I am trying to program an Arduino Uno to control a stepper motor.
I need 3 buttons.
Press it to turn the motor 1 step clockwise.
Press it to turn the motor 1 step anticlockwise.
Press it to turn the motor a set number of steps. This should only happen once per press of the button.
I have 2 sketches. One doesn't have any code for the first 2 buttons and works as expected. It indexes as it should do.
The other sketch has extra lines of code for the jog buttons but they don't work. Also, with this sketch, if the index button is pressed, the motor turns 1 step and then the other 400. If either of the jog buttons is pressed, nothing happens.
I used to have something very similar to this working years ago using the Button.h library but it doesn't work anymore. That's why I am now trying to get it working using the Pushbutton.h library instead.
Can anyone please offer advice to get the jog buttons working?
Thanks in advance.
I managed to get the sketch working. Sort of.
The index button works as it should do but the jog buttons do not always respond. I have to keep pressing them until the motor decides to move, whilst annoying that they don't work properly, I can work with it.
Can anybody offer any suggestions how to get the jog buttons to perform as they should?
Sketch is below.
#include <Pushbutton.h>
#include <Stepper.h>
const int stepsPerRevolution = 400; //set number of steps for motor
Pushbutton buttonIndex (2); //set cycle start button input on pin 2
Pushbutton buttonJogcw (4); //set jog clockwise button on pin 4
Pushbutton buttonJogccw (7); //set jog anticlockwise button on pin 7
Stepper myStepper(stepsPerRevolution,8,9,10,11); //set stepper motor on pins 8,9,10,11
void setup(){
myStepper.setSpeed(200); //set motor speed
void loop(){
if(buttonIndex.getSingleDebouncedPress()){myStepper.step(-400);}//set number of steps to move
if(buttonJogcw.getSingleDebouncedPress()){myStepper.step(-1);} //set to jog 1 step clockwise
if(buttonJogccw.getSingleDebouncedPress()){myStepper.step(1);} //set to jog 1 step anticlockwise
See how a little whitespace makes the program much easier to read
void setup(){
void loop(){
myStepper.step(-1);
myStepper.step(1);
I suspect the reason why your JOG buttons don't respond is because they have to wait until after the motor has moved its full 400 steps from the first IF statement. What happens if you comment out the line myStepper.step(-400);
I am not familiar with the Pushbutton library. Maybe a simple digitalRead() for the jog button would be better with code that says
if (jogCW == LOW) { // assumes LOW when pressed
myStepper.step(-1);
