Sound Sensor - Which One?
I am doing some freelance work, where I will be making a prototype of a wireless sound sensor, that can send a warning via SMS every time the sound has breached X dB for N seconds.
I have the code for the GSM (SMS) module locked down, and the logic for the rest. All I need is the hardware for the microphone/dB sensor, so I can put it all together.
I thought this part would be the easiest so I left it for last, but turns out, that I cannot find any microphones/sensors, that fit my needs.
I have found many sensor boards, that include a microphone and the necessary filters to make them compatible with the Arduino, but none of those that I've found can reach the ranges I need (approx 120 dB - think of fire alarms and concerts). Whenever I try to search for the sound sensor with new keywords, I am lead back to the same sensors.
I have therefore assumed, that I might need to make a custom solution? If not, and there is an off-the-shelf solution that costs no more than 15 USD per module, please let me know. Since this would by far be the best solution both in terms of reliability but also time (university is already taking the majority of this, so I don't have time to "nerd" with this project too much :frowning: )
But, if I really do need to make a custom solution, I figured this would be the best place to start. I have some vague ideas of what is needed and of how sound works, but please, explain to me as though I was an idiot, what I will need to do in order to make a reliable audio sensor, that can reach 120 dB.
Also, preferably a solution that is analogue, such that X can be decided through software. Or where the sound limit X can be entered precisely through hardware (no turning on a potentiometer for a hand-wavy guesstimate).
As a final note; IF there is a off-the-shelf solution, please simply redirect me to this.
Thank you very much :slight_smile:
Have you looked at the actual circuit and been able to determine if the limit is the actual microphone itself or something else? Have you investigated covering the microphone with sound absorbing material that will reduce your 120dB to a level suitable for the device?
The microphone is the limiting factor for loud sounds, so look for one that can handle well above 120 dB. The electronics required to interface a microphone to Arduino are trivial.
Or, as Paul suggests above, use sound dampening material to reduce the effective sensitivity of, say this module: SparkFun Electret Microphone Breakout - BOB-12758 - SparkFun Electronics
In any case you will need a professional sound level meter to calibrate the setup.
Lots of irrelevant words. That only make helpers turn the other way.
Link needed for evaluation.
That does not make helpers enthusiastic.
That's technical data that can help.
Duh! :rofl:
I have a SparkFun BOB-12758 so just for fun, awhile back I made an SPL Meter. Here is the code, followed by some notes & comments:
// SPLmeter.ino (7-17-21)
// This is just a simple example program, not intended as a "real" SPL meter.
// It reads the peak & average SPL and "prints" the results to the Arduino Serial Monitor via USB.
// The USB has to stay connected so you can use the Serial Monitor on your computer.
// It could be modified to use an LED or LCD display.
// IT NEEDS TO BE CALIBRATED FOR THE PARTICULAR MICROPHONE BOARD, SO YOU NEED A REAL SPL METER!
// To calibrate, find the peak and average ADC readings at a known SPL level from the real meter.
// The input is assumed to be biased at Vcc/2 for a reading of ~512 with no signal (silence).
// The bias is subtracted-out to get the "real" readings.
// Since you'll never have true-silence (and there is electrical noise) you can measure and calculate an average to find the actual true-bias.
// My example does not include code for finding the true bias/average but when I tried it I was getting readings of 511 or 512 as expected.
// This works with most Arduino microphone boards that have amplified & biased outputs.
// I used a SparkFun BOB-12758 microphone board.
// Some microphone boards have an "envelope follower" output which puts-out a varying DC voltage relateive to loudness.
// A voltage-follower output isn't biased so you can take the bias subtraction out of the program.
// dB calculations are always relative so the raw dB calculation is added to dBSPLref (or effectively "subtracted" if you "add a negative" raw dB reading).
// Global Variables
int Bias = 512;                           // Nominally half of the 1023 range   Adjust as necessary
int Analog;                               // The analog reading with bias subtracted-out and converted to absolute value (Read from A0)
int Max;                                  // The maximum peak
int LoopTime = 1000;                      // Read continuously in a fast-loop for one second before finding peak & calculating average
int SPLref = 94;                          // An arbritary (semi-standard) reference for finding PeakRef and AvgRef. Any known SPL level will work
int PeakRef = 159;                        // Measured (or calculated) at SPLref
int AvgRef = 73;                          // Measured (or calculated) at SPLref
int n;                                    // Number of readings in the loop (for calculatijng the average)
unsigned long Sum;                        // For finding average
unsigned long ReadStartTime;              // millis() used for SampleTime loop
float Average;                           // ADC average
float dBSPLPeak;                         // Peak dB SPL reading.
float dBSPLAvg;                          // Average SPL reading
  Serial.begin(9600);                   // Used for serial monitor
// Start main loop ============================================================================================
  Max = 0;                                  //Initilize/reset every time before starting while() loop
  Sum = 0;
  n = 0;                                    //Number of readings (number of loops counted in 1 second)
  ReadStartTime = millis();                 //Save/update loop-starting time
  // Find maximum & accumulate sum loop ==================================================================================
  // Takes readings in a "fast loop" to find the peak & average.
  while (millis() - ReadStartTime < LoopTime)            // Normally 1 second
    Analog = abs(analogRead(A0) - Bias);                 // Read, take out the 2.5V bias/offset, make positive.
    if (Analog > Max)
      Max = Analog;                                      // Save overall maximum reading (Zero is invalid for log/dB calculation)
    Sum = Sum + Analog;
    n++;                                                 // Count the number of readings (to calculate average)
  }  // of while() loop ===================================================================================================
  Average = (float)Sum/n;                                // Zero is invalid for log/dB calculation
  //Calculate dB SPL maximum and and average and send to Serial Monitor before re-starting main loop
  // Since the dB calculculaion is relative to the reference we must add it to the reference to get dB SPL.  (It's OK to "add a negative")
  dBSPLPeak = SPLref + 20*log10((float)Max/PeakRef);
  dBSPLAvg = SPLref + 20*log10((float)Average/AvgRef);
  Serial.print (" Max = ");      // Take out (or comment-out) after calibration
  Serial.print (Max);            // Take out (or comment-out) after calibration
  Serial.print ("    ");         // Take out (or comment-out) after calibration
  Serial.print (" Average = ");  // Take out (or comment-out) after calibration
  Serial.print (Average);        // Take out (or comment-out) after calibration
  Serial.print (dBSPLPeak,1);        // Display peak dB SPL reading to one decimal place
  Serial.print (" dB SPL Peak");
  Serial.print ("    ");
  Serial.print (dBSPLAvg,1);        // Display average dB SPL reading to one decimal place
  Serial.println (" dB SPL Average");
}  // End of main loop ==========================================================================================
The BOB 12758 microphone element is rated up to 110dB but my quick-and-dirty calculations say the built-in preamp will clip at about 96dB. If you use this board you might have to change a resistor to reduce the gain in addition to blocking some of the sound. (There are amplifier boards with adjustable gain.)
This isn't an issue with loud sounds but when USB powered I was getting quite a bit of electrical noise to the point where I couldn't measure the loudness of my TV without turning it up louder than normal. With a separate power supply it was useable at lower levels but still not useful for "quiet sounds".
SPL meter COMPLICATIONS -
YOUR METER NEEDS TO BE CALIBRATED. Generally, that means you need a real SPL meter to calibrate your homemade meter. Or you can buy an SPL calibrator that puts-out a known SPL level. A cheap one costs about $100 USD (more than a cheap SPL meter). If the microphone specs give you the sensitivity and you know the amplifier gain you can make a calculation instead of using an SPL meter but there are tolerances so it won't be as accurate. The microphone board I used has a spec of +/-2dB but my calcuated value was only off by about 1dB. The calculated average had more error and I'm not sure why... With a sine wave the peak-to-average ratio is is a known constant.
YOU CAN'T USE A HOMEMADE SPL METER FOR LEGAL OR REGULATORY PURPOSES. For this, your meter has to be calibrated/certified by an independent certified lab. These labs won't calibrate your homemade meter. Same thing if you buy a "cheap" non-certified meter.
Real SPL meters are usually A-WEIGHTED which takes-into account the fact that our ears are most-sensitive to mid-frequencies. A-weighting reduces low-frequency (bass) and high frequency readings. The weighting circuit is normally an analog filter which would be inserted between the microphone preamp and the Arduino. (I've never built a weighting filter.) Weighting could be done in software but it adds lots of software complexity and a regular Arduino would have to pause reading while doing the filter calculations, and you would miss some peaks.
A simple high-pass filter can be used to reduce the low-frequency readings and it's probably "better than nothing". A high-pass filter will filter-out the DC bias (DC is zero Hz) so you'd have to add another bias circuit (or build that as part of your filter).
There is a lot of low-frequency energy in natural sounds or noise and especially in music so a homemade meter without A-weighting will read higher than a real SPL meter. However, you can calibrate-out that error to some extent if you calibrate it with the sound you intend to measure. For example, if you want to measure the loudness of a particular machine you can make your meter match the real meter with the sound from that particular machine.
I calibrated my meter to match with a 1kHz sine wave so at 94dB, my real meter reads 94dB and with this constant tone my homemade meter reads 94dB for both the peak and the average. With music from my stereo the homemade meater reads higher (because of the bass) and of course the peaks are higher than the real meter. (My real SPL meter doesn't read peaks.)
Hey DVDDoug,
First off, thank you very much for the detailed answer!
Secondly, when you say I need to calibrate it; With regards to what exactly? Is it the room shape/size (i.g I want to measure the sound at the end of the room, so I need to calibrate it to be more sensitive)? Or is it because, each physical module is fabricated with some sort of inherent "malfunction/randomness"?
As for the A-weighting, I need to look more into that, but nonetheless thanks for bring it up :slight_smile:
No I have not investigated that or looked at the circuit. Both good ideas, will definitely look into it, thank you :+1:
