Sound bank chip
Hello! I am looking to build a toy with Arduino that needs to play a bunch of sounds e.g. "fire shot", "you are dead!", "explosion" etc.
I am probably fine with a total memory of 8-10 seconds. I am not interested in the SD Mp3 or Wav players out there I need a simpler solution (preferably a bread board) that <<attention!>> allows me to play more than one pre-recorded sound (on non volatile memory). Very similar to a talking toy that reacts and plays messages depending on user's action.
Please advice me and sorry if this has already been answered; I did several searches but didn't find anything to clarify my entire question. And yes, I've seen those 8s record/playback chips on ebay however I need to be able to play 5-6 different sounds ...
Thanks!
p.s. Speakjet from SpeakJet.com is waaay to expensive at $25usd... I need something simpler an cheaper
How about $8?
Add an inexpensive Promini to sense user's inputs and send appropriate command message to the player.
I think some of these will respond to button inputs directly also.
...nope that won't work they all need a source (e.g. SD) I need a chip that stores the samples inside on a non volatile type of memory. Do you know those kids toys that are producing sounds when a button is pressed? Or the singing "post card"? That is what I need in a cost effective package.
  1. ability to write and store 4-6 samples
  2. I2C control (preferred)
  3. ability to play back the stored samples (or portions of them)
  4. hi-quality sound is NOT a mandatory feature. Mono 22khz is plenty for what I need.
  5. an integrated sound amplifier on the board would be nice.
I've found chips that are able to record 10seconds and play it back however I am not sure I can play back just a section(e.g. 2.500ms - 4.450ms) of the 10s sound as that would serve my purpose.
Here is the aforementioned chip http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=160883881867&refid=store&tfrom=150916490980&tpos=unknow&ttype=price&talgo=origal
This is a cheap sound player $3.50 (but again needs an SD and that makes it unreliable long term)
U-disk audio player TF SD card voice module MP3 Sound WTV020-SD-16P Arduino | eBay
Hey dude.
I'm looking the same of you.
Perhaps, your are looking for a DataFlash Chips.
Most of them are simple 8pin chips and needs a Microcontroller for Data Store and Read.
Wikipedia:
Some docuementations:
This is a 16MBit Dataflash
Im not sure how implement this, and some of this DataFlash are documentated for work in AVR Atmel Controllers
like this: http://www.atmel.com/Images/doc1456.pdf (This is a Audio Player/Recorder make with DataFlash and AVR Risc Microcontroller)
Also, I found a Library for Arduino: Arduino Playground - Dataflash
But if we dive more deeper im sure we can get something like we want. :wink:
BlueIronThiever:
Hey dude.
Every Arduino microcontroller has buil-in flash memory. An UNO has 32KB.
If you just want to play short snippets of low-qulity ("speech quality") audio sound, you can store the sound data within the same Arduino program which acts as the player program.
See here:
http://playground.arduino.cc/Code/PCMAudio
You not even need 8-bit/8000Hz PCM audio for short voice messages. 8-bit 4000Hz should be enough.
4000Hz 8-bit means: Each second of audio requires 4000 bytes of storage.
So if you put 28000 bytes into PROGMEM aray, you have 7 seconds of audio data in an UNO, you can player either 7 seconds in one piece, or maybe have three audio clips of 2s+3s+2s audio to play from.
PROGMEM data can easily be used up to 64KB on controllers with more than 64KB, and with a MEGA2560 you can use possibly more than 64KB, so more than 15 seconds audio, played from the Arduino program itself, should be no problem, using 8-bit 4000Hz audio data.
For playing longer audio sequences, I'd rec ommend using a small micro SD card module and playing 8-bit WAV file format from SD card. Or maybe use a small and cheap MP3/WAV audio module which can play MP3 or WAV files from MicroSD cards.
jurs:
See here:
Arduino Playground - HomePage
Okey, I got it. I can play a 1 second "cought" sampler for my project, but the volume of the sampler is so low.
I play the sampler directly in a 8Ω, 1.5W speaker.
Would there be a problem if i connect the speaker to a Sound amplifier like a LM386?
I make that question becouse most of the LM386 aplications are for analog input. But in this case, the sound is digital.
The Arduino pin can not drive a speaker directly, you will damage the Arduino.
No problem that is what you must do.
Yes.
No, you have an analogue signal in the form of a PWM signal. It averages to analogue. You might need a RC restoration filter but most amps can cope without one.
BlueIronThiever:
Which circuit did you use for audio coupling between Arduino putput and speaker?
This circuit should work for Atmega based boards and a small 8 Ohm speaker, assuming that you create audio output on digital PWM output pin D9:
You can get a higher output volume when using a 1µF capacitor instead of the 100 Ohm resistor in that circuit.
I have been searching for the same thing. I did come across the ISD2360 chip that is able to have sound files stored into it but I haven't come to find out how to program it or how to use it with other chips/arduino.
Heres the link to the chip: I2360YYI - Nuvoton
If you have been searching for the same thing as the OP, you have not found it in that chip.
BlueIronThiever:
Probably for your case a simple transistor with a 10k base resistor will be enough to drive that speaker. Unless you have at hand a module based in the lm386 making one for this project is probably overkill.
If you connect a 8 ohm speaker to an arduino pin you'll go over the max current for that pin, so you'll have to add a resistor between the pin and the speaker, I think that 1 K ohm is safe.
