I thought I could figure this out... but since I am asking here, you know that I didn't ![]()
I can't get SdFat to work.
Setup:
• STM32F103C8 BluePill clone
• Official ST Core
• Arduino IDE 1.8.13
• No bootloader installed
• Use Serial connection and STM32CubeProgrammer to program
• SD module wired to SPI1 (SS = PA4, SCK = PA5, MISO = PA6, and MOSI = PA7)
• SdFat v2.0.4
On the latest version of SdFat (v2.0.4) there is a example program that allow you to switch between SD.h and SdFat.h for SD card support using SPI.
Setting USE_SD_H to 1 uses SD.h. In this example, the SD card works without any issues:
Using SD.h. Set USE_SD_H zero to use SdFat.h.
Type any character to begin.
Initializing SD card...initialization done.
Writing to test.txt...done.
test.txt:
testing 1, 2, 3.
testing 1, 2, 3.
testing 1, 2, 3.
testing 1, 2, 3.
Then I set USE_SD_H to 0 to use SdFat and it doesn't work.
Using SdFat.h. Set USE_SD_H nonzero to use SD.h.
Initializing SD card...initialization failed!
After much testing, any SD example program using SD.h works. Any example program that uses SdFat.h doesn't work.
I had the same issue when using SdFat v1.1.4 then I upgraded to v2.0.4 hoping it worked, but it didn't.
Am I doing something wrong? I have tripled checked the wiring and since it does work on SD.h, it must be something else.
(Yes, I could just use SD.h, but I am excited to use some of the new features in SdFat v2, like long file names
