My xp fails to see my nano 's (two of) when I connect them to various usb ports on my xp computer (they work on my windows 7 computer).
I found this thread here pointing out that the usb 2.0 driver for the nano is located at the USB serial page and that it is an .inf file. I have loaded it into my computer but the computer fails to see it? I am obviously loading it into the wrong place and missing something.
Where am I supposed to put the .inf file and how does the computer see the driver?
update.
I have found the driver in , of all places, drivers directory. I have renamed it oldusb2.0 driver and loaded the new one I found, the computer still fails to find it and instead of the two ping sounds you get when you plug a unit in I get three lower frequency sounds as if the computer has seen the nano but fails to recognise it. I seem to remember this computer saw nano's a while ago but not now, anyone any idea what might be wrong? The unit still powers up and runs a program in it but I can't program it.
What kind of nanos are they? Official, or clones? Are they known working (ie, they work on other computers)?
Check the part number on the USB-serial interface (it'll probably be FTDI-something, or a CH340G, which was very common in clones). You need the correct driver for that part (there's nothing magic about the nano - it's just a pro mini + a serial adapter on the same PCB)
So basically a Duemilanove (when FT232 is used), but with A6/A7 (analog input only) brought out.
Try here for FT232
http://www.ftdichip.com/FTDrivers.htm
Links at bottom of the page to the driver types you wish to use (VCP or D2XX).
For CH430G (clone), browse the supplier website.
DrAzzy, see my first post :-
Thanks Chillitronix I found your link, loaded and ran it and both my nano's are now recognised.
Thanks Guys, your help was invaluable as usual.
I have XP sp3. My Nano 3.0 will not communicate since upgrading my IDE to 1.6.3. Tried everything in the troubleshooting section.
The link above is for a Chinese site and I can't figure out what download I need. Is there an English site?
