I connected an SD-card to my ESP32 WROOM 38 pins.
I can access the card, read the disc information, but can't open a file.
Here my code
PROGRAMNAME:
Name SD_card_01.ino
Version: 01
Author: xxx
Created: 4-5-2015
Edited by:
Modified: 06-04-2022
WHAT DOES THIS PROGRAM:
Demo initialize, open file, write to file, delete file, check if file exists
INFO:
https://docs.arduino.cc/learn/programming/sd-guide
https://www.arduino.cc/reference/en/libraries/sd/
https://www.mischianti.org/2021/03/28/how-to-use-sd-card-with-esp32-2/
HARDWARE:
- ESP32 WROOM, 38 pins mounted in CV-logger
- SD card attached to SPI bus as follows:
MOSI - pin P23
MISO - pin P19 + 10k puillup to .3 V
CLK - pin P18
CS - pin P5
TESTED ON:
IDE 1.8.19 and ESP32
//Inlcude libraries
#include <SD.h> //Version 1.2.4
#include <SPI.h>
const int chipSelect = 5;
//void printDirectory(File dir, int numTabs);
File myFile;
int n;
// set up variables using the SD utility library functions:
//Sd2Card card; //Removed 20220406
//SdVolume volume;
//SdFile root;
char chrFilename[] = "00000000.csv";
void setup(){
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
Serial.print("Initializing SD card...");
if (!SD.begin(chipSelect)) {
Serial.println("initialization failed!");
while (1);
Serial.println("initialization done."); int i;
// print the type of card
Serial.print("Card type: ");
switch (SD.cardType()) {
case CARD_NONE:
Serial.println("NONE");
case CARD_MMC:
Serial.println("MMC");
case CARD_SD:
Serial.println("SD");
case CARD_SDHC:
Serial.println("SDHC");
default:
Serial.println("Unknown");
// print the type and size of the first FAT-type volume
uint32_t volumesize;
Serial.print("Volume type is: FAT");
//Serial.println(SDFS.usefatType(), DEC);
Serial.print("Card size: ");
Serial.println((float)SD.cardSize()/1000);
Serial.print("Total bytes: ");
Serial.println(SD.totalBytes());
Serial.print("Used bytes: ");
Serial.println(SD.usedBytes());
//File dir = SD.open("/");
//printDirectory(dir, 0);
// open the file. note that only one file can be open at a time,
// so you have to close this one before opening another.
myFile = SD.open("test.txt", FILE_WRITE);
// if the file opened okay, write to it:
if (myFile) {
Serial.print("Writing to test.txt...");
myFile.println("testing 1, 2, 3.");
// close the file:
myFile.close();
Serial.println("done.");
// if the file didn't open, print an error:
Serial.println("error opening test.txt");
// re-open the file for reading:
myFile = SD.open("test.txt");
if (myFile) {
Serial.println("test.txt:");
// read from the file until there's nothing else in it:
while (myFile.available()) {
Serial.write(myFile.read());
// close the file:
myFile.close();
// nothing happens after setup
