Hi there people,
I hope you guys can help me out with my project.
Here's what I want to do (the video attached should illustrate it i guess):
I have a 12 V DC Motor, which draws about 1.7A at full speed (http://www.johnsonmotor.com/en/products/dc-motors/standard-dc-motors/low-voltage-dc-motors/datasheets/NF213G-023-metric.pdf) along with a 1,0µ Multilayer ceramic capacitor between its poles. I built a gearbox around it and mount it to a frame. Then there's a threaded shaft which rotates and pushes or pulls a counterpiece away or towards itself. This makes another piece of frame rotate.
To stear this guy with my Sparkfun Pro Micro I use this L298N Driver http://www.ebay.de/itm/Dual-H-Brucke-DC-Stepper-Motor-Treiber-Controller-Board-Modul-Arduino-L298N-AR-/301044405289?pt=Bauteile&hash=item4617a51429
I don't know if you can see it in the video, but i attached a 10kOhm potentiometer, which constantly gives a feedback of the motors position. Now i tell the motor to move according to a control curve, which consists of an int array of "positions" to reach. The motor moves towards the prompted direction. As soon as the potentiometer returns the respective list value the code moves on to the next value in the control curve.
The code looks like this:
// Pro Micro Nr. D controlling agent 0 and 5
int curveA[] = {570, 570, 570, 570, 570, 576, 535, 535, 535, 534, 534, 533, 533, 533, 532, 532, 531, 531, 530, 530, 530, 529, 529, 528, 528, 527, 524, 525, 525, 525, 525, 525, 524, 523, 522, 520, 519, 517, 516, 515, 513, 511, 509, 506, 504, 501, 499, 497, 495, 494, 492, 491, 488, 486, 482, 479, 475, 471, 468, 464, 462, 460, 458, 457, 456, 455, 452, 448, 443, 440, 440, 441, 442, 442};
int curve_length;
int red = 15;
int poti1 = A0; // select the input pin for the potentiometer
int led = 17; //led pin define
int EnA = 4; // both the digital enable Pins (always turned HIGH)
int In1 = 3; // analog pins for motors
int In2 = 5;
int motor_strength = 250; //motor strength
pinMode(red, INPUT);
pinMode(led, OUTPUT);
pinMode(EnA, OUTPUT);
pinMode(In1, OUTPUT);
pinMode(In2, OUTPUT);
Serial1.begin(9600);
curve_length = sizeof(curveA) / sizeof(int);
//main loop
int i;
for(i = 0; i < curve_length; i++)
analogWrite(In1, 0); // set all motor strengths to zero
analogWrite(In2, 0);
if (digitalRead(red) == HIGH)
int value = curveA[i];
go(value);
signal(500);
// move void
void go(int value)
while(analogRead(poti1) < value)
analogWrite(In1, motor_strength);
if (analogRead(poti1) >= value)
{analogWrite(In1, 0);
return;}
while(analogRead(poti1) > value)
analogWrite(In2, motor_strength);
if (analogRead(poti1) <= value)
{analogWrite(In2, 0);
return;}
// signal definition
void signal(int wait){
digitalWrite(led, HIGH);
delay(wait);
digitalWrite(led, LOW);
delay(wait/5);
delay(wait/5);
delay(wait/5);
This works quite well, but here's the problem:
I need to do this with two motors simultaneously, but as soon as I upload code which intends to read two potentiometers and read two different curve control arrays, the connections to the board breaks down. it "bricks", becomes unaccessible and i have to reset it manually to upload something else.
The code I tested looks something like this:
int i;
analogWrite(In3, 0);
analogWrite(In4, 0);
int valueA = curveA[i];
int valueB = curveB[i];
go1(valueA);
go2(valueB);
signal(500);
with "go1" and "go1" and the inputs and outputs modified respectively.
I have no clue why, but I was doing some tests and everytime i try to do anything that requires to write two analog signals in correlation to read analog from two potentiometers fails miserably.
could it be a problem with the current??? Maybe the Pro Micro can't provide enough current to give signals to so many pins???
At first I thought it's a problem with two while-loops interfering so I played around with code without these loops, but it's the same problem: as soon as i read to potentiometers that guy bricks
Does anyone have suggestions?
Thanks a lot
Benjamin
Mein Film.mp4 (2.32 MB)
