somebody can tell the mean.
int ultraSoundSignalPins = {0,1}; // 2 Ultrasound signal pins
int ultraSoundTriggerPin = 6; // output pin to start Ultrasound signals
int pwm_a = 3;
int pwm_b = 11;
int dir_a = 12;
int dir_b = 13;
unsigned char analogPin = 0;
for(int i=0; i < 2; i++) {
pinMode(ultraSoundSignalPins*, INPUT); // Switch signalpin to input*
  • pinMode(ultraSoundTriggerPin, OUTPUT); // set this pin to output*
  • //give the sensors time to boot up*
  • delay(250);*
  • // send RX pin high to signal to chain to ping*
  • digitalWrite(ultraSoundTriggerPin, HIGH);*
  • delayMicroseconds(30);*
  • digitalWrite(ultraSoundTriggerPin, LOW);*
  • pinMode(ultraSoundTriggerPin, INPUT); // electrically disconnects the pin*
  • delay(50);*
    this i do not unstander ?
    what it means.
  • for(int i=0; i < 2; i++) {*
    _ pinMode(ultraSoundSignalPins*, INPUT); // Switch signalpin to input*_
    * pinMode(ultraSoundTriggerPin, OUTPUT); // set this pin to output*
    * //give the sensors time to boot up*
    * delay(250);*
    * // send RX pin high to signal to chain to ping*
    * digitalWrite(ultraSoundTriggerPin, HIGH);*
    * delayMicroseconds(30);*
    * digitalWrite(ultraSoundTriggerPin, LOW);*
    * pinMode(ultraSoundTriggerPin, INPUT); // electrically disconnects the pin*
    * delay(50);*
Two things 1) go back to that post by hitting modify, select the code, hit the # icon and save. 2) Can you point out what you don't understand in the code. The Serial.begin just under the arrow is a mistake, it should be removed.
What are you asking? What are you trying to accomplish with the code? It looks like you are chaining two Maxbotix ultrasonic sensors. Where is your loop? \http://www.maxbotix.com/downloads.htm There you'll find links to datasheets, quick start guides, etc. If you're more specific with your question, you may get a more specific answer.
