SMA GPS antenna for HC12 module
Hello,
I don't find the information, so I ask you some help guys.
I have a HC12 module:
I've received a small antenna to solder to it (on ANT2), but I would like to avoid that.. I woud like to buy a GPS SMA antenna to connect on ANT1 instead, simply as : please see the attachment
But I don't know the name of the connector between ANT1 and the SMA cable?
Can anyone help me with the names of these components?
Thanks a lot :slight_smile:
Oh I think I found what I was searching, it's called : U.FL Mini PCI to RP-SMA (Pigtail) Antenna Cable
In products that I found it seems to be compatible for wifi routers, do you think that it will work for HC12? Are these frequencies even compatible ?
No.
GPS uses L band , 1575 Mhz .
HC-12 radios use 434 - 470 Mhz.
Not even vaguely compatible.
