trying to upgrade to newer version to check out serial plotter. The start screen comes up with loading configuration then disappears. if i run arduino_debug.exe from an administrator cmd prompt i get the following....
Microsoft Windows [Version 6.3.9600]
(c) 2013 Microsoft Corporation. All rights reserved.
C:\Program Files (x86)\Arduino>arduino_debug.exe
Loading configuration...
com.sun.jna.platform.win32.Win32Exception: The system cannot find the file speci
fied.
at com.sun.jna.platform.win32.Advapi32Util.registryGetStringValue(Advapi
32Util.java:580)
32Util.java:555)
at processing.app.windows.Platform.recoverSettingsFolderPath(Platform.ja
va:61)
at processing.app.windows.Platform.init(Platform.java:56)
at processing.app.Base.guardedMain(Base.java:151)
at processing.app.Base.main(Base.java:135)
i am running windows 8.1, updated the java and restarted (with the restart option) the computer but no change.
had an issue before with special characters in displayed username its the ' char, but have heard that was fixed. was looking through procmon but did not find anything that caught my eye.
proc mon shows:
High Resolution Date & Time: 11/27/2015 3:49:56.6286300 AM
Event Class: Registry
Operation: RegQueryValue
Result: NAME NOT FOUND
Path: HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\Shell Folders\Local AppData
TID: 5824
Duration: 0.0000039
Length: 144
which is different (Shell Folders, User Shell Folders) as that only contains one key:
!Do not use this registry key:Use the SHGetFolderPath or SHGetKnownFolderPath function instead
i copied over the "Local AppData", "Personal", and "AppData" keys from user shell folders to shell folders and IDE started.
the nightly download did not work either, not sure if others can reproduce this....
i had renamed that folder but still did not work. fixed issue by copying over registry keys that i documented above. the error makes sense when looking at the code. will file a bug report tomorrow and a patch.
