" level=info msg="Tool required for debug" tool="esp32:riscv32-esp-elf-gdb@14.2_20240403"
time="2025-04-24T09:09:50-07:00" level=info msg="Tool required for debug" tool="esp32:xtensa-esp-elf-gdb@14.2_20240403"
time="2025-04-24T09:09:50-07:00" level=info msg="Tool required for debug" tool="builtin:serial-monitor@0.15.0"
time="2025-04-24T09:09:50-07:00" level=info msg="Tool required for debug" tool="builtin:ctags@5.8-arduino11"
time="2025-04-24T09:09:50-07:00" level=info msg="Tool required for debug" tool="builtin:dfu-discovery@0.1.2"
time="2025-04-24T09:09:50-07:00" level=info msg="Tool required for debug" tool="Seeeduino:arm-none-eabi-gcc@9-2019q4"
time="2025-04-24T09:09:50-07:00" level=info msg="Tool required for debug" tool="Seeeduino:openocd@0.11.0-arduino2"
time="2025-04-24T09:09:50-07:00" level=info msg="Tool required for debug" tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
time="2025-04-24T09:09:50-07:00" level=info msg="Tool required for debug" tool="Seeeduino:bossac@1.9.1-arduino2"
time="2025-04-24T09:09:50-07:00" level=info msg="Tool required for debug" tool="arduino:avrdude@6.3.0-arduino17"
time="2025-04-24T09:09:50-07:00" level=info msg="Tool required for debug" tool="Seeeduino:nrfjprog@9.4.0"
time="2025-04-24T09:09:50-07:00" level=info msg="Tool required for debug" tool="Seeeduino:CMSIS@5.7.0"
2025-04-24T16:09:50.040Z daemon INFO time="2025-04-24T09:09:50-07:00" level=info msg="Tool required for debug" tool="esp32:riscv32-esp-elf-gdb@14.2_20240403"
2025-04-24T16:09:50.041Z daemon INFO time="2025-04-24T09:09:50-07:00" level=info msg="Tool required for debug" tool="arduino:dfu-util@0.11.0-arduino5"
2025-04-24T16:09:50.041Z daemon INFO time="2025-04-24T09:09:50-07:00" level=info msg="Tool required for debug" tool="esp32:mklittlefs@3.0.0-gnu12-dc7f933"
2025-04-24T16:09:50.041Z daemon INFO time="2025-04-24T09:09:50-07:00" level=info msg="Tool required for debug" tool="Seeeduino:arm-none-eabi-gcc@9-2019q4"
2025-04-24T16:09:50.041Z daemon INFO time="2025-04-24T09:09:50-07:00" level=info msg="Tool required for debug" tool="builtin:serial-discovery@1.4.1"
2025-04-24T16:09:50.041Z daemon INFO time="2025-04-24T09:09:50-07:00" level=info msg="Tool required for debug" tool="builtin:mdns-discovery@1.0.9"
2025-04-24T16:09:50.041Z daemon INFO time="2025-04-24T09:09:50-07:00" level=info msg="Tool required for debug" tool="arduino:avrdude@6.3.0-arduino17"
2025-04-24T16:09:50.041Z daemon INFO time="2025-04-24T09:09:50-07:00" level=info msg="Tool required for debug" tool="Seeeduino:openocd@0.11.0-arduino2"
2025-04-24T16:09:50.042Z daemon INFO time="2025-04-24T09:09:50-07:00" level=info msg="Tool required for debug" tool="Seeeduino:CMSIS@5.7.0"
2025-04-24T16:09:50.045Z daemon INFO time="2025-04-24T09:09:50-07:00" level=info msg="Tool required for debug" tool="arduino:dfu-util@0.11.0-arduino5"
2025-04-24T16:09:50.045Z daemon INFO time="2025-04-24T09:09:50-07:00" level=info msg="Tool required for debug" tool="esp32:esp-x32@2405"
2025-04-24T16:09:50.045Z daemon INFO time="2025-04-24T09:09:50-07:00" level=info msg="Tool required for debug" tool="builtin:ctags@5.8-arduino11"
2025-04-24T16:09:50.045Z daemon INFO time="2025-04-24T09:09:50-07:00" level=info msg="Tool required for debug" tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
2025-04-24T16:09:50.045Z daemon INFO time="2025-04-24T09:09:50-07:00" level=info msg="Tool required for debug" tool="Seeeduino:CMSIS@5.7.0"
2025-04-24T16:09:50.045Z daemon INFO time="2025-04-24T09:09:50-07:00" level=info msg="Tool required for debug" tool="arduino:arduinoOTA@1.3.0"
2025-04-24T16:09:50.046Z daemon INFO time="2025-04-24T09:09:50-07:00" level=info msg="Tool required for debug" tool="Seeeduino:bossac@1.9.1-arduino2"
2025-04-24T16:09:50.047Z daemon INFO time="2025-04-24T09:09:50-07:00" level=info msg="Tool required for debug" tool="arduino:dfu-util@0.11.0-arduino5"
2025-04-24T16:09:50.047Z daemon INFO time="2025-04-24T09:09:50-07:00" level=info msg="Tool required for debug" tool="esp32:esp-x32@2405"
2025-04-24T16:09:50.047Z daemon INFO time="2025-04-24T09:09:50-07:00" level=info msg="Tool required for debug" tool="builtin:ctags@5.8-arduino11"
2025-04-24T16:09:50.047Z daemon INFO time="2025-04-24T09:09:50-07:00" level=info msg="Tool required for debug" tool="Seeeduino:arm-none-eabi-gcc@9-2019q4"
2025-04-24T16:09:50.047Z daemon INFO time="2025-04-24T09:09:50-07:00" level=info msg="Tool required for debug" tool="builtin:dfu-discovery@0.1.2"
2025-04-24T16:09:50.047Z daemon INFO time="2025-04-24T09:09:50-07:00" level=info msg="Tool required for debug" tool="arduino:arduinoOTA@1.3.0"
2025-04-24T16:09:50.079Z root INFO [hosted-plugin: 32660] PLUGIN_HOST(32660): PluginManagerExtImpl/loadPlugin(C:\Users\ziad\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-arduino-tools\extension\dist\extension.js)
2025-04-24T16:09:50.092Z root INFO [hosted-plugin: 32660] calling activation function on VS Code Arduino Tools
2025-04-24T16:09:50.130Z daemon INFO time="2025-04-24T09:09:50-07:00" level=info msg="Adding libraries dir" dir="C:\\Users\\ziad\\AppData\\Local\\Arduino15\\libraries" isSingleLibrary=false location=ide
2025-04-24T16:09:50.131Z daemon INFO time="2025-04-24T09:09:50-07:00" level=info msg="Adding libraries dir" dir="C:\\Users\\ziad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.1.3\\libraries" isSingleLibrary=false location=platform
2025-04-24T16:09:50.131Z daemon INFO time="2025-04-24T09:09:50-07:00" level=info msg="Adding libraries dir" dir="c:\\Users\\ziad\\Documents\\Arduino\\libraries" isSingleLibrary=false location=user
2025-04-24T16:09:53.651Z daemon INFO time="2025-04-24T09:09:53-07:00" level=info msg="Adding libraries dir" dir="C:\\Users\\ziad\\AppData\\Local\\Arduino15\\libraries" isSingleLibrary=false location=ide
2025-04-24T16:09:53.651Z daemon INFO time="2025-04-24T09:09:53-07:00" level=info msg="Adding libraries dir" dir="C:\\Users\\ziad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.1.3\\libraries" isSingleLibrary=false location=platform
2025-04-24T16:09:53.651Z daemon INFO time="2025-04-24T09:09:53-07:00" level=info msg="Adding libraries dir" dir="c:\\Users\\ziad\\Documents\\Arduino\\libraries" isSingleLibrary=false location=user
2025-04-24T16:10:38.729Z daemon INFO time="2025-04-24T09:10:38-07:00" level=info msg="Adding libraries dir" dir="C:\\Users\\ziad\\AppData\\Local\\Arduino15\\libraries" isSingleLibrary=false location=ide
2025-04-24T16:10:38.729Z daemon INFO time="2025-04-24T09:10:38-07:00" level=info msg="Adding libraries dir" dir="C:\\Users\\ziad\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.1.3\\libraries" isSingleLibrary=false location=platform
2025-04-24T16:10:38.729Z daemon INFO time="2025-04-24T09:10:38-07:00" level=info msg="Adding libraries dir" dir="c:\\Users\\ziad\\Documents\\Arduino\\libraries" isSingleLibrary=false location=user
Thanks for your help @ptillisch
OK, great I see the reason here:
It seems that the data in the settings.json file where Arduino IDE stores its settings has been corrupted somehow. Arduino IDE can't read the data from the file, so it must ignore it and use the default settings instead.
The fix will be to remove the corruption. I'll provide instructions you can follow to do that:
- Start Arduino IDE.
- Press the Ctrl+Shift+P keyboard shortcut (Command+Shift+P for macOS users) to open the "Command Palette".
A menu will appear on the editor toolbar:
- Select the "Preferences: Open Settings (JSON)" command from the menu.
ⓘ You can scroll down through the list of commands to find it, or type the command name in the field.
A "settings.json" tab will open in the Arduino IDE editor, which contains the settings data in JSON format. - Change line 22 from this:
to this:}#in} - Select File > Save from the Arduino IDE menus.
- Close the settings.json tab by clicking its X icon.
After fixing the corruption, when you select File > New Sketch from the Arduino IDE menus the new sketch should now be populated with the contents of your custom "blueprint" sketch.
I recommend avoiding editing settings.json in the future. You can modify the Arduino IDE advanced settings in a more convenient and safe manner through the GUI that is accessed by the procedure described here.
