Hey guys,
I want to modify my coffee grinder to have it start via an arduino board and stop at X gram using a scale attached to my arduino board. I am a software engineer and I know how to use a soldering iron, but i see this project happening only when i take the easiest route possible (because of the time i have).
I want to ask if you can suggest me any conplete scale / arduino kit with which i can
- measure weight to the tenth of a gram
- weigh up to a kilo ( the portafilter of my espresso machine is 650g)
- have the scale connect to an arduino board
- connect to the grinder with a simple i/o cable
- connect to the arduino wirelessly via bluetooth (or wifi) to set the desired g and start the grinder via an app
Do you have any recommendations for a kit i can use as a base to start from ?
Thanks,
Lukas
