So, I want to create a pair of smart glasses like these:
But, I want to know what wires I should probably use and which power module I should use. Maybe if I need the 10k preset, which bluetooth module (HC-06 or HC-05) or just need to redo the whole thing.
Your question is confusing. You can get #28 hook-up wires online. It looks like the instructions in the video used #22 which is a bit heavy for this application. And he really needs lessons on soldering.
Thanks! I also want to know if I should get rid of the 10k preset and if someone can recommend a power supply. Also, which video are you talking about?
Just try soldering thin wires to anything just to find out IF you can. Different people get different results so what YOU should use depends on YOU and not what someone else tells.
