Hello,
I'm currently working on a scooter project and am trying to get a TFT display working so I can display some data for the rider. I'm trying to get a display output using the UCGlib, however I have found a very strange issue. I cannot seem to compile any UCGlib examples for the Arduino Nano Every. Some other libraries also fail as well. If I change the board to a normal Nano it compiles no problem. I have already tried wiping the board from the board manager both manually by deleting it and via the manager window. I have also reinstalled the IDE as well and still am stuck. I have previously been running code on the Arduino to control the speed via PWM to the ESC on my scooter and it has been working great.... until now.
Computer: Macbook Air running Big Sur 11.4
Code Output:
Arduino: 1.8.19 (Mac OS X), Board: "Arduino Nano Every, None (ATMEGA4809)"
/Users/ryanbaer/Desktop/Arduino.app/Contents/Java/arduino-builder -dump-prefs -logger=machine -hardware /Users/ryanbaer/Desktop/Arduino.app/Contents/Java/hardware -hardware /Users/ryanbaer/Library/Arduino15/packages -tools /Users/ryanbaer/Desktop/Arduino.app/Contents/Java/tools-builder -tools /Users/ryanbaer/Desktop/Arduino.app/Contents/Java/hardware/tools/avr -tools /Users/ryanbaer/Library/Arduino15/packages -built-in-libraries /Users/ryanbaer/Desktop/Arduino.app/Contents/Java/libraries -libraries /Users/ryanbaer/Documents/Arduino/libraries -fqbn=arduino:megaavr:nona4809:mode=off -ide-version=10819 -build-path /var/folders/8c/zddk8qfd4hg93m59znbn5svr0000gn/T/arduino_build_160426 -warnings=none -build-cache /var/folders/8c/zddk8qfd4hg93m59znbn5svr0000gn/T/arduino_cache_750077 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=/Users/ryanbaer/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino5 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino5.path=/Users/ryanbaer/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino5 -prefs=runtime.tools.arduinoOTA.path=/Users/ryanbaer/Library/Arduino15/packages/arduino/tools/arduinoOTA/1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=/Users/ryanbaer/Library/Arduino15/packages/arduino/tools/arduinoOTA/1.3.0 -prefs=runtime.tools.avrdude.path=/Users/ryanbaer/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=/Users/ryanbaer/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17 -verbose /var/folders/8c/zddk8qfd4hg93m59znbn5svr0000gn/T/arduino_modified_sketch_331219/HelloWorld.ino
/Users/ryanbaer/Desktop/Arduino.app/Contents/Java/arduino-builder -compile -logger=machine -hardware /Users/ryanbaer/Desktop/Arduino.app/Contents/Java/hardware -hardware /Users/ryanbaer/Library/Arduino15/packages -tools /Users/ryanbaer/Desktop/Arduino.app/Contents/Java/tools-builder -tools /Users/ryanbaer/Desktop/Arduino.app/Contents/Java/hardware/tools/avr -tools /Users/ryanbaer/Library/Arduino15/packages -built-in-libraries /Users/ryanbaer/Desktop/Arduino.app/Contents/Java/libraries -libraries /Users/ryanbaer/Documents/Arduino/libraries -fqbn=arduino:megaavr:nona4809:mode=off -ide-version=10819 -build-path /var/folders/8c/zddk8qfd4hg93m59znbn5svr0000gn/T/arduino_build_160426 -warnings=none -build-cache /var/folders/8c/zddk8qfd4hg93m59znbn5svr0000gn/T/arduino_cache_750077 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=/Users/ryanbaer/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino5 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino5.path=/Users/ryanbaer/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino5 -prefs=runtime.tools.arduinoOTA.path=/Users/ryanbaer/Library/Arduino15/packages/arduino/tools/arduinoOTA/1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=/Users/ryanbaer/Library/Arduino15/packages/arduino/tools/arduinoOTA/1.3.0 -prefs=runtime.tools.avrdude.path=/Users/ryanbaer/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=/Users/ryanbaer/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17 -verbose /var/folders/8c/zddk8qfd4hg93m59znbn5svr0000gn/T/arduino_modified_sketch_331219/HelloWorld.ino
Using board 'nona4809' from platform in folder: /Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7
Using core 'arduino' from platform in folder: /Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7
Detecting libraries used...
/Users/ryanbaer/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino5/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO_EVERY -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 -DNO_EXTERNAL_I2C_PULLUP -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino/api/deprecated -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/variants/nona4809 /var/folders/8c/zddk8qfd4hg93m59znbn5svr0000gn/T/arduino_build_160426/sketch/HelloWorld.ino.cpp -o /dev/null
Alternatives for SPI.h: [SPI@1.0]
ResolveLibrary(SPI.h)
-> candidates: [SPI@1.0]
/Users/ryanbaer/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino5/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO_EVERY -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 -DNO_EXTERNAL_I2C_PULLUP -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino/api/deprecated -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/variants/nona4809 -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/libraries/SPI/src /var/folders/8c/zddk8qfd4hg93m59znbn5svr0000gn/T/arduino_build_160426/sketch/HelloWorld.ino.cpp -o /dev/null
Alternatives for Ucglib.h: [Ucglib@1.5.2]
ResolveLibrary(Ucglib.h)
-> candidates: [Ucglib@1.5.2]
/Users/ryanbaer/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino5/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO_EVERY -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 -DNO_EXTERNAL_I2C_PULLUP -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino/api/deprecated -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/variants/nona4809 -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/libraries/SPI/src -I/Users/ryanbaer/Documents/Arduino/libraries/Ucglib/src /var/folders/8c/zddk8qfd4hg93m59znbn5svr0000gn/T/arduino_build_160426/sketch/HelloWorld.ino.cpp -o /dev/null
Using cached library dependencies for file: /Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/libraries/SPI/src/SPI.cpp
/Users/ryanbaer/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino5/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO_EVERY -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 -DNO_EXTERNAL_I2C_PULLUP -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino/api/deprecated -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/variants/nona4809 -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/libraries/SPI/src -I/Users/ryanbaer/Documents/Arduino/libraries/Ucglib/src /Users/ryanbaer/Documents/Arduino/libraries/Ucglib/src/Ucglib.cpp -o /dev/null
/Users/ryanbaer/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino5/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO_EVERY -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 -DNO_EXTERNAL_I2C_PULLUP -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino/api/deprecated -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/variants/nona4809 -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/libraries/SPI/src -I/Users/ryanbaer/Documents/Arduino/libraries/Ucglib/src /Users/ryanbaer/Documents/Arduino/libraries/Ucglib/src/clib/ucg_bitmap.c -o /dev/null
/Users/ryanbaer/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino5/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO_EVERY -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 -DNO_EXTERNAL_I2C_PULLUP -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino/api/deprecated -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/variants/nona4809 -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/libraries/SPI/src -I/Users/ryanbaer/Documents/Arduino/libraries/Ucglib/src /Users/ryanbaer/Documents/Arduino/libraries/Ucglib/src/clib/ucg_box.c -o /dev/null
/Users/ryanbaer/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino5/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO_EVERY -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 -DNO_EXTERNAL_I2C_PULLUP -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino/api/deprecated -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/variants/nona4809 -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/libraries/SPI/src -I/Users/ryanbaer/Documents/Arduino/libraries/Ucglib/src /Users/ryanbaer/Documents/Arduino/libraries/Ucglib/src/clib/ucg_ccs.c -o /dev/null
/Users/ryanbaer/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino5/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO_EVERY -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 -DNO_EXTERNAL_I2C_PULLUP -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino/api/deprecated -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/variants/nona4809 -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/libraries/SPI/src -I/Users/ryanbaer/Documents/Arduino/libraries/Ucglib/src /Users/ryanbaer/Documents/Arduino/libraries/Ucglib/src/clib/ucg_circle.c -o /dev/null
/Users/ryanbaer/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino5/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO_EVERY -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 -DNO_EXTERNAL_I2C_PULLUP -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino/api/deprecated -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/variants/nona4809 -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/libraries/SPI/src -I/Users/ryanbaer/Documents/Arduino/libraries/Ucglib/src /Users/ryanbaer/Documents/Arduino/libraries/Ucglib/src/clib/ucg_clip.c -o /dev/null
/Users/ryanbaer/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino5/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO_EVERY -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 -DNO_EXTERNAL_I2C_PULLUP -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino/api/deprecated -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/variants/nona4809 -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/libraries/SPI/src -I/Users/ryanbaer/Documents/Arduino/libraries/Ucglib/src /Users/ryanbaer/Documents/Arduino/libraries/Ucglib/src/clib/ucg_com_msg_api.c -o /dev/null
/Users/ryanbaer/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino5/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO_EVERY -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 -DNO_EXTERNAL_I2C_PULLUP -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino/api/deprecated -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/variants/nona4809 -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/libraries/SPI/src -I/Users/ryanbaer/Documents/Arduino/libraries/Ucglib/src /Users/ryanbaer/Documents/Arduino/libraries/Ucglib/src/clib/ucg_dev_default_cb.c -o /dev/null
/Users/ryanbaer/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino5/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO_EVERY -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 -DNO_EXTERNAL_I2C_PULLUP -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino/api/deprecated -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/variants/nona4809 -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/libraries/SPI/src -I/Users/ryanbaer/Documents/Arduino/libraries/Ucglib/src /Users/ryanbaer/Documents/Arduino/libraries/Ucglib/src/clib/ucg_dev_ic_hx8352c.c -o /dev/null
/Users/ryanbaer/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino5/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO_EVERY -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 -DNO_EXTERNAL_I2C_PULLUP -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino/api/deprecated -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/variants/nona4809 -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/libraries/SPI/src -I/Users/ryanbaer/Documents/Arduino/libraries/Ucglib/src /Users/ryanbaer/Documents/Arduino/libraries/Ucglib/src/clib/ucg_dev_ic_ili9163.c -o /dev/null
/Users/ryanbaer/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino5/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO_EVERY -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 -DNO_EXTERNAL_I2C_PULLUP -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino/api/deprecated -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/variants/nona4809 -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/libraries/SPI/src -I/Users/ryanbaer/Documents/Arduino/libraries/Ucglib/src /Users/ryanbaer/Documents/Arduino/libraries/Ucglib/src/clib/ucg_dev_ic_ili9325.c -o /dev/null
/Users/ryanbaer/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino5/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO_EVERY -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 -DNO_EXTERNAL_I2C_PULLUP -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino/api/deprecated -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/variants/nona4809 -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/libraries/SPI/src -I/Users/ryanbaer/Documents/Arduino/libraries/Ucglib/src /Users/ryanbaer/Documents/Arduino/libraries/Ucglib/src/clib/ucg_dev_ic_ili9325_spi.c -o /dev/null
/Users/ryanbaer/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino5/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO_EVERY -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 -DNO_EXTERNAL_I2C_PULLUP -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino/api/deprecated -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/variants/nona4809 -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/libraries/SPI/src -I/Users/ryanbaer/Documents/Arduino/libraries/Ucglib/src /Users/ryanbaer/Documents/Arduino/libraries/Ucglib/src/clib/ucg_dev_ic_ili9341.c -o /dev/null
/Users/ryanbaer/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino5/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO_EVERY -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 -DNO_EXTERNAL_I2C_PULLUP -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino/api/deprecated -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/variants/nona4809 -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/libraries/SPI/src -I/Users/ryanbaer/Documents/Arduino/libraries/Ucglib/src /Users/ryanbaer/Documents/Arduino/libraries/Ucglib/src/clib/ucg_dev_ic_ili9486.c -o /dev/null
/Users/ryanbaer/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino5/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO_EVERY -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 -DNO_EXTERNAL_I2C_PULLUP -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino/api/deprecated -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/variants/nona4809 -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/libraries/SPI/src -I/Users/ryanbaer/Documents/Arduino/libraries/Ucglib/src /Users/ryanbaer/Documents/Arduino/libraries/Ucglib/src/clib/ucg_dev_ic_ld50t6160.c -o /dev/null
/Users/ryanbaer/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino5/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO_EVERY -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 -DNO_EXTERNAL_I2C_PULLUP -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino/api/deprecated -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/variants/nona4809 -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/libraries/SPI/src -I/Users/ryanbaer/Documents/Arduino/libraries/Ucglib/src /Users/ryanbaer/Documents/Arduino/libraries/Ucglib/src/clib/ucg_dev_ic_pcf8833.c -o /dev/null
/Users/ryanbaer/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino5/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO_EVERY -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 -DNO_EXTERNAL_I2C_PULLUP -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino/api/deprecated -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/variants/nona4809 -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/libraries/SPI/src -I/Users/ryanbaer/Documents/Arduino/libraries/Ucglib/src /Users/ryanbaer/Documents/Arduino/libraries/Ucglib/src/clib/ucg_dev_ic_seps225.c -o /dev/null
/Users/ryanbaer/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino5/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO_EVERY -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 -DNO_EXTERNAL_I2C_PULLUP -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino/api/deprecated -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/variants/nona4809 -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/libraries/SPI/src -I/Users/ryanbaer/Documents/Arduino/libraries/Ucglib/src /Users/ryanbaer/Documents/Arduino/libraries/Ucglib/src/clib/ucg_dev_ic_ssd1289.c -o /dev/null
/Users/ryanbaer/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino5/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO_EVERY -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 -DNO_EXTERNAL_I2C_PULLUP -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino/api/deprecated -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/variants/nona4809 -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/libraries/SPI/src -I/Users/ryanbaer/Documents/Arduino/libraries/Ucglib/src /Users/ryanbaer/Documents/Arduino/libraries/Ucglib/src/clib/ucg_dev_ic_ssd1331.c -o /dev/null
/Users/ryanbaer/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino5/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO_EVERY -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 -DNO_EXTERNAL_I2C_PULLUP -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino/api/deprecated -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/variants/nona4809 -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/libraries/SPI/src -I/Users/ryanbaer/Documents/Arduino/libraries/Ucglib/src /Users/ryanbaer/Documents/Arduino/libraries/Ucglib/src/clib/ucg_dev_ic_ssd1351.c -o /dev/null
/Users/ryanbaer/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino5/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO_EVERY -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 -DNO_EXTERNAL_I2C_PULLUP -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino/api/deprecated -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/variants/nona4809 -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/libraries/SPI/src -I/Users/ryanbaer/Documents/Arduino/libraries/Ucglib/src /Users/ryanbaer/Documents/Arduino/libraries/Ucglib/src/clib/ucg_dev_ic_st7735.c -o /dev/null
/Users/ryanbaer/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino5/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO_EVERY -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 -DNO_EXTERNAL_I2C_PULLUP -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino/api/deprecated -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/variants/nona4809 -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/libraries/SPI/src -I/Users/ryanbaer/Documents/Arduino/libraries/Ucglib/src /Users/ryanbaer/Documents/Arduino/libraries/Ucglib/src/clib/ucg_dev_msg_api.c -o /dev/null
/Users/ryanbaer/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino5/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO_EVERY -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 -DNO_EXTERNAL_I2C_PULLUP -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino/api/deprecated -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/variants/nona4809 -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/libraries/SPI/src -I/Users/ryanbaer/Documents/Arduino/libraries/Ucglib/src /Users/ryanbaer/Documents/Arduino/libraries/Ucglib/src/clib/ucg_dev_oled_128x128_ft.c -o /dev/null
/Users/ryanbaer/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino5/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO_EVERY -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 -DNO_EXTERNAL_I2C_PULLUP -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino/api/deprecated -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/variants/nona4809 -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/libraries/SPI/src -I/Users/ryanbaer/Documents/Arduino/libraries/Ucglib/src /Users/ryanbaer/Documents/Arduino/libraries/Ucglib/src/clib/ucg_dev_oled_128x128_ilsoft.c -o /dev/null
/Users/ryanbaer/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino5/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO_EVERY -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 -DNO_EXTERNAL_I2C_PULLUP -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino/api/deprecated -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/variants/nona4809 -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/libraries/SPI/src -I/Users/ryanbaer/Documents/Arduino/libraries/Ucglib/src /Users/ryanbaer/Documents/Arduino/libraries/Ucglib/src/clib/ucg_dev_oled_128x128_univision.c -o /dev/null
/Users/ryanbaer/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino5/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO_EVERY -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 -DNO_EXTERNAL_I2C_PULLUP -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino/api/deprecated -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/variants/nona4809 -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/libraries/SPI/src -I/Users/ryanbaer/Documents/Arduino/libraries/Ucglib/src /Users/ryanbaer/Documents/Arduino/libraries/Ucglib/src/clib/ucg_dev_oled_160x128_samsung.c -o /dev/null
/Users/ryanbaer/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino5/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO_EVERY -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 -DNO_EXTERNAL_I2C_PULLUP -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino/api/deprecated -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/variants/nona4809 -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/libraries/SPI/src -I/Users/ryanbaer/Documents/Arduino/libraries/Ucglib/src /Users/ryanbaer/Documents/Arduino/libraries/Ucglib/src/clib/ucg_dev_oled_96x64_univision.c -o /dev/null
/Users/ryanbaer/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino5/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO_EVERY -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 -DNO_EXTERNAL_I2C_PULLUP -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino/api/deprecated -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/variants/nona4809 -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/libraries/SPI/src -I/Users/ryanbaer/Documents/Arduino/libraries/Ucglib/src /Users/ryanbaer/Documents/Arduino/libraries/Ucglib/src/clib/ucg_dev_tft_128x128_ili9163.c -o /dev/null
/Users/ryanbaer/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino5/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO_EVERY -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 -DNO_EXTERNAL_I2C_PULLUP -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino/api/deprecated -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/variants/nona4809 -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/libraries/SPI/src -I/Users/ryanbaer/Documents/Arduino/libraries/Ucglib/src /Users/ryanbaer/Documents/Arduino/libraries/Ucglib/src/clib/ucg_dev_tft_128x160_st7735.c -o /dev/null
/Users/ryanbaer/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino5/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO_EVERY -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 -DNO_EXTERNAL_I2C_PULLUP -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino/api/deprecated -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/variants/nona4809 -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/libraries/SPI/src -I/Users/ryanbaer/Documents/Arduino/libraries/Ucglib/src /Users/ryanbaer/Documents/Arduino/libraries/Ucglib/src/clib/ucg_dev_tft_132x132_pcf8833.c -o /dev/null
/Users/ryanbaer/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino5/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO_EVERY -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 -DNO_EXTERNAL_I2C_PULLUP -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino/api/deprecated -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/variants/nona4809 -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/libraries/SPI/src -I/Users/ryanbaer/Documents/Arduino/libraries/Ucglib/src /Users/ryanbaer/Documents/Arduino/libraries/Ucglib/src/clib/ucg_dev_tft_240x320_ili9325_spi.c -o /dev/null
/Users/ryanbaer/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino5/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO_EVERY -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 -DNO_EXTERNAL_I2C_PULLUP -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino/api/deprecated -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/variants/nona4809 -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/libraries/SPI/src -I/Users/ryanbaer/Documents/Arduino/libraries/Ucglib/src /Users/ryanbaer/Documents/Arduino/libraries/Ucglib/src/clib/ucg_dev_tft_240x320_ili9341.c -o /dev/null
/Users/ryanbaer/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino5/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO_EVERY -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 -DNO_EXTERNAL_I2C_PULLUP -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino/api/deprecated -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/variants/nona4809 -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/libraries/SPI/src -I/Users/ryanbaer/Documents/Arduino/libraries/Ucglib/src /Users/ryanbaer/Documents/Arduino/libraries/Ucglib/src/clib/ucg_dev_tft_240x320_itdb02.c -o /dev/null
/Users/ryanbaer/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino5/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO_EVERY -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 -DNO_EXTERNAL_I2C_PULLUP -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino/api/deprecated -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/variants/nona4809 -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/libraries/SPI/src -I/Users/ryanbaer/Documents/Arduino/libraries/Ucglib/src /Users/ryanbaer/Documents/Arduino/libraries/Ucglib/src/clib/ucg_dev_tft_240x320_ssd1289.c -o /dev/null
/Users/ryanbaer/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino5/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO_EVERY -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 -DNO_EXTERNAL_I2C_PULLUP -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino/api/deprecated -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/variants/nona4809 -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/libraries/SPI/src -I/Users/ryanbaer/Documents/Arduino/libraries/Ucglib/src /Users/ryanbaer/Documents/Arduino/libraries/Ucglib/src/clib/ucg_dev_tft_240x400_hx8352c.c -o /dev/null
/Users/ryanbaer/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino5/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO_EVERY -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 -DNO_EXTERNAL_I2C_PULLUP -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino/api/deprecated -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/variants/nona4809 -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/libraries/SPI/src -I/Users/ryanbaer/Documents/Arduino/libraries/Ucglib/src /Users/ryanbaer/Documents/Arduino/libraries/Ucglib/src/clib/ucg_dev_tft_320x480_ili9486.c -o /dev/null
/Users/ryanbaer/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino5/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO_EVERY -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 -DNO_EXTERNAL_I2C_PULLUP -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino/api/deprecated -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/variants/nona4809 -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/libraries/SPI/src -I/Users/ryanbaer/Documents/Arduino/libraries/Ucglib/src /Users/ryanbaer/Documents/Arduino/libraries/Ucglib/src/clib/ucg_font.c -o /dev/null
/Users/ryanbaer/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino5/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO_EVERY -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 -DNO_EXTERNAL_I2C_PULLUP -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino/api/deprecated -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/variants/nona4809 -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/libraries/SPI/src -I/Users/ryanbaer/Documents/Arduino/libraries/Ucglib/src /Users/ryanbaer/Documents/Arduino/libraries/Ucglib/src/clib/ucg_init.c -o /dev/null
/Users/ryanbaer/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino5/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO_EVERY -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 -DNO_EXTERNAL_I2C_PULLUP -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino/api/deprecated -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/variants/nona4809 -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/libraries/SPI/src -I/Users/ryanbaer/Documents/Arduino/libraries/Ucglib/src /Users/ryanbaer/Documents/Arduino/libraries/Ucglib/src/clib/ucg_line.c -o /dev/null
/Users/ryanbaer/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino5/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO_EVERY -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 -DNO_EXTERNAL_I2C_PULLUP -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino/api/deprecated -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/variants/nona4809 -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/libraries/SPI/src -I/Users/ryanbaer/Documents/Arduino/libraries/Ucglib/src /Users/ryanbaer/Documents/Arduino/libraries/Ucglib/src/clib/ucg_pixel.c -o /dev/null
/Users/ryanbaer/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino5/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO_EVERY -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 -DNO_EXTERNAL_I2C_PULLUP -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino/api/deprecated -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/variants/nona4809 -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/libraries/SPI/src -I/Users/ryanbaer/Documents/Arduino/libraries/Ucglib/src /Users/ryanbaer/Documents/Arduino/libraries/Ucglib/src/clib/ucg_pixel_font_data.c -o /dev/null
/Users/ryanbaer/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino5/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO_EVERY -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 -DNO_EXTERNAL_I2C_PULLUP -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino/api/deprecated -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/variants/nona4809 -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/libraries/SPI/src -I/Users/ryanbaer/Documents/Arduino/libraries/Ucglib/src /Users/ryanbaer/Documents/Arduino/libraries/Ucglib/src/clib/ucg_polygon.c -o /dev/null
/Users/ryanbaer/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino5/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO_EVERY -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 -DNO_EXTERNAL_I2C_PULLUP -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino/api/deprecated -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/variants/nona4809 -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/libraries/SPI/src -I/Users/ryanbaer/Documents/Arduino/libraries/Ucglib/src /Users/ryanbaer/Documents/Arduino/libraries/Ucglib/src/clib/ucg_rotate.c -o /dev/null
/Users/ryanbaer/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino5/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO_EVERY -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 -DNO_EXTERNAL_I2C_PULLUP -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino/api/deprecated -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/variants/nona4809 -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/libraries/SPI/src -I/Users/ryanbaer/Documents/Arduino/libraries/Ucglib/src /Users/ryanbaer/Documents/Arduino/libraries/Ucglib/src/clib/ucg_scale.c -o /dev/null
/Users/ryanbaer/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino5/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO_EVERY -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 -DNO_EXTERNAL_I2C_PULLUP -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino/api/deprecated -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/variants/nona4809 -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/libraries/SPI/src -I/Users/ryanbaer/Documents/Arduino/libraries/Ucglib/src /Users/ryanbaer/Documents/Arduino/libraries/Ucglib/src/clib/ucg_vector_font_data.c -o /dev/null
Generating function prototypes...
/Users/ryanbaer/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino5/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO_EVERY -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 -DNO_EXTERNAL_I2C_PULLUP -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino/api/deprecated -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/variants/nona4809 -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/libraries/SPI/src -I/Users/ryanbaer/Documents/Arduino/libraries/Ucglib/src /var/folders/8c/zddk8qfd4hg93m59znbn5svr0000gn/T/arduino_build_160426/sketch/HelloWorld.ino.cpp -o /var/folders/8c/zddk8qfd4hg93m59znbn5svr0000gn/T/arduino_build_160426/preproc/ctags_target_for_gcc_minus_e.cpp
/Users/ryanbaer/Desktop/Arduino.app/Contents/Java/tools-builder/ctags/5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives /var/folders/8c/zddk8qfd4hg93m59znbn5svr0000gn/T/arduino_build_160426/preproc/ctags_target_for_gcc_minus_e.cpp
Compiling sketch...
/Users/ryanbaer/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino5/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO_EVERY -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 -DNO_EXTERNAL_I2C_PULLUP -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino/api/deprecated -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/variants/nona4809 -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/libraries/SPI/src -I/Users/ryanbaer/Documents/Arduino/libraries/Ucglib/src /var/folders/8c/zddk8qfd4hg93m59znbn5svr0000gn/T/arduino_build_160426/sketch/HelloWorld.ino.cpp -o /var/folders/8c/zddk8qfd4hg93m59znbn5svr0000gn/T/arduino_build_160426/sketch/HelloWorld.ino.cpp.o
Compiling libraries...
Compiling library "SPI"
Using previously compiled file: /var/folders/8c/zddk8qfd4hg93m59znbn5svr0000gn/T/arduino_build_160426/libraries/SPI/SPI.cpp.o
Compiling library "Ucglib"
/Users/ryanbaer/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino5/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO_EVERY -DARDUINO_ARCH_MEGAAVR -DMILLIS_USE_TIMERB3 -DNO_EXTERNAL_I2C_PULLUP -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino/api/deprecated -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/variants/nona4809 -I/Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/libraries/SPI/src -I/Users/ryanbaer/Documents/Arduino/libraries/Ucglib/src /Users/ryanbaer/Documents/Arduino/libraries/Ucglib/src/Ucglib.cpp -o /var/folders/8c/zddk8qfd4hg93m59znbn5svr0000gn/T/arduino_build_160426/libraries/Ucglib/Ucglib.cpp.o
/Users/ryanbaer/Documents/Arduino/libraries/Ucglib/src/Ucglib.cpp: In function 'void ucg_com_arduino_port_d_send(uint8_t, volatile uint8_t*, uint8_t, uint8_t)':
/Users/ryanbaer/Documents/Arduino/libraries/Ucglib/src/Ucglib.cpp:1057:13: error: no match for 'operator=' (operand types are 'PORT_t {aka PORT_struct}' and 'uint8_t {aka unsigned char}')
PORTD = data;
In file included from /Users/ryanbaer/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino5/avr/include/avr/io.h:677:0,
from /Users/ryanbaer/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino5/avr/include/avr/pgmspace.h:90,
from /Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino/api/String.h:31,
from /Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino/api/IPAddress.h:24,
from /Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino/api/ArduinoAPI.h:30,
from /Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino/Arduino.h:23,
from /Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/libraries/SPI/src/SPI.h:23,
from /Users/ryanbaer/Documents/Arduino/libraries/Ucglib/src/Ucglib.cpp:39:
/Users/ryanbaer/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino5/avr/include/avr/iom4809.h:1059:16: note: candidate: PORT_struct& PORT_struct::operator=(const PORT_struct&)
typedef struct PORT_struct
/Users/ryanbaer/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino5/avr/include/avr/iom4809.h:1059:16: note: no known conversion for argument 1 from 'uint8_t {aka unsigned char}' to 'const PORT_struct&'
/Users/ryanbaer/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino5/avr/include/avr/iom4809.h:1059:16: note: candidate: PORT_struct& PORT_struct::operator=(PORT_struct&&)
/Users/ryanbaer/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino5/avr/include/avr/iom4809.h:1059:16: note: no known conversion for argument 1 from 'uint8_t {aka unsigned char}' to 'PORT_struct&&'
Using library SPI at version 1.0 in folder: /Users/ryanbaer/Library/Arduino15/packages/arduino/hardware/megaavr/1.8.7/libraries/SPI
Using library Ucglib at version 1.5.2 in folder: /Users/ryanbaer/Documents/Arduino/libraries/Ucglib
exit status 1
Error compiling for board Arduino Nano Every.
