Solderless Connector
What kind of solderless connector would I need?
TIA
What is the purpose of the pushbutton and associated resistor ?
If you use the internal pull-up resistor of the 328P ( pinMode(yourPin, INPUT_PULLUP) ) you (in general) don't need that resistor.
Note:
How may LEDs in the strip?
just 8
  • I don’t think you will be happy with a solderless connector.
    Instead, solder a 3 pin male connector (JST connectors are good) to the strip, a female JST goes to the Arduino.
IMG_3273
I tried using solderless, plastic "clip-on" connectors... I could not get them to work. The LED strip pads would fold or lift or break and the clip would slide off or bend. Connections would not last for me. Others have had better success. Best is to solder.
